A aparut varianta de soft 3.61 pentru 7x1 si 792 de la magic pe super-sat.
Are urmatoarele inbunatatiri.
hello:
modify problem:
1. hungarian osd show ???????, problem.
---modify
2. multiple recall list still not working right
---modify
3.after i copy provider to fav list
i need add or delete by this fav list some channels
becose some time card no open all channel ,
(this one i want delete ) or maybe card open channel by other provider
(this one i want add to this specified favorite list)
---in set fav menu, yellow select provider type, blue key to set a fav
4.provider sorting do lots of mistake
need add more diacritics becose i have digitalb provoder
and digitalcanal provider this two receiver put like same provide
digit recognise first 5 characters
---because some limit (flash memory, data struct...),
provider name add a number after name, this number is provider name length.
5.please check mute feature if u activate mute and switch channel
command not valable for switched channel
pictog\ram with mute show on display but switched channel not quite
6. add cccam support for share
Share_Uptool Version:4.7.0x24
Use this tool to upgrade the paramers of CCcam.
CCcam format in the upgrade file:
#CCcam Setting
# status domain/ip port login password hops
CCcam: { 1 } { domain } { 10011 } { dummy } { dummy } { 2 }
Add the CCcam paramers to your TXT file, then upgrade the file.
Reboot your STB, press [MENU] on the desktop, then press [RED] button
to call the Dialog for CCcam Setting.
Make sure the paramers is the same as you upgraded just now.
If the paramers is useable, wait a few seconds, you can watch
the scrambled channel.
If everything was okay, we will improve this upgrade tools,
then you can configration the paramers in the tools in the next version.
---modify
Greeting : magic
