Results 1 to 3 of 3
Thread: problema cccaminfoPHPv0.8.2 ?
    02 Feb 2008
    Default problema cccaminfoPHPv0.8.2 ?
    salut,dupa un restart la dm500 si un update la cccaminfo ami apar foarte multi clienti activi,dar fara sa se conecteze:ex.
    Active Clients : 26
    # Username Host Connected Idle time ECM EMM Ver Last used share Ecm time
    1 ------------ 00d -2:-38:-6 00d -2:-38:-6 0 (0) 0 (0) 2.1.1
    2 ------ ----- 00d -2:-38:-7 00d -2:-38:-7 0 (0) 0 (0) 2.0.11
    3 ------ ----- 00d -2:-38:-7 00d -2:-38:-7 0 (0) 0 (0) 2.0.11
    4 ------ ----- 00d -2:-38:-10 00d -2:-38:-10 0 (0) 0 (0) 2.0.11
    5 ------ ----- 00d -2:-38:-11 00d -2:-38:-11 0 (0) 0 (0) 2.1.1
    6 ------------ 00d -2:-38:-11 00d -2:-38:-11 0 (0) 0 (0) 2.1.2
    7 ------------ 00d -2:-38:-11 00d -2:-38:-11 0 (0) 0 (0) 2.1.2
    8 ------------ 00d -2:-38:-12 00d -2:-38:-12 0 (0) 0 (0) 2.1.2
    9 -------------00d -2:-38:-13 00d -2:-38:-13 0 (0) 0 (0) 2.1.1
    10 ------------ 00d -2:-38:-13 00d -2:-38:-13 0 (0) 0 (0) 2.1.2
    11 ------------ 00d -2:-38:-13 00d -2:-38:-13 0 (0) 0 (0) 2.1.1
    12 ------------ 00d -2:-38:-13 00d -2:-38:-13 0 (0) 0 (0) 2.1.2
    13 ------------ 00d -2:-38:-14 00d -2:-38:-14 0 (0) 0 (0) 2.1.1
    14 ------------ 00d -2:-38:-17 00d -2:-38:-17 0 (0) 0 (0) 2.1.1
    15 ------------ 00d -2:-38:-17 00d -2:-38:-17 0 (0) 0 (0) 2.0.11
    16 ------------ 00d -2:-38:-17 00d -2:-38:-17 0 (0) 0 (0) 2.0.11
    17 ------------ 00d -2:-38:-18 00d -2:-38:-18 0 (0) 0 (0) 2.0.11
    18 ------------ 00d -2:-38:-18 00d -2:-38:-18 0 (0) 0 (0) 2.1.1
    19 ------------ 00d -2:-38:-19 00d -2:-38:-19 0 (0) 0 (0) 2.1.2
    20 ------------ 00d -2:-38:-21 00d -2:-38:-21 0 (0) 0 (0) 2.0.9
    21 ----------- 00d -2:-38:-21 00d -2:-38:-21 0 (0) 0 (0) 2.1.2
    22 ----------- 00d -2:-38:-22 00d 00:00:01 118 (117) 0 (0) 2.0.9 0500:024f00:001b (ok) 0.1967s
    23 ----------- 0d -2:-38:-24 00d -2:-38:-24 0 (0) 0 (0) 2.1.2
    24 ----------- 00d-2:-38:-25 00d -2:-38:-25 0 (0) 0 (0) 2.0.11
    25 ----------- 00d -2:-38:-26 00d -2:-38:-26 0 (0) 0 (0) 2.1.2
    26 ----------- 00d -2:-38:-39 00d -2:-38:-39 0 (0) 0 (0) 2.0.9
    am imaginea nemesis4.4 max var.daca este o linie cu probleme cum o pot afla?tb verificate una cate una?linii am in jur de 40 .spatiu este suficient doar 40% ocupat.ps .am schimbat imaginea dar fara rezultat.
    Standard RSP member ASs's Avatar
    28 Mar 2009
    Default Re: problema cccaminfoPHPv0.8.2 ?
    Din ce am observat si eu, apar acesti peeri la Active Clients atunci cand ei se logheaza la server, iar dupa autentificare trec la lista de Clients.
    Acsti clienti apar simultan in lista de clienti si clienti activi ?
    24 Nov 2008
    apar ca clienti activi la inceput cand se logheaza toti dupa restartul tau .
    Dar ar trebui ca apoi sa dispara .
    Ai dat un update in cccaminfo ?
