Results 121 to 127 of 127
Thread: AZBOX HD Emu
Threaded View
    Golden Member istvan's Avatar
    14 Feb 2007
    Baia Mare
    Default AZBOX HD Emu
    First of all, I would like all users to read Thread started by the The_Ripper for which all Thanks goes for this great work.
    The_Ripper Thread
    http://www.satdudez.org/forum/showthread.php?t=112731
    I will try just to explain on one place how to install and run native CCcam 2.1.1 ( CCcam.mips ) on AzBox HD Elite and Premium.
    First of all, download from this thread file, called azbox-cccam-2-1-1-working.rar . Unpack it on Your desktop.
    Use FileZilla FTP or any FTP manager to connect on You AzBox HD device.
    Enter in /EMU folder and create directory lib , so You will have /EMU/lib .
    Now transfer this files to that directory from just downloaded archive from this thread :
    CCcam.mipsel , ld.so.1, libc.so.6, libcrypt.so.1, libdl.so.2, libdvbapi.so, libgcc_s.so.2, libm.so.6, libnss_dns.so.2, libnss_files.so.2, libnss_hesiod.so.2, libnss_nis.so.2, libnss_nisplus.so.2, libpthread.so.1, libresolv.so.2, libstdc++.so.7 . ( It means, copy all files except file dvbapi_module from my archive ).
    Please put CHMOD 755 on all files which You copied to /EMU/lib directory !!! This is very important !!!
    Prepare Your CCcam.cfg file and copy it, inside of /EMU/lib directory.
    Now, You have to go inside of /EMU/OpenXCAS directory and there You should create new directory called dvbapiCAS, so You will have /EMU/OpenXCAS/dvbapiCAS . Put inside of that folder file called dvbapi_module and give CHMOD 755 to that file.
    Also it is important that You create inside of that /EMU/OpenXCAS/dvbapiCAS file named as openxcas.conf which should contain this :
    [module]
    name = dvbapiCAS
    daemon = dvbapi_module
    version = 1.00
    Now when all is settled You can start it.
    But keep in mind, first start CCcam and then start dvbapi_module .
    Also keep in mind that all other EMU's are dissapled in OpenXCAS panel Camd activation and priority settings.
    To start CCcam use this command :
    LD_PRELOAD=/EMU/lib/libdvbapi.so /EMU/lib/ld.so.1 --library-path /EMU/lib/ /EMU/lib/CCcam.mipsel -dv -C /EMU/lib/CCcam.cfg &
    And to start dvbapi_module
    Go inside of /EMU/OpenXCAS/dvbapiCAS
    and type this command:
    ./dvbapi_module
    The best combination is to start 2 telnet sessions to Your AzBox HD, on first session run CCcam on seccond start dvbapi_module.
    Enjoy.
    Thanks to The_Ripper .
    Automatic Running ( no need to start manually ) :
    If You want to run CCcam 2.1.1 from OpenXCAS Panel , Camd Activation and Priority .
    First You have to copy 2 files , dvbapi.sh and openxcas.conf to /EMU/OpenXCAS/dvbapiCAS .
    Also extract arhive module.rar and copy module.seq file to /EMU/OpenXCAS .
    Files are attached to this post
    Then, go in OpenXCAS Panel on Your AzBox HD, and choose Camd activation and priority and You can start and restart CCcam 2.1.1 from there as dvbapiCAS .
    Attached Files Attached Files
    RSP-TEAM
