Results 1 to 4 of 4
Thread: DREAMBOX 7025
    Default DREAMBOX 7025
    Dreambox 7025 cu tuner Twin
    - 300 MHz Processor
    - Linux open source (most parts under the terms of GPL)
    - Supports Linux Standard API
    - 1 x DVB Common-Interface Slot
    - 2 x Smartcard-Reader
    - Integrated Compact Flash Interface Slot
    - MPEG2 Hardware decoding (fully DVB compliant)
    - TWIN Tuner, mixable, Plug&Play
    - Tunervarianten DVB-S, DVB-C und DVB-T, pluggable
    - 10/100 MBit compatible Ethernet Interface
    - USB Port
    - 12V switch cinch
    - V.24/RS232 Interface
    - Big-size LC-Display
    - 32 MByte Flash
    - 128 MByte DDR-RAM
    - integrated IDE UDMA66 Interface
    - Support for internal HDD in any capacity
    - unlimited channel lists for TV/Radio
    - channel-change time < 1 second
    - full automatic service scan
    - supports directly bouquet-lists
    - supports EPG (electronic program guide)'
    - supports multiple LNB-Switching control (supports DiSEqC)
    - fully adaptable OSD in many languages and skin-support
    - S/PDIF Interface for digital bit stream out (AC-3)
    - 2 x Scart-interfaces
    - RF modulator
    - Audio/Video cinch out
    - MINI-DIN connector for extern IR (send)
    DreamBox DM7025 technical data
    DBS-Tuner:
    Frequency Range 950 . 2150 MHz
    Signal Level - 65 dBm . - 25 dBm
    Signal-to-Noise Level 12 dB max.
    DBS-Tuner Input Connector F-Type female
    Input Impedance 75 Ohm
    AFC +/- 3 MHz
    Demodulation Shaped QPSK
    FEC Viterbi and Reed-Solomon
    Viterbirate 1/2, 2/3, 3/4, 5/6, 7/8, automatic assimilation
    Roll-off Factor 35 %
    Demultiplexing according ISO 13818-1
    Common-Interface:
    Common-Interface Power Consumption max. 0,3A/5V
    Video decoder:
    Video Compression MPEG-2 and MPEG-1 compatible
    Video Standard PAL G/ 25 Hz, NTSC
    Video Formats 4:3 / 16:9
    Footage 16:9, automatic assimilation for 16:9 TV-Device (over Scart)
    Letterbox precolating for 4:3 TV-Device
    Audio decoder:
    Audiokompression MPEG-1 & MPEG-2 Layer I and II, MP3
    Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz
    Output analog:
    Output Level L/R 0,5 Vss on 600 Ohm
    THD > 60 dB (1 kHz)
    Crosstalk <65>
    TV-Scart:
    Output: FBAS,RGB,S-VHS over OSD selectable
    VCR-Scart:
    FBAS
    Serielle Interface RS 232:
    Typ RS232 bidirectional
    Bitrate 115,2 kBit/s max.
    Plug Connector SUB-D-9
    Function: Update of Firmware
    Ethernet:
    10/100 MBit compatible interface
    Function Update of Firmware, Connect to PC
    USB:
    USB 1.1 connector
    Mini DIN:
    I2C for stearing of external devices
    IR funktion
    Pins:
    1 5V
    2 SDA (I2C-Kanal 2)
    3 SCL
    4 3,3V
    7 GND
    8 IR-Output
    9 GND
    UDMA66 IDE Interface:
    Intern for connect HDD
    Compact Flash - Reader
    LNB power and polarisation:
    LNB Current 500mA max. ; short-circuit-proof
    LNB Voltage vertical <14V> 11,5V at 400mA
    LNB Voltage horizontal <20V> 17,3V at 400mA
    Count of active satellite position:
    DiSEqC 1.0/1.2 SAT POSITION / SAT OPTION
    DiSEqC - Rotor Control
    Power consumption:
    < 30W (in operation, horizontal polarization / 400mA LNB current)
    < 25W (in operation, without LNB)
    < 2W (Deep-Standby-Mode)
    Input voltage:
    230V / 50 Hz alternating acurrent +/- 15%
    110V / 60 Hz alternating acurrent +/- 15%
    Physical specification:
    Ambient Temperature +15°C...+35°C
    Humidity < 80%
    Size (W x D x H): 374 mm x 230 mm x 75 mm
    Weight: 1,8 kg without HDD
    http://www.elstar.ro/manuale/Dreambox_ro.zip
    Pret - - 22.400.000 Lei
    2240 LEU NOU
    Fara comentarii! Spaniolul :wink:
    23 Dec 2007
    Not too bad for a blind man ...
    O zi frumoasa! Snow's Avatar
    05 Jan 2007
    Default Re: DREAMBOX 7025
    imagine noua download
    Nabilosat Enigma2 Black Hole - DM7025
    Enigma2 version date: 25 May 2008
    Openvpn Kernel module support included. Openvpn fully embedded in graphic interface.
    Default Skin : Army Niro
    Alternative Skin : Porto Invader
    Main Function Keys
    Button 1xOK = Light Info Skin
    Button 2xOK = Extra Info Skin
    Button Blue = Nabilo Blue Panel
    Button Green = Nabilo Green Panel
    Button Green-Long-Push = Subservices
    Button Red = Start Record
    Button Yellow = Time Shift
    Addons
    Dedicated Addons Server
    Download and install additional packages from Nabilosat server
    Infobar/OSD
    NEW Introducing Analogic Clock to Enigma2
    Channel Orbital Position
    Signal SNR, AGC, BER
    Infobar Picons
    LCD/OLED Picons
    Advanced EMU information
    Nabilo Panels features
    1) Blue Panel
    Setup
    OSD Settings
    Fast Plugin Settings
    Inadyn Settings
    Swap File Settings
    Hard Disk Setup
    OpenVPN Panel
    Samba/Cifs Panel
    Telnet Panel
    FTP Panel
    Info
    CCcam Info
    Memory Info
    Available Space
    Processes
    Service Info
    Enigma2 Settings
    About
    Save
    Select/Start/Restart EMU
    2) Green Panel
    Shoutbox
    Fast Plugin
    Addons
    Addons Download Manager
    Manual Install Nab packages
    Manual Install IPK packages
    Addons Uninstall Panel
    Nabilosat Statistics
    Scripts
    Many thanks to the Beta Testers Team
    Black33, ^^Corrado^^, Maximo II, Matrix10, Porto, Nabilo, Army, Piefav, Franzjuve, Willow, MaxZ4, DeepDiver
    For multiboot use, Nabilosat Team reccommends Oozoon as your choiche for flash image.
    This image does not contain any keys or softcams inside.
    The following are screenshots are taken from the default Army Niro Skin
    preluat de pe http://www.nabilosat.info/forum/show...372#post291372
    prezentare video http://www.maximo.sxhost.info/logoflash/
    Member Beginner Patrocle's Avatar
    28 Mar 2008
    Cine foloseste dreambox 7025?
