Results 1 to 12 of 12
Thread: Smargo Card Reader @ K?nig Hub
    Standard RSP member Black_Angel's Avatar
    31 Mar 2008
    AR( RO.), KA( DE )
    Default Smargo Card Reader @ König Hub
    asi avea iarasi o problema de care nu i dau da capat
    am Dream Box 7020Si- cu Nabilo Darkstar si CCcam- vers. am sa revin mai incolo
    mai nou am facut Abo la Dolce si bagat in Dream
    asta inseamna ca am acuma 5 cartele
    gamam card pe - card reader extern -Phonix
    KBW-Bundesliga - in slot intern
    Dolce - in Slot intern
    si acuma vin -
    MTV Unliemited ( 19° E )- in Smargo
    FreeXXXTV ( 5 prog -) in Smargo
    si asi dori sa mai bag un Sky D tot in Smargo
    cu care am incercat- in loc de MTV - m-am gindit ca cine stie - codificarile fac pe nebunii- dar nici pe aia de S02- nu a mers
    configuratia - CCcam
    ##############SERVER-LISTENING-PORT#################
    #SERVER LISTEN PORT : 12000
    ####################OSD#############################
    #ZAP OSD TIME : 3
    #OSD USERNAME : root
    #OSD PASSWORD : xxxxxxxxx
    #OSD PORT : 80
    ############### EXT.READER ####################
    PHOENIX READER PATH : /dev/tts/0
    SMARTCARD CLOCK FREQUENCY: /dev/tts/0 6000000
    B: /dev/tts/0 00
    CAMKEY: /dev/tts/0 00 00 00 00 00 00 00 00
    CAMDATA: /dev/tts/0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    ############# SMARGO READER ###################
    SERIAL READER : /dev/usb/tts/0 smartreader+
    SERIAL READER : /dev/usb/tts/1 smartreader+
    SERIAL READER : /dev/usb/tts/2 smartreader+
    #SERIAL READER : /dev/usb/tts/3 smartreader+
    #SERIAL READER : /dev/usb/tts/4 smartreader+
    #SERIAL READER : /dev/usb/tts/5 smartreader+
    #SERIAL READER : /dev/usb/tts/6 smartreader+
    BOXKEY: /dev/sci0 xx xx 00 11
    daca scot Smargoul cu MTV- care imi face neplaceri-
    si il bag din nou imi arata in php urmatoarele
    card reader /dev/sci0
    handled 0(0) ecms and 0(0) emms
    Nds card 1ada64
    Entitlement info
    0067 22-11-2002
    00c8 22-11-2002
    0ff3 22-11-2002
    card reader /dev/sci1
    handled 15(7) ecms and 0(0) emms
    Nds card 60318ed
    Entitlement info
    0016 30-10-2002
    00f3 30-10-2002
    00fc 30-10-2002
    00fe 30-10-2002
    card reader /dev/tts/0
    Irdeto card
    Caid 604 ACS 505
    Cardserial 4012345678T98765A (ffffff)
    Provider 00 052b29
    Provider 01 0a09f7
    card reader /dev/usb/tts/0
    Conax card
    Caid b00
    id name date
    1010 Technisat 29.07.06-28.08.06
    01.01.90-01.01.90
    2010 Preview 1 01.01.90-01.01.90
    01.01.90-01.01.90
    2011 Preview 2 01.01.90-01.01.90
    01.01.90-01.01.90
    card reader /dev/usb/tts/1
    Viaccess card
    Caid 500
    Cardserial be2759
    ident fff830 - be2759
    ident 24400 - be2759
    ident 24410 - be2759
    valid from 31-8-2009 untill 30-8-2010
    dar dupa ca: 2-4 min max. imi dispare cardul de MTV ( Conax )
    am incercat deja vers. de CCcam- 2.0.9 ; 2.0.11 ; 2.1.12
    la toate imi facela fel
    Intrebarea mai ar fi- care ar fi cel mai valabil CCcam ???
    29 Mar 2009
    Austria - TM
    Default Re: Smargo Card Reader @ König Hub
    Sal Black_Angel
    Eu am pe un Dm 800 sky D dar ai probat si in intern slot
    Eu am mai adäugat in cfg.:
    TRY ALL CHIDS : /dev/sci0
    SMARTCARD CLOCK FREQUENCY: /dev/sci0 6000000
    si nu imi face probleme folosesc CCcam 2.1.1 cu Gp
    mfg
    31 Mar 2008
    AR( RO.), KA( DE )
    treaba este ca nu cu Sloturile interne am problema -
    ci cu Smargo in Hub- deci extern legat prin USB-
    sau nu te am inteles eu bine ?
    31 Mar 2008
    AR( RO.), KA( DE )
    am adaugat in cfg.
    #SMARTCARD CLOCK FREQUENCY: /dev/ttsUSB0 3580000
    stiu acuma le am scos-
    si totusi nu vrea sa mearga
    ptr. ca
    Conax 3.57 MHz (MTV-Unlimited, ContoTV, Primacom, ...)
    Viaccess 1+2 3.57 MHz (TPS, FreeX, ...)
    deci au aceasi freq. si eu Nu am avut definat care cum -
    poate ca de aceea tot imi pica cartela de Conax ?-
    dar nici dupa ce am pus- freqventzele de citire nu merge- nici nu le-a recunoscut cel putin.
    si sa fac reboot- la ora asta !!!
    Golden Member sateros's Avatar
    02 Mar 2007
    Romania / Piatra Neamt
    Quote Originally Posted by Black_Angel View Post
    si acuma vin -
    #ZAP OSD TIME : 3
    #OSD PORT : 80
    B: /dev/tts/0 00
    Nds card 1ada64
    Entitlement info
    0067 22-11-2002
    00c8 22-11-2002
    0ff3 22-11-2002
    Nds card 60318ed
    Entitlement info
    0016 30-10-2002
    00f3 30-10-2002
    00fc 30-10-2002
    00fe 30-10-2002
    Irdeto card
    Caid 604 ACS 505
    Provider 00 052b29
    Provider 01 0a09f7
    Conax card
    Caid b00
    id name date
    01.01.90-01.01.90
    01.01.90-01.01.90
    01.01.90-01.01.90
    Viaccess card
    Caid 500
    Cardserial be2759
    eu asi incerca sa pun un overclock pe mtv cu 560000
    schimba ordinea la smargo punand unu cate unul nu toate odata eu am 7 si face figuri la ultimile 2
    13 Feb 2007
    Earth
    Post Re: Smargo Card Reader @ König Hub
    salut, o mica scapare , e vorba de 5600000 , setarea exacta .
    e vorba doar de graba a lui Romica .
    noroc .
    31 Mar 2008
    AR( RO.), KA( DE )
    @ rom3o
    ordinea a schimbat-o deja - fara succes
    eu am 7
    - ce fel de Hub folosesti tu ??
    Eu am acesta care am scris- de Firma Konig
    31 Mar 2008
    AR( RO.), KA( DE )
    am trecut- ptr. Conax- deci MTV
    SMARTCARD CLOCK FREQUENCY: /dev/ttsUSB0 5600000
    si de citeva min bune- vad ca NU a mai picat cartea-
    am sa vad miine cum o sa fie situatia
    Totusi- va Mulzumesc ptr. informatiile date -
    31 Mar 2008
    AR( RO.), KA( DE )
    a ramas si peste Noapte
    deci asta a fost configurarea- pe care eu nu am facut-o si stiuta
    31 Mar 2008
    AR( RO.), KA( DE )
    revin iarasi cu problema mea-
    Nu mai vrea sa citeasca cartea de Conax- MTV
    am setat manual Smargoul- si trecut frqventza de 5,33MHz- prima data
    dupa aceea am setat pe 3,69MHz-
    intrebarea care asi aveea acuma ce inseamna T-mode , am avut T= 0 pina acuma .
    Acuma am trecut T=1- care este dif. intre 0 si 1 ??- poate sa imi spuna asta cineva ?
    31 Mar 2008
    AR( RO.), KA( DE )
    adica m-am exprimat gresit
    mi-o arata in php- dar dupa citva timp dispare
    31 Mar 2008
    AR( RO.), KA( DE )
    poate ajuta asta pe cineva -
    T-mode stands for transmission protocol. I.o.w. the way the decive 'talks' to a smartcard.
    In short it comes down to this:
    T=0 -> character protocol
    T=1 -> block protocol
    Different cards require a different way of communication. Without getting all to technical it basically comes down to this:
    seca, conax, cryptoworks, nds, viaccess -> T=0
    Irdeto (betacrypt, Nagra? Haven't tested) -> T=1
    Parity is also of importance (parity tag in newcs.xml):
    seca, conax, cryptoworks = even
    nds, viaccess = odd
    irdeto = doesn't matter much (because T=1)
    EGT stands for 'Extra Guard Time'.
    That is the time that is needed to be added *between* consecutive characters sent to the smart card. The obvious: The lower the faster.
    The correct value may be found in the ATR ('Answer to Reset') from the card. But I wouldn't worry about it, and leave it at 0. If it -for whatever reason- won't work, the correct value can always be found back in the ATR (TC1 value).
