Results 166 to 172 of 172
Thread: Soleron
Threaded View
    Default Soleron
    Un nou produs? sau o clona?SOLERON (Platforma Linux) ≈ DM 500S
    - 250 MHz IBM PowerPC Processor (350 Mips)
    - Linux Operating System
    - 1 x Smartcard-Reader
    - MPEG2 Hardware decoding
    - Common available NIMs (DVB-S, DVB-C)
    - V.24/RS232 Interface
    - 100Mbit full duplex Ethernet Interface
    - 2 LED status
    - unlimited channel lists for TV/Radio
    - channel-change time < 1 second
    - full automatic service scan
    - supports directly bouquet-lists (indirect unlimited)
    - supports EPG (electronic program guide)
    - supports multiple LNB-Switching control (supports DiSEqC)
    - fully adaptable OSD in many languages (skin-support)
    - SPDI/F Interface for digital bit stream out (AC-3 / DTS)
    - 1 x Scart-interfaces (fully controlled by software)
    DBS-Tuner:
    Frequency Range 950 ?. 2150 MHz
    Signal Level - 65 dBm ?. - 25 dBm
    Signal-to-Noise Level 12 dB max.
    DBS-Tuner Input Connector F-Type female
    Input Impedance 75 Ohm
    AFC +/- 3 MHz
    Demodulation Shaped QPSK
    Input Symbol rate 2 ?. 45 Mbaud/s, SCPC / MCPC
    FEC Viterbi and Reed-Solomon
    Viterbirate 1/2, 2/3, 3/4, 5/6, 7/8, automatic assimilation
    Roll-off Factor 35 %
    Demultiplexing according ISO 13818-1
    Video decoder:
    Video Compression MPEG-2 and MPEG-1 compatible
    Video Standard PAL G/ 25 Hz
    Video Formats 4:3 / 16:9
    Footage 16:9, automatic assimilation for 16:9 TV-Device (over Scart)
    Letterbox precolating for 4:3 TV-Device
    Audio decoder:
    Audiokompression MPEG-1 & MPEG-2 Layer I and II
    Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz
    Output analog:
    Output Level L/R 0,5 Vss on 600 Ohm
    THD > 60 dB (1 kHz)
    Crosstalk < -65 dB
    Output digital:
    Output Level 0,5 Vss on 75 Ohm
    Sampled Data Filtering 32 kHz, 44.1 kHz, 48 kHz
    S/PDIF-Output optical (AC3)
    Video parameter:
    Input Level FBAS 1 Vss +/- 0.3 dB on 75 Ohm
    Teletext filter in conformity with ETS 300 472 Standard
    TV-Scart:
    Output: FBAS,RGB,S-VHS over OSD selectable
    Serielle Interface RS 232:
    Typ RS232 bidirectional
    Bitrate 115,2 kBit/s max.
    Plug Connector SUB-D-9
    Function Update of Firmware and Preprogramming
    Ethernet:
    100 MBit compatible, bi-direktional interface
    LNB Power and polarisation:
    LNB Current 500mA max. ; short-circuit-proof
    LNB Voltage vertical < 14V without load, > 11,5V at 400mA
    LNB Voltage horizontal < 20V without load, > 17,3V at 400mA
    LNB shut-off at Standby-Mode
    Count of active satellite position:
    DiSEqC 1.0/1.2 SAT POSITION / SAT OPTION
    DiSEqC - Rotor Control
    Power consumption:
    < 10W / 12V
    Input voltage:
    DC12V,alternating acurrent +/- 15%
    Extern power supply:
    Input:
    110-240V AC / 50-60Hz / 0,6A
    Output:
    12V = / 1A
    Physical specification:
    Ambient Temperature +15?C...+35?C
    Humidity < 80%
    Size (W x D x H): 195 mm x 130 mm x 40 mm
    Weight: 0,6 kg
    Pret - - 5.750.000 Lei
    Spaniolul :wink:
