Results 1 to 15 of 30
Thread: Gemini 4.60 Non Bomb DM500 CCcam 2.1.2
    Standard RSP member eagle's Avatar
    29 Jun 2008
    Default Gemini 4.60 Non Bomb DM500 CCcam 2.1.2
    New : my new modefecation image of Gemini 4.60 Non Bomb DM500 CCcam 2.1.2 original Mod Borsalino 21.07.09
    the new: emu Cccam_2.1.2 insideand integration in the image
    #whate new
    -this image non time bomb (tested 100/100 in my clone)
    -Valid image of the original and clone dream 500s
    -new bootlogo hd inside
    -You can check program : dm500_clone_bomb_checker_v1[1].0
    -Emu: CCcam 2.1.2 inside (start with image..in blue panel withe volume button for the built-Emu )
    -please send Cccam.cfg in var/etc withe ftp
    -add grab inside in image ok screenshot fixed
    -the skins oroginale
    -add nagrab recording in image
    -Now you can change the form of a channel presntation withe button help
    -add italian Language in demarge
    -add option DVR withe help botton
    -big var naw 83% Free espace withe cccam 2.1.2
    -option pvr ok withe this modifecation image
    -Fast image to open channels with Cccam2.1.1
    -send this image withe dreamup or falshwizare
    Here are some of the screenshote for this wonderful modifectione image of Gemini 4.60 Non Bomb DM500 CCcam 2.1.2 original Mod Borsalino
    Language in demarge
    #the cccam 2.1.2 inside in image
    #the big var withe cccam 2.1.2
    #option DVR ok withe help
    #change the form of a channel presntation withe button help
    Default Re: Gemini 4.60 Non Bomb DM500 CCcam 2.1.2
    Salut , exista vreun setting pe undeva pt. a-mi arata toate prg. dintr-un "buchet" ca in imagine , adica pe 3 coloane fiindca ma cam "chinui" cu listele clasice de "n" paginii
    In schimb l-am facut sa-mi arate info suplimentar pe cccam (2.0.11) la prg. share cand iti apare si meniul de jos , apare un chenar stanga sus cu diverse info legate de cccam , in rest imaginea se misca bine per ansamblu
    24 Nov 2008
    Info suplimentar de la CCcam, apare la toate imaginile gemini.
    Ca l-ai descoperit tu la imaginea asta , nu inseamna ca celelalte versiuni nu au aceasta optiune.
    Nu asta era ideea , dar in fine....
    Oricum eu nu am mai instalat imag. geminii de la "razboiul clonelor" incoace si stiu ca la vremea respectiva cu imag. geminii nu puteai obtine info supliment. cccam fara a instala pluginul "CCcam.info 1.1"
    Daca instalai acel plugin , e altceva legat de info suplimentar cccam
    Pe mine ma intereseaza in prezent ce setari/setare trebuie facuta pt. a-ti arata pe coloane prg. dintr-un "buchet" , nu ca in prezent unde ai liste de 2-3 pag. cu prg. aferente "buchetului"
    29 Jun 2008
    Bafta si numai bine
    12 Aug 2007
    Detaliaza , ca apar coloane chiar daca nu ai cccam . Deci ...bouquets sub mai multe forme ... Unde e scriptul exact , ca am vazut asta si la alte img modificate , de ex sif
    16 Mar 2008
    i'ts works perfect withe CCcam
    thanx for your reply
    29 Jun 2008
    eu nu zis ca apar coloane numai daca ai CCcam instalat..poti avea si gbox,mbox..sau chiar nici un emulator
    si coloanele astea apar la orice imagine daca apesi>OK+Bouquets+Help
    iar in legatura cu scriptul..nu inteleg despre ce script vrei sa sti unde se afla..dar iti spun ca fiecare imagine are optiunea >afisare informati sharing
    29 Jun 2008
    Quote Originally Posted by borsalino View Post
    yes .. it is a perfect image.
    thanks for hard work!
    Quote Originally Posted by maximuss View Post
    pai in imagini ti s-a aratat ce sa faci pt a aparea pe ecran sus in stanga info despre tipul de sharing folosit : buton albastru+3 (extras/setup)+(sageata dreapta)general+ok+crypt+sageata dreapta pana apare expert +
    am spus la mai multi de setarea asta de la extra/setup +general
    unde daca pui la crypt expert + o sa afiseze sus in stanga pe ecranul teve-ului o casuta cu tot ce trebuie (asta la gemini) nu stiu la altele ca nu am cautat
    12 Aug 2007
    Nu am fost inteles . Intrebarea mea se referea la modul de afisare a buchetelor in imagini nemodificate de Borsalino. Nu ma intereseaza inf despre decodare , doar modul de asezare a listei de favorite . Vreau sa am asta la o alta imagine ce nu e gp.
    29 Jun 2008
    apasa <OK+Bouquets+Help>
    23 Jul 2007
    La mine merge direct OK -> Help. de fiecare data cand apas Help, imi arata alt mod de afisare a listei.
    21 Dec 2008
    buzau
    cred ca am mai scris pe undeva pe aici
    se deschide dcc apesi sus pe pe telecomanda apare telecomanda dream si dai clik pe tasta video ( sunt vreo 3 variante) am dm 500 gemini 4 60 si functioneaza!!! cred ca merge pe orice img
    Standard RSP member vardic's Avatar
    29 Apr 2008
    root
    am pus si eu aceasta imagine...mi se pare ok, dar are o problema (cel putin la mine), nu pot sa instalez pachetul de limba romana. nu e vorba ca n`as sti sa citesc in engleza, dar fara lb romana pe unele programe la epg, am caractere ciudate, ex. hbo comedy. pachetul in loc sa il instaleze in share/locale il pune in var/share/locale. am incercat sa copiez in share fisierele dar nu imi da voie. ceva idei?
