Results 1 to 3 of 3
Thread: Dm714s
    08 Oct 2009
    Default Dm714s
    Salutare poate cineva sa-mi spuna despre placa pci DM 714S care cica ar fii sky tuner nu am idee cu ce player functioneaza???
    24 Feb 2007
    45°39'N & 25°35'E
    Default Re: Dm714s
    Features: *Silicon tuner
    *Fully compatible with DVB-DATA ETSI/EN 301 192 standard
    *Fully compatible with DVB-S Protocol (EN 300 744) /MPEG-2
    *Compatible with TCP/IP, UDP
    * Compatible with progDVB
    *Support SDTV/HDTV
    *Input frequency: 950 MHz ~ 2150 MHz
    *Symbol rate: 2~ 45 MS/s
    *Support DiSEqC1.0/1.2 protocol
    *Max. 32 PIDs can be decoded simultaneously
    *Support Electronic Program Guide (EPG)
    *Support Real Time Digital Video Recording (DVR)
    *Support Infrared Remote Control
    *Compatible with Windows Vista
    DM714S DVB-S TV card supports MPEG-2 A/V decoding. DVB-S can be widely used in software download, fast accessing internet, distance education, distance treatment, distance shopping, newspaper transmission system, video conference, and VOD, etc. DVB-S is based on an open system, supporting upgrade from a local disc or Internet
    http://newmitech.en.ec21.com/DVB_S_T...5_2919277.html
    08 Oct 2009
    Default Re: Dm714s
    Multumesc iky asta am gasit si eu pe internet dar ce am omis este istoricul placii adica am cumparat-o din piata si am coborat driverul de la mama lui adica newmi si am folosit progdvb dar pe jiji apare ceva semnal adica 72% si dupa scanare nu am niciun canal deci cu asta as avea nevoie de ajutor,daca o mai foloseste cineva si stie setarile.
