Member
Beginner
- Rep Power
- 0
Problema
Buna seara !
Am un receiver kaon ksf100, si am incercat sa ii bag astazi un firm , si mi-a aparut mesajul asta:
[ Upgrade mode. ] "" File open error, please open file first! Engineer Mode UPGRADE TOOL (V2.30) 22-MAR-2004 Patch File open O.K.! > Old version binary. -. Target loader version :L 619 -----------> Front :: 74HC164 used (connector: 14pin) -----------> Target 2M Flash. -----------> Target AMD/ST FLASH(TOP). Connect Success //================================================== // FileInfo: KAON-TEAM, H/W(FF.0C.FF), S/W(03.00.00) // Target: L 619, u-C[0] , FLS[2M], KSF-100SCO, H/W(12.C0.A5), S/W(03.00.37) //================================================== Target Model Mismatch : KSF-100SCO Hardware Version Mismatch Your DVB-S/T/C is not same ! MICOM Type mismatch ! CI/CAS Type mismatch ! HDD Type mismatch ! You got 5518-B parallel, cannot upgrade 5518-D serial.STB Model : KAON-TEAM -. STB H/W Ver : 12.C0.A5 -. STB S/W Ver : 03.00.37 DownLoad Start 263 Block Retry 323 Block Retry 382 Block Retry DownLoad Success DownLoad CRC Check OK Flash Write Start Flash CRC Check OK Upgrade End COM1 Off !!! ("Enter" key to reconnect.) STB normal start. [ Upgrade mode. ] Engineer Mode UPGRADE TOOL (V2.30) 22-MAR-2004 Patch File open O.K.! > Old version binary. COM1 Off !!! .
Am si eu niste nelamuriri
1.Receiverul trebuie bagat in priza cand ii schimbi softul sau trebuie bagat dupa anumiti pasi ?
2.Am stricat ceva?
3. Cum stiu daca pinii sunt conectati bine? daca nu sunt conectati bine cum pot sa ii conectez?
Multumesc!
Re: Problema
1.conectezi recul la calculator(doar null-modem) atentie scos din priza inainte de al scoate din priza pentru conectare asigurate ca este in stand by.
2.pornesti programul kup.230exe dai space de la tastatura clic open alegi softul iara open si apesi pe butonul de pornire la receptor si astepti pana se incarca softul.
Ai aici poza www.sat.us.pn scrii pe google.
3.In menu keylor intri galben+menu selectezi nagra 2 de duci la 00211 si pui kei 00-01 (00)
10-11 (01)
Si la setare sistem sa fie chanel pe unloked.
Success!
Member
Beginner
- Rep Power
- 0
Re: Problema
Deci la punctu1 adica receptorul cand il bagi in priza nu trebuie sa porneasca pe un kanal trebuie sa fie in stand by.oprit de la telecomanda.
Member
Beginner
- Rep Power
- 0
Re: Problema
Am decodat aparatul, dar cand il conectez tot clipeste conax in dreapta sus.. incontinuu..
si apropo, am apasat galben+meniu si nu am gasit nagra 2.. decat nagra vision. am bagat codurile la 2111 00 si 01 si nu a mers? Ce credeti ca nu am facut bine
EDIT: am rezolvat, am schimbat pe intelsat si a mers ! Mersi cipry pt ajutor!
- Rep Power
- 71
Re: Problema
Daca iti arata conax......inseamna ca ai gasit focus .
Cauta programele de gigi si iti v-a merge.
Member
Visitor
- Rep Power
- 0
kaon
salutare,
am si eu nevoie de ajutor pls...tocmai mi-am decodat KAON ul de la focus sat
merge ok, am urm instructiunile d mai sus, dar a treb inainte sa scimb firmware cu Kup230 sa incarc bootloaderu KaonTeamBL219v4.exe si dupa aia a mers si kup230 care imi tot dadea eroarea de mai sus din topic.
Sunt incepator si nu stiu cum se introduc/schimba codurile pt gigi
Apas galben+meniu ma duc la nagravision aleg 2111 01 si dupa aia nu mai stiu ce fac??
Dak puteti sa-mi spuneti si mie cum se face. ms.
Member
Visitor
- Rep Power
- 0
