Results 1 to 9 of 9
Thread: UFS910 with any E2 + EMU crashes after 2-6 hours
    04 Apr 2009
    Default UFS910 with any E2 + EMU crashes after 2-6 hours
    Hello,
    all the images I tested till now are stable until I use a EMU.
    For ex I tested all version of incubus and the best I get is 2-6 Hours wout a crash. Today I tested MgCamd.133 and it crashes after 30Mins.
    With crash i mean, the Receiver completely freezes and it can be revived only by powercycling....
    My prefered EMU would be Incubus.
    I tested the RSP Images too, but i have the same problems, with incubus (all versions) after 2-6 hours the Receiver crashes....
    Can anyone help me with this ?
    I use BA with the E2 images installed in a seperate Partition, where each Partition is 900Mb big. In Flash I have the 2.0 Official Software.
    Thankyou in Advance,
    Konstantin
    06 Dec 2008
    Default Re: UFS910 with any E2 + EMU crashes after 2-6 hou
    hi
    with incubus any version
    04 Apr 2009
    Is there anyone that uses sucessfully any E2 Image with a Incubus version and doesnt have regular crashes(complete receiver Freezing) ?
    Could that be a memory (Ram) Problem ?
    What I observed is, that the newer the Image the bigger the Problems.....
    Is there anyone from the RSP Team or Forum member, that could give some advice ?
    Konstantin
    27 Nov 2008
    I have to confirm that I have the same problems. I have a very good payserver with very little freezes but incubus crashes my kathy anyway.
    The same happens with mbox only less often...
    04 Apr 2009
    Hello,
    1) Is there anyone here that has got working a E2 Image with Incubus relyable?
    2) Is this a general problem of all base images in combination with ANY Emu ?
    3) I use cccam on my 7025 cause it is the most stable cam i had till now
    and it has a build in cardreader code..so no newcs or other cardserver is nessesery.
    I use only local cards on my 7025 that i want to share wirth my Kathrein (for the HD stuff), the 2 receivers are on the same LAN so no delay probs at all....
    4) yesterday i try ed to use mgcamd on the UFS910 connecting to newcs on the 7025, well this combination crashes the UFS much faster......
    All others of you(except of the 2 people that replyed) that use E2 + Incubus on a UFS910 have no problems ????
    any help or tips ????
    Cheers,
    Konstantin
    05 Sep 2007
    From what i know it is a problem in E2, AAF has serios problems on incubus, RSP does work pretty well except NDS where if you have a card with too much delay it will probably crash(>800ms) this is a problem on AAF too...
    I do have too many cards in incubus because i can`t limit my lines, but except this problem who slows down the box a little , it works fine.
    21 Post(s)
    My tests using MgCamd 1.33 shows that it is the most performant of all emulators ! no freezes no crashes ... speed zapping ...decode everything and uses softcam.key witch can be foun everywhere ! updated daily !!! as soon the 1.34c will be available ..will have MgCamd client to CCCam server ...
    04 Apr 2009
    Hello and thankyou for the Answers !
    @ resofty:
    That makes sense, because when i was using the latest RSP i had crashes with incubus, but not that fast as with AAF...From all the images i tested i liked the RSP most, but there wasnt an update for a while now so i tested AAF.
    @mihaip:
    1) does that mean that using mgcamd 1.33 client to newcs should work stable on the UFS ?
    2) thats great news that mgcamd1.34c will have the cccam protocol too!, do you know when it will be available ?
    I will install the latest RSP image again till a new one comes out.
    a) Are there any tips regarding the incubus config ? I use 0.93
    b) does it make any inpovement using the 0.93-teta ?
    Here the link to my current incubus config:
    http://www.grsnet.net/incubusCamd.conf
    Thankyou ,
    Cheers, Konstantin
    04 Apr 2009
    Well it seems that incubus is really not suitable for the UFS....I installed today again the latest RSP Image and Incubus 0.93teta and the best result i had was 1:30h wout crashing the box.....
    I hope the MgCamd cccam client will be more stable .....
    Cheers,
    Konstantin
