Results 1 to 5 of 5
Thread: CCCam WebIF
    21 Post(s)
    Default CCCam WebIF
    Stiti un motiv suficient de bun ca interfata WEB a CCCam sa nu pornesca ?
    - nu merge sub cccaminfo ( error reading webpage )
    - nu merge nici linia http://192.168.1.67:16001 lansata de pe PC
    - asta se intampla pe DM800 cu Gemini 4.30 , 4.40 ...
    - o imagine proaspat instalata in ambele cazuri ...
    - cccam are configuratia standard ( default)
    - interfata de retea ... ethernet
    eu zic ca este o problema pe DM800 ... asta pentru ca pluginul cccaminfo
    da un diagnostic limpede ca lumina zilei ! intrebarea este ...de ce ?
    24 Jul 2007
    Default Re: CCCam WebIF
    REGULA 12
    Man daca folosesti Cccam impreuna cu Newcs verifica in usr/script
    sa ai linia:/usr/bin/CCcam_2.1.2 & tu poate ai /usr/bin/CCcam_2.1.2 -s &
    Bafta!
    21 Post(s)
    Asa este ... mutzamiri eterne !
    Fisierele shell erau cele descarcate de pe Gemini server ...nemodificate !
    Totusi ... luminati-ma ... ce inseamna -s ???
    Standard RSP member imeDB's Avatar
    21 Aug 2007
    Code:
    root@dm800:~# /var/bin/CCcam -h
    usage: CCcam [-d] [-C <configfile>]
            -d               run in the foreground (implies -v and -q)
            -v               be verbose
            -q               don't use syslog (use on old systems)
            -C <configfile>  use <configfile> instead of default (/var/etc/CCcam.cf)
            -f               filter on specific demux data (saves some CPU,
                             but some platforms might not handle this very well)
            -n               show network packets
            -s               disable server
            -t               show timing
            -l               disable self-learning capabilities
    root@dm800:~#
    21 Post(s)
    Daylight clear ! multzam !
