Page 33 of 86 FirstFirst ... 232930313233343536374383 ... LastLast
Results 481 to 495 of 1283
  1. #481
    Super Member painluck's Avatar
    08 Feb 2007
    Quote Originally Posted by maximuss View Post
    In cautarile mele ptr documentare am gasit astea , nu stiu exact ptr ce model sant ptr ca nu era scris.
    Secret menu:
    8888--key boards,the activation of EMU,it is possible to write the keys in here
    7777--the settings of card sharing,other Echo,you are on net
    9231--the settings of card sharing on splitter
    9232--the correction of a picture slip
    9233--weaker transponder it is possible to strengthen his sign a little bit
    9234--box-keys to a card
    9236--card,card sharing,emu the setting of priority (2.85,2.87,2.88,2.89 sw)
    se pot accesa pe echo 791
  2. #482
    Super Member
    15 May 2007
    deci merge (acum) digi pe echo 790? poate cineva sa confirme?
  3. #483
    Moderator sorin8m's Avatar
    22 Apr 2007
    Quote Originally Posted by badeaghio View Post
    deci merge (acum) gigi pe echo 790? poate cineva sa confirme?
    Nu, doar daca bagi manual cheile.
  4. #484
    Super Member
    15 May 2007
    gasii un softcam, de echo zice nenea ala pe crosat, sa il pun sa vad daca merge.
    eu nu zic de AU, din ce ai spus tu pe thread-ul asta, cu un soft viitor
    a, inca ceva:
    rom_log_Conexant.zip
    20 new tested logs
    ce e asta si cum se foloseste? am vazut la uptool ceva cu log, la ce ajuta?
  5. #485
    Super Member genugeo85's Avatar
    01 Apr 2007
    Vagauna Romania
    Foloseste cu incredere key-le postate de orlandosro!
  6. #486
    22 Apr 2007
    a, inca ceva:
    Sunt logo-uri pentru echo de la rusi.
    Cum noi avem echolite ei ai metabox.
    Sa mai scris despre asta.
  7. #487
    Standard RSP member delsat's Avatar
    22 Jul 2007
    Crisana
    771 ii la fel ca si 790, ma refer la sw.
  8. #488
    22 Apr 2007
    Quote Originally Posted by delsat View Post
    Da, e acelasi
  9. #489
    Standard RSP member bobo74's Avatar
    02 Mar 2007
    Revin cu aceeasi rugaminte...!
    Cine are un soft(2.92,2.93,2.95,etc) care merge cat de cat si care face AU la Premiere si functioneaza fara sa se blocheze din 10 in 10 sec il rog sa posteze aici si sa ne spuna si noua pas cu pas cum procedeaza si ce softcam foloseste...!
    Se pare ca pentru Digi sunt din nou key...!a testat cineva?
    Multumesc.
  10. #490
    22 Apr 2007
    Quote Originally Posted by bobo74 View Post
    Se pare ca pentru gigi sunt din nou key...!a testat cineva?
    Multumesc.
    Pai 2.92 gasesti pe crosat iar pentru premieire nu tre sa pui nici un soft ca sa mearga AU pentru ele, doar tre sa pui pe premiere start astepti pana nu iti apare imaginea si asta e tot. A sa nu uit ca sati mearga te sa activezi emulatorul cu "meniu+8888".
    Cu stima
  11. #491
    VIP EchoCat's Avatar
    EU
    In cateva zile vine v2.96,acum e in teste
  12. #492
    29 Aug 2007
    Si care ar fi noutatile ?
    Ceva AU ? Pt D+ si alti D
  13. #493
    22 Apr 2007
    Quote Originally Posted by EchoCat View Post
    Sper sa nu fie testat ca si cu 2.93.
    Eu nu mai cred nimic pana nu vad.
  14. #494
    EU
    Quote Originally Posted by sorin8m View Post
    Sa stiti un lucru de la v2.92 in sus toate sunt cu full Nagra AU!Ca unele nu au fost publice asta e alta lucru...
    Noul uptool 8.4 771_791 am pus la sec.UPLOAD
  15. #495
    22 Apr 2007
    Eu zic ca nu exista findca nu leam vazut. 2.92 dupa aceea 2.95 care e o rusin de soft. Daca ai ceva fati curaj si publica.
