Results 121 to 127 of 127
Thread: AZbox firmware V.1...(Daily FW),
  1. #121
    25 Aug 2009
    Default kgdteam firmware
    salut,cine ma poate ajuta cu o sugestie la urmatoarea problema?:kgdt 4890 instalat pe un azbox premium;ecranul ramine negru insa in rest pare ok,se poate accesa prin ftp,telnet.Din telecomanda nu raspunde decit la reset.
  2. #122
    10 Nov 2008
    Daca e cuplat prin hdmi la tv , probabil nu e setata bine rezolutia .
  3. #123
    crisz
    Guest
    Post azbox-0.9.5306-patch.bin
    Da, bine a spus valerica, incearca pe Euroscart sau schimba rezolutia pe HDMI din telecomanda.
    Iata si un nou firmware de la mama lui
    azbox-0.9.5306-patch.bin 45.35 MB
    fixed the multi-language epg ( main audio language sets default epg language ) | improved streaming | improved timeshift | improved recordings
    link: http://www.multiupload.com/EIN0R464FM
  4. #124
    crisz
    Guest
    Default New Firmware from OPENSAT azbox-0.9.5307
    Salut,
    Iata un now firmware de la Opensat :
    2011.07.04 azbox-0.9.5307-patch.bin 45.38 MB
    Updated the satellite's transponder list (needs format application area) | fixed the epg behavior.
    Link:
    http://www.multiupload.com/23G10TOFLB
    Sa auzim de bine
  5. #125
    crisz
    Guest
    Default New firmware azbox-0.9.5308
    New firmware :
    2011.07.07 azbox-0.9.5308 45.39 MB
    DVBS.dat is now split between ku and c band ( to use this new file, after install perform a factory restore ) | fixed the dutch iso369 string | added 2 new dvbc countries : dutch and ukraine ( testing ) | fixed the epg detail scrolling | fixed the number of audio streams available at audio list window (euronews)
    Link:
    http://www.multiupload.com/CL6PV5Q2KU
    Numai bine
  6. #126
    13 Aug 2011
    Default Problems with 0.9.5308
    Hello everybody, recently I have installed the newer firmware 0.9.5308. Now I have observed the receiver is more slow, less stable and the streaming option doesn't work.
    Do you have the same problems? Any ideas?
    Thanks!
  7. #127
    crisz
    Guest
    New firmware :
    2011.09.06 azbox-0.9.5309-patch.bin 45.39 MB fixed youtube
    link:
    http://www.multiupload.com/AXKC7KNGT7
