Results 1 to 2 of 2
Thread: Vand .....Smargo Smartreader+
    Standard RSP member melting's Avatar
    19 Sep 2008
    Default Vand .....Smargo Smartreader+
    http://www.ac-sat-corner.de/shop/ima...der/smargo.jpg
    pret 200 ron....este nou
    The Smargo SmartReaderPlus incorporates an integrated USB to Serial converter, which enables the Smargo SmartReaderPlus to work with all standard Phoenix compatible Linux® and Microsoft Windows® applications.
    Powerfull ARM® 91 Thumb® Processor -High-performance 32-bit RISC Architecture -High-density 16-bit Instruction Set -64 Kbytes, organized in 512 Pages of 128 Bytes (Single Plane) -16 Kbytes Internal High-speed SRAM, Single-cycle Access at Maximum Speed -Low-power RC Oscillator, 3 to 20 MHz On-chip Oscillator and one PLL -Supports 3.20, 3.43, 3.69, 4.00, 4.36, 4.80, 5.34, 6.00, 6.86, 8.00, 9.61, 12.0 and 16.0 MHz for smartcards.
    Supported by standard drivers for Windows and Linux
    Developer guide available.
    Works on all Dreambox® Models with USB connection.
    Can be cascaded with more SmartReadersPlus using an USB Hub.
    No power supply required.
    Supports all known smartcards
    19 Sep 2008
    Default Re: Vand .....Smargo Smartreader+
    Se poate inchide!
    Vandut
