Thanks Thanks:  60
Likes Likes:  379
Dislikes Dislikes:  1
Page 47 of 65 FirstFirst ... 3743444546474849505157 ... LastLast
Results 691 to 705 of 963
Thread: Bucuria copiilor... BANCURILE NOASTRE
  1. #691
    Golden Member mar1us's Avatar
    09 May 2009
    dublin
    Smile Mail to Tech Support
    Upgrading to Husband 1.0
    Dear Tech Support:
    Last year I upgraded from Boyfriend 5.0 to Husband 1.0 and noticed that the new program began making unexpected changes to the accounting modules, limiting access to flower and jewellery applications that had operated flawlessly under Boyfriend 5.0. In addition, Husband 1.0 uninstalled many other valuable programs, such as Romance 9.9 but installed undesirable programs such as NFL 5.0 and NBA 3.0. Conversation 8.0 no longer runs and HouseCleaning 2.6 simply crashes the system. I've tried running Nagging 5.3 to fix these problems, but to no avail.
    --Desperate***
    Dear Desperate,
    Keep in mind, Boyfriend 5.0 is an entertainment package, while Husband 1.0 is an operating system. Try to enter the command: C:/ I THOUGHT YOU LOVED ME and install Tears 6.2. Husband 1.0 should then automatically run the applications: Guilty 3.0 and Flowers 7.0. But remember, overuse can cause Husband 1.0 to default to GrumpySilence 2.5, Happyhour 7.0 or Beer 6.1. Beer 6.1 is a very bad program that will create "Snoring Loudly" wave files. DO NOT install MotherInLaw 1.0 or reinstall another Boyfriend program. These are not supported applications and will crash Husband 1.0
    In summary, Husband 1.0 is a great program, but it does have limited memory and cannot learn new applications quickly. Consider buying additional software to improve performance. I personally recommend HotFood 3.0 and Lingerie 5.3.
    Good Luck! Tech Support
  2. #692
    - Iţi aduci aminte, draga mea, prima noapte de dragoste? N-ai avut timp nici ciorapii să-i dai jos, spune cu nostalgie soţul.
    - Da imi amintesc,… răspunde soţia. Acum pană te “hotărăşti” tu, am timp să impletesc două perechi.
    Anul acesta de Halloween eu şi cu prietenii mei ne-am deghizat in blonde.
    - Ne daţi sau nu ne daţi?
    Şi toţi ne-au dat-o…
    Vorbesc doi prieteni:
    - Soţia mea e tot timpul nemulţumită – ba că nu am dus gunoiul, ba că nu am plimbat căţelul, ba că nu am strans după pisică, ba una, ba alta! M-am săturat!
    - De bătaie ce zice?
    - Slavă Domnului, incă nu a ajuns să mă bată!
  3. #693
    O blondă in autobuz. Şoferul anunţă:
    - Umătoarea staţie: “1 Decembrie”.
    Blonda, panicată:
    - Mai devreme nu se poate!?
    Fiul meu de 6 ani mi-a lasat secretara gravidă. Ticălosul mic a luat un ac şi mi-a găurit toate prezervativele!
    Un gangster celebru ii oferă proaspetei logodnice un superb colier de perle. Incantată, tanăra intreabă:
    - Sunt fantastice! Ştiu că nu se face, dar sunt foarte curioasă. Cat poate să coste aşa ceva?
    - Păi, cu aproximaţie, intre cinci şi zece ani.
    - In fine, am reuşit să mă las de fumat. Imaginează-ţi, in ultima vreme, cum aprindeam ţigara, cum incepea să-mi curgă sange din nas!
    - Nu e nevoie să-mi imaginez. Să ştii că şi nevastă-mea e o femeie extrem de dură.
    - Sunt cazuri cand soţul trebuie să-şi mintă soţia.
    - Asta nu-i chiar atit de grav. Mai rău e cand trebuie să spună adevărul!
  4. #694
    29 Mar 2009
    Austria - TM
    Intra Gigi Becali in discoteca... o fata super se apropie de el si il
    intreaba dulce :
    - Dansati ?
    - Nu fa zdreanta ce esti, asa merg eu !
  5. #695
    După meciul Steaua Dinamo intră un dinamovist intr-o cafenea:
    - Bună seara, o cafea, vă rog..
    Ospătarul:
    - Imi pare rău, avem doar 3 in 1!
    Un dialog de dimineata:
    - Scumpo, stii, cand ma barbieresc dimineata, ma simt cu zece ani mai tanar.
    - Dar nu ai putea sa te barbieresti seara?
    Petrecerea burlacilor
    Cu cateva zile inainte de nunta:
    - Draga, am hotarat cu prietenii sa organizez o petrecere a burlacilor ...
    - Aha! Bautura cat incape, curve si toata noaptea faceti sex cu ele!
    - Nu, draga, doar cate o bere, linistiti, vom povesti ...
    - Tu pe cine minti? Crezi ca eu nu am fost la petreceri de burlaci?!
  6. #696
    29 Mar 2009
    Austria - TM
    Red face
    După meciul Steaua Dinamo un dinamovist il intreaba pe arbitru dupa meci:
    - Ce mai face cainele dvs?
    - Care caine? Eu nu am nici un caine.
    - Cum? Orb si umblati fara caine?
  7. #697
    - Buna Ziua! Aveti cartea "Dinamo in Liga Campionilor"?
    - Da. Vedeti ca e la raftul cu SF.
    I: De ce isi bat dinamovistii copiii in ziua de Craciun?
    R: Pentru ca umbla cu Steaua.
    Un dinamovist da peste lampa lui Aladin. O freaca el si din ea iese un duh, gata sa-i indeplineasca o dorinta. Dinamovistul zice:
    - Fa-l pe puradelul de fiul meu cel mai inteligent om de pe planeta. Duhul raspunde:
    - Asa ceva e imposibil. Uite-te la el, e retardat mintal, jegos, plin de paduchi, nici nu stie sa scrie si sa citeasca. E prea greu. Ai vreo alta dorinta?
    - Atunci fa sa castige Dinamo campionatul! La care duhul se scarpina in cap si zice:
    - Ia adu-l pe fiul tau sa mai ma uit o data la el.
    Un dinamovist merge impreuna cu ciinele sau intr-un bar pentru a vedea un meci de campionat al favoritilor. La fiecare gol al ros-albilor, patrupedul schelalaia de mama focului, se ridica in doua labe si topaia, dadea din coada, sarea bucuros pe masa, facea tumbe.Uimit nevoie mare, barmanul ii zice stapinului: "Dom'le, incredibil ce ciine ai! N-am mai vazut asa ceva! Dar, spune-mi si mie, daca se bucura la modul asta la un meci de campionat, cum se manifesta in Liga Campionilor?". Replica omului: "Nu stiu, ca il am doar de 15 ani!"
    - De ce li se spune dinamovistilor spartani?
    - Pentru ca au doar 300 de suporteri in tribuna...
    Bula mergea plingind pe strada. Un trecator il intreaba:
    - De ce plingi, Bula?
    - M-a batut tata.
    - Si acum unde te duci asa hotarit?
    - La Dinamo, ca am auzit ca aia nu bat pe nimeni.
    - Ce se intampla daca din gresala bagi in aparatul de cafea un banut cu sigla CFR Cluj?
    - Pe afisaj apare scris UEFA Champions League.
    - Ce se intampla daca bagi unul cu Dinamo?
    - Pe afisaj scrie: MAI INCEARCA!
    - Care este diferenta dinte o buburuza si Dinamo?
    - Buburuza are mai multe puncte...
  8. #698
    29 Mar 2009
    Austria - TM
    Gata mä predau
  9. #699
    11 Apr 2008
    Fost mebru
    De ce nu poartă steliştii centura de siguranţă in maşină? Ca să adune puncte...
    Banc aparut dupa meciul Steaua - Olimpique Lyon 3-5:
    - Cum se saluta stelistii? Give me five!
    - Care e animalul preferat al stelistilor? Cincila.
    - Ce oras viseaza sa viziteze stelistii de Craciun? Cincinnati.
    - Cum dau noroc stelistii dupa marele meci cu Lyon? Cin-cin.
    - Care e site-ul favorit al stelistilor? HI5.
    - Cladirea preferata? Pentagon
    - Povestea preferata? 5 paini, de Ion Creanga
    Mesajul Cleopatrei Stratan pentru Banel Nicolita:
    - "Te-astept la cealalta portita!"
    Emil Gradinescu la meciul Stelei cu Napoli: Avem nevoie de un gol, un singur gol si suntem calificati!… L-am primit!!!
    Un fan stelist se duce la stadion pentru a-si achizitiona un tricou cu echipa bucuresteana:
    - As dori un tricou cu Steaua.
    - De care sa fie de portar, de fundas, de mijlocas, de atacant sau de arbitru?
    Pandurii Tg Jiu – Steaua 2-1 ; (Marcatori: Nicolita, Nicolita /Nicolita )
    Un rapidist si un stelist la poarta raiului.
    Sfantul Petru le zice: Pe tine nu te primesc in rai pentru ca nu ai avut mila de saracii stelisti si i-ati batut rau cu 5-1!! Pe tine, stelistule, te primesc pentru ca Steaua nu bate pe nimeni!!
    De ce a fost poreclit Mihai Costea, Nila, cand a venit la Craiova?
    Pentru ca se stia ca intr-o buna zi se va duce cu oile!!!
    Ce echipa poate sa invinga Steaua?
    Steaua Bucuresti cu Banel titular!!
    Ce canta un suporter dinamovist cand merge cu Steaua:
    Steaua sus rasare
    Pierde in deplasare
    Pierde si acasa
    Si retrogradeaza!!
  10. #700
    Quote Originally Posted by Diablo1 View Post
    Gata mä predau
    Si eu!
  11. #701
    Member Addicted Member
    11 Feb 2007
    Șoseaua Kiseleff nr. 10
    Cred ca e momentul ca dinamovistii sa mearga fara centura in masina!
    Valabil si pentru rapidisti!
    Gigi Becali beat, impreuna cu sotia sa in fata stadionului Dinamo. Vine un politist si spune:
    - Stiti, domnule Becali, nu e bine sa stati in fata stadionului Dinamo, ca sunt suporteri si pot sa va agreseze!
    - Ce ma? Pe mine, Becali? Ce sa-mi faca ei? Pai, eu, la banii mei, cumpar tot stadionul lui Dinamo, il cumpar si pe Borcea. La care sotia zice:
    - Lasati-l, domnule ofiter, sotul meu cand e beat cumpara toate cacaturile!
    De ce isi trimite NASA astronautii sa se antreneze in Stefan cel Mare?
    - Pentru ca este singurul loc din lume fara pic de atmosfera!
    I: Esti intr-o camera cu un leu, o cobra si un dinamovist si ai un pistol cu doua gloante. Ce faci ?
    R: Impusti dinamovistul! De doua ori!
    -de ce li se spune la dinamovisti, spartani?
    -pentru ca au cei 300 de arbitri (romani) alaturi de ei.
    Culmea echipei Dinamo: sa fie vai de steaua ei!
  12. #702
    11 Apr 2008
    Fost mebru
    Mă predau şi eu ...
  13. #703
    11 Feb 2007
    Ok. Toti care v-ati predat incolonati-va si directia casa de bilete a FC STEAUA pentru abonamente pe viata. Intr-o mana sa aveti buletinul si in cealalta cererea de adeziune la peluza nord sau sud (dupa preferinta).
  14. #704
    Ajunge barbatul acasa, coboara din masina, intra in casa, se tranteste pe canapea, se descalta si isi arunca sosetele pe masa, deschide televizorul si urla:
    - Nevasta in momentul acesta adu-mi repede o bere! Hai, pana nu incepe!!
    Femeia se conformeaza si-i aduce o bere.
    Dupa 10 minute:
    - Nevasta mai adu 2 beri, dar repede!! Pana nu incepe!
    Femeia nedumerita ii mai aduce 2 beri.
    Dupa alte 15 minute:
    - Auzi, in minutul asta mai adu-mi 2 beri!! Ca imediat incepe!!!
    Femeia, cu nervii intinsi la maxim, cedeaza:
    - Auzi, ma, dobitocule , pai cine dracu te crezi tu in casa asta?
    - Na, ca a inceput!
  15. #705
    De ce au suporterii dinamovisti palmele lucioase?
    Dupa fiecare meci isi freaca mainile zicand: - meciul urmator, sigur batem!
