Results 1 to 12 of 12
Thread: Probleme cu Incubus
    RSP Enigma Team
    28 Aug 2009
    Departe
    Default Probleme cu Incubus
    Nu mai reusesc deloc sa fac Incubus sa mearga. Am incercat toate versiunile din RSP menu cu fisierele de configurare respective, am incercat si Incubus 94, nimic. Nu merge nici sharing, nici SoftCam.*** (care merge OK cu mgcamd).
    Postez mai jos fisierul de configurare pt. incubus93T, imi poate spune cineva ce gresesc? Nu stiu ce alte informatii de diagnostic ar mai fi utile acum.
    [General]
    background_execution=1
    debug_level=0
    log_to_console=0
    log_to_file=1
    logfile_name=/tmp/incubusCamd.log
    softcamfile_name=/var/***s/SoftCam.***
    priofile_name=/var/***s/incubusCamd.prio
    on_screen_messages_show=0
    on_screen_messages_username=root
    on_screen_messages_password=
    on_screen_messages_***_update=0
    on_screen_messages_wait_for_***_update=0
    on_screen_messages_ecm=0
    on_screen_messages_emm=0
    console_logs_broadcast=0
    console_logs_broadcast_port=666
    webif=1
    webif_port=668
    [Prov:000000:CaID:0000]
    check_priority=emu,cs,card
    decoder_type=1
    cs_protocol_order=cccam,newcamd,gbox,camd35,camd33,radegast,aroureos
    process_emms_on_cs_mode=1
    process_emm_g=1
    process_emm_s=1
    process_emm_u=1
    card_server_url_0=cccam://User:Pass@server.com:8008
    [Servers]
    card_server_url=cccam://User:Pass@server.com:8008
    [CaIDTunnel]
    1833:1702:000000
    25 Oct 2007
    Chisinau
    Cu ce il legi? Daca il legi cu Cccam atunci trebuie sa ai shi
    cccam://userass@address:12000/yes/no
    shi
    card_server_url=cccam://userass@address:12000
    RSP Enigma Team
    28 Aug 2009
    Departe
    Multumesc pentru raspunsul prompt. Am adaugat linia:
    cccam://User:Pass@server.com:8008/yes/no
    deasupra la:
    Din pacate, tot nimic. Si dupa cum spuneam, nu numai share-ul nu merge, nici macar emu local, cu SoftCam.Key, nu merge.
    RSP Enigma Team
    28 Aug 2009
    Departe
    Am dezactivat tot ce tine de sharing si am lasat numai softcam, pentru simplificarea problemei. La selectarea unui program litera "N" din randul de litere din stanga-sus e initial galbena iar apoi se face verde, dar tot nu am imagine.
    In log vad mesaje de genul:
    zildan edit:
    Nu posta asta ca oricum nu va merge neagra pe emulator din clei, doar avem belele !
    Deci nu spera la emu din chey ca nu merge pe neagra incubus.
    Pune imaginea RSP si ai acolo gata facut cfg ca exemplu.
    Cere si tu un beta si o sa primesti daca crezi ca e foarte veche ultima publica.
    RSP Enigma Team
    28 Aug 2009
    Departe
    Dupa cum spuneam, am incercat toate variantele de Incubus din meniul RSP, descarcand si fisierele de configurare aferente, chei etc.
    Am avut Incubus mergand pe receiver-ul asta, atat cu SoftCam cat si cu CS, dar nu-mi dau seama ce anume am schimbat in configuratie de nu mai merge. In afara de fisierele din /var/*** (incubusCamd.conf, .prio) si /var/config/incubus93T.emu, mai exista alte fisiere la care ar trebui sa ma uit?
    In alta ordine de idei, as fi interesat de un beta. Sunt incepator si nu stiu cat de "valoros" va fi feedback-ul meu, dar pot macar sa incerc sa ajut.
    25 Oct 2007
    Chisinau
    Descarca Incubus94, dar numai pentru CS. Dar cu cine, ce, il legi totushi?
    RSP Enigma Team
    28 Aug 2009
    Departe
    Am incercat si cu Incubus94, acelasi rezultat. Anyway, partea de CS cred ca o sa se rezolve, e posibil ca problema sa fie fost totusi la server (astept confirmarea).
    Dar ramane partea cu SoftCam, care merge OK cu mgcamd, dar aceleasi canale, cu acelasi SoftCam, nu mai merg in Incubus. E normal?
    Asta ar inseamna ca trebuie sa tot alternez intre mgcamd pt. SoftCam si Incubus pt. CS (server cccam) cand schimb canalele. Exista si alte solutii?
    27 Dec 2008
    Default Incubus
    Se poate folosi incubus si ca server sau numai client? Daca se poate sa functioneze drept server de ce anume am nevoie ( programe sau linii de configurare! )
    Multumesc mult!
    15 Nov 2007
    doar client............
    13 Feb 2007
    Earth
    Post
    salut, din ce stiu eu , INCUBUS functioneaza , doar ca si client , client de cccam . noroc .
    27 Dec 2008
    Default Incubus
    Pacat !
    Multumesc de raspuns!
