Dislikes:
- Rep Power
- 0
Receptor digital Technomate Combo HD 6900,are tuner dvb-t, receptioneaza si Protv HD,Are intrare de HDD, inregistreaza etc.Mai multe informatii:
MPEG4/H.264HD
Receptor Technomate Combo 6900 HD
(satelit si terestru MPEG4/H.264HD)
# Caracteristici receptie satelit: Demodulare QPSK&8PSK
# FEC DVB-S (QPSK): 1/2, 3/5, 3/4, 4/5, 5/6, 8/9, 9/10
# FEC DVB-S (8PSK): 2/3, 3/4, 3/5, 5/6, 8/9, 9/10
# Mufa intrare "F mama"
# Frecventa intrare tuner: 950 MHz- 2150 MHz
# SR: 2 - 45 Mbaud
# Transport stream: MPEG-4/H.264 HP@L4.0 1920 x 1080 interface@50Hz
# Profil nivel: MPEG-2 MP@HL, MPEG-4/AVC MP@L4
# Rata intrare: max. 81 Mbit/sec
# Dimensiune: 4:3, 16:9, Letter Box
# Rezolutie video: 1920 x 1080i, 1280 x 720p, 720 x 576i
# Decodare audio: Dolby AAC, AC-3, MPEG-1 layers 1, 2 si 3 (MP3)
# Mod audio: Mono/Stanga/Dreapta/Stereo
# Iesire component: Y/Pb/Pr tip RCA
# Conexiune scart - scart doua bucati
# Conexiune S-video si Optica Dolby Digitala 5.1 CH
# Conexiune AV tip RCA Stanga/Dreapta/Stereo
# Conexiune HDMI si RS 232C
# Conexiune USB2.0 PVR Ready cu HDD extern sau USB Flash Drive (memory stick) cu Timeshift
# Functie Record & Playback, MP3 player si imagini JPEG prin HDD exterior sau USB Flash Drive (memory stick)
# Un lector de cartela incorporat
# Doua sloturi Interfata Comuna PCMCIA
# Capacitate 10.000 de canale
# Caracteristici receptie terestra: Mufa intrare IEC 169-2 tip "F mama"
# Frecventa intrare tuner: VHF(174 - 230MHz) si UHF(470 - 862 MHz)
# Demodulare COFDM 8K
# Banda canal 7 MHz respectiv 8 MHz
# Iesire pentru TV analogic
Avind in vedere ca nu pot edita postul,Pun si pretul ca am uitat : 1250 ron
