Dislikes:
Member
Visitor
- Rep Power
- 0
kgdteam firmware
salut,cine ma poate ajuta cu o sugestie la urmatoarea problema?:kgdt 4890 instalat pe un azbox premium;ecranul ramine negru insa in rest pare ok,se poate accesa prin ftp,telnet.Din telecomanda nu raspunde decit la reset.
- Rep Power
- 64
Daca e cuplat prin hdmi la tv , probabil nu e setata bine rezolutia .
azbox-0.9.5306-patch.bin
Da, bine a spus valerica, incearca pe Euroscart sau schimba rezolutia pe HDMI din telecomanda.
Iata si un nou firmware de la mama lui
azbox-0.9.5306-patch.bin 45.35 MB
fixed the multi-language epg ( main audio language sets default epg language ) | improved streaming | improved timeshift | improved recordings
link: http://www.multiupload.com/EIN0R464FM
New Firmware from OPENSAT azbox-0.9.5307
Salut,
Iata un now firmware de la Opensat :
2011.07.04 azbox-0.9.5307-patch.bin 45.38 MB
Updated the satellite's transponder list (needs format application area) | fixed the epg behavior.
Link:
http://www.multiupload.com/23G10TOFLB
Sa auzim de bine
New firmware azbox-0.9.5308
New firmware :
2011.07.07 azbox-0.9.5308 45.39 MB
DVBS.dat is now split between ku and c band ( to use this new file, after install perform a factory restore ) | fixed the dutch iso369 string | added 2 new dvbc countries : dutch and ukraine ( testing ) | fixed the epg detail scrolling | fixed the number of audio streams available at audio list window (euronews)
Link:
http://www.multiupload.com/CL6PV5Q2KU
Numai bine
Member
Visitor
- Rep Power
- 0
Problems with 0.9.5308
Hello everybody, recently I have installed the newer firmware 0.9.5308. Now I have observed the receiver is more slow, less stable and the streaming option doesn't work.
Do you have the same problems? Any ideas?
Thanks!
New firmware
New firmware :
2011.09.06 azbox-0.9.5309-patch.bin 45.39 MB fixed youtube
link:
http://www.multiupload.com/AXKC7KNGT7
