Thanks Thanks:  120
Likes Likes:  217
Page 24 of 27 FirstFirst ... 142021222324252627 LastLast
Results 346 to 360 of 401
  1. #346
    45 Post(s)
    Quote Originally Posted by satelescu View Post
    Yamal 601 @ 49 East
    Yamal 601 are un semnal bun pe zona noastra,de 45dBW.La fel ca Express-AM& la 40.0E,sau altii din aceiasi generatie,acest
    Am incercat receptia satelitului cu mai multe aplicatii si cu receptorul DM920 UHD,iar rezultatele obtinute cu acestea m-au incurajat sa fac observatiile de mai sus.Sper sa fie valabile si la voi.
    Scanarea Yamal601 de pe pozitia 49E, mi-a pus probleme cu programele T2-MI de pe 3977L15280, 4077V15280 sau 4018L5119, semnale destul de puternice dar unde vechiul meu Octagon SF8008 nu vrea sa faca lumina, cu imaginea OpenAtv 6.4
    [SATTYPE]
    1=0490
    2=YAMAL 601 @ PF 1.8m
    [DVB]
    0=40
    1=3595,V,5119,34,2 ;9.3 dB
    2=3622,V,5129,34,2 ;4.7 dB
    3=3627,H,20580,56,2 ;8.5 dB
    4=3628,V,5119,34,2 ;2.7 dB
    5=3643,V,15280,34,2 ;1.4 dB
    6=3654,H,20580,56,2 ;10.5 dB
    7=3663,V,15280,34,2 ;2.1 dB
    8=3696,V,5119,34,2 ;5.8 dB
    9=3703,V,5129,34,2 ;5.1 dB
    10=3704,H,15280,34,2 ;8.2 dB
    11=3720,V,2083,13,2 ;-0.3 dB
    12=3743,H,34070,34,1 ;-10 dB
    13=3777,V,4132,? ;4.1 dB
    14=3782,H,5119,34,2 ;6.2 dB
    15=3787,V,4060,23,2 ;7.8 dB
    16=3803,H,5129,34,2 ;9 dB
    17=3816,V,3790,? ;9.5 dB
    18=3822,H,5129,34,2 ;9.1 dB
    19=3823,V,9139,? ;7.1 dB
    20=3827,H,1832,34,4 ;4.3 dB
    21=3830,V,1499,34,1 ;7 dB
    22=3857,V,5129,34,2 ;9.9 dB
    23=3858,H,5119,34,2 ;7.1 dB
    24=3864,V,5119,34,2 ;9.7 dB
    25=3882,H,5129,34,2 ;1.8 dB
    26=3882,V,5129,34,2 ;9.2 dB
    27=3897,H,10665,34,3 ;10.3 dB
    28=3906,V,2499,56,2 ;8.9 dB
    29=3917,H,2962,34,1 ;9.9 dB
    30=3921,V,5119,34,2 ;9.6 dB
    31=3968,V,8899,? ;2.6 dB
    32=3977,H,15280,34,2 ;11.2 dB
    33=4018,H,5119,34,2 ;13.3 dB
    34=4018,V,5119,34,2 ;1.3 dB
    35=4030,H,7758,25,2 ;-10 dB
    36=4051,H,4159,? ;-10 dB
    37=4077,V,15280,34,2 ;7 dB
    38=4077,H,12820,78,2 ;-10 dB
    39=4126,V,36120,34,4 ;7.9 dB
    40=4184,H,18400,34,2 ;8 dB
  2. #347
    17 Apr 2007
    Transilvania
    13 Post(s)
    Nu inteleg se ce nu folosesti playerele dvb pentru transponderii scanati cu placa dvb pe care o ai?Nici nu trebuie sa-ti mai bati capul cu inchiderea transponderilor si vizionarea programelor tv/radio pe care i-ai gasit cu alte dispozitive,pentru ca bunul nostru coleg,exceptionalul dezvoltator de aplicatii dvb @altxro ne-a pus la dispozitie(gratuit) ultima versiune a playerului sau,AltDVB 24(#136),care a si rezolvat problema strimurilor T2_MI(PLP) incit acestea pot fi vizualizate fara probleme.
    Ilustrez mai jos modul prin care iti setezi in player acesti transponderi t2-mi,iar dupa scanarea lor vei putea vedea progamele tv sau radio pe care i-a decapsulat/decodat playerul.In general rusii folosesc acelasi pid PMT-4096 pentru astfel de transponderi,iar pentru streamuri PLP,alegi 0 sau 1,depinde de pachet/e.Dar pentru a sti ce numar trebuie ales e mai usor sa consulti lista cu transponderii respectivi pe FlySat .
    Deci:1.Scan->2.DVB Scanner(lista cu transponderi)->Edit(alegi trp)->la Decapsulation,alegi T2-MI,PiD-4096,PLP-0 sau 1,click OK si apoi scanezi.Sper sa te ajute.
    ps_@dingo31,nu stiu cind o sa mai ocup de banda C.De aceea te-as ruga sa continuu cu receptia acestei bande,iar daca spui ca n-ai obstacole fizice pina la vest,sa zicem,30.0W,atunci incearca sa acoperi tot arcul si sa ne oferi rapoarte.
    Fara sa fac caz de mine,si precum stii deja din revista InfoSatelit sau din alta parte,eu am incercat sa cuprind in rapoartele mele aproape toate pozitiile de pe toata orbita in banda C,ajungind si la 53.0W.Doar @bonou2 m-a insotit in aceasta calatorie si m-am bucurat ca nu sint singur cind am strabatut cerul.Ai putea face la fel si tu,si in acelasi timp ai si actualiza cu rapoartele tale ce-i posibil si ce nu-i posibil de receptionat cu echipamentul tau de receptie.
    Cred ca nu gresesc daca spun ca o astfel de intreprindere de unul singur pe orbita ar trebui sa fie tinta majora a fiecarui pasionat care se respecta,un fel de Meca unde trebuie sa ajunga fiecare credincios al acestui hobby.Si-mi permit sa adaug ca o metafora,ca fiecare raport al nostru de receptie este o luminita pe cer,prin care le spunem privitorilor,ca acolo sus de tot,este ceva care merita descoperit si facut cunoscut.Luminita aceea da si sens acestei pasiouni.Daca tot sintem cu "capul in nori",cum le place unora sa ne ironizeze,atunci sa le oferim in schimb "stelele"(satelitii) pe care le-am cules
  3. #348
    45 Post(s)
    Problema nu este cu playere altdvb sau smartdvb, ci cu imaginea openatv 6.4 de pe octagon. Cu dm920 nici nu am incercat, n-are rost dar cu ocatgonul sf8008 nu au fost probleme cu T2MI, asa cum s-a discutat pe acest forum https://www.sateliti.info/showthread...pe-5E-Astra-4A
    Pe 4018L5120 il deschide acum dar cel de pe 4077R15284 nu vrea sub nicio forma.
    Dar cred ca receptia T2MI este alt topic, revin cu rapoarte din banda C, multumesc pentru propunere
    ---------- Post added at 20:19 ---------- Previous post was at 19:48 ----------
    Nici nu stiu unde sa incadrez topicul, desi este vorba de receptia din banda C, cred ca mai degraba subiectul apartine de receptia T2MI
    Daca mai sus am exemplificat receptia posibila pe un transponder 4018L5120, pe 4077R15284 sau 3977L15284 unde semnalul este chiar mai puternic, de peste 11dB nu reusesc sa am lumina si nu stiu de ce?
  4. #349
    05 Feb 2008
    azi am receptionat lnb-ul c band,in weekend il pun pe 10 est [pf 2m]revin cu rapoarte de receptie
  5. #350
    17 Apr 2007
    Transilvania
    13 Post(s)
    @dingo31,Ce bine era sa fi scanat separat fiecare polaritate si apoi sa fi postat tot separat pozele cu semnalul obtinut la 4077,pe care spui ca nu-l deschide.Pe spectrumul tau semnalul la 4077,pe ambele polaritati,pare ca e puternic,daca mai iau dupa grafica,dar de fapt semnalul nu a fost inchis pe nici unul.Asta se vede din lista de trasponderi listati de Crazyscan la 49.0E dupa ce satelitul a fost scanat.
    Semnalul la 4077 V/R,15280,3/4,cu 7dB,cit e indicat pe lista generata de CS,nu-i suficient de tare incit sa poata fi inchis.Parametrii acestui transponderi sint pretentiosi,iar daca mai tinem cont de faptul ca are doua streamuri PLP,ambele cu pachete tv,atunci ar trebui ca el sa fie de cel putin 9dB,dar nici atunci nu-i sigur.Pentru o vizionare sigura si stabila pe un astfel de transponder semnalul sa fie de cel putin 10dB.
    Dar nici pe cealalta polaritate(H/L),la 4077 L,12820,7/8(probabil un transponder de Data,),semnalul nu-i bun,as zice ca e mai slab daca mai iau de acel -10dB.Asta inseamna ca este chiar sub prag,si deci n-ai sanse sa-l inchizi.Asta si mai mult influenteaza negativ semnalul pe ambele polaritati.De fapt nivelul lui general este prea slab pentru receptia normala cu antena ta.
    Eu zic ca de acum inainte ar fi de dorit sa postezi separat polaritatile cu transponderii scanati si gasiti de Crazyscan.
    Nu inteleg la ce te referi cind spui ca la ceilalti doi transponderi,cu semnal puternic,n-ai lumina.Cu ce dispozitiv ai incercat?Cu receptorul sau cu placa dvb?Daca cu placa,atunci inseamna ca n-ai editat corect parametrii in editorul lui AltDVB.
    In postarea mea anterioara la 49.0E,am ilustrat ca 3977 L l-am inchis cu AltDVB si ca playerul a gasit programe tv pe unul din strimuri PLP,cu 0! Verifica mai bine ce-ai editat la acest transponder.
    Mai important pe acest topic este sa ilustram cit mai bine receptia si mai putin cite programe receptioneaza un dispozitiv sau altul.
    Unele pachete tv la 49.0E sint codate.Trebuie verificat care sint acestea.
  6. #351
    45 Post(s)
    Quote Originally Posted by gladix View Post
    Cum se comporta noul LNB, ce rezultate ai cu antena de 2m?
    Observatiile mele pe 10E sunt destul de slabe, cu urmatoarele rezultate, (am inclus doar semnalele pe care le pot inchide):
    [SATTYPE]
    1=0100
    2=INTELSAT 37E
    [DVB]
    0=20
    1=3666,V,1004,34,4 ;0.8 dB
    2=3684,V,3047,23,3 ;5.8 dB
    3=3689,H,1332,35,2 ;6.1 dB
    4=3694,H,1909,23,2 ;4.2 dB
    5=3780,H,1084,34,2 ;6.3 dB
    6=3783,V,2250,35,2 ;10.8 dB
    7=3783,H,3086,34,2 ;5 dB
    8=3793,V,15400,23,2 ;7.3 dB
    9=3793,H,15400,23,2 ;2.9 dB
    10=3808,V,6819,34,4 ;4.8 dB
    11=3819,V,1199,45,3 ;7.1 dB
    12=3826,V,4582,56,2 ;5.8 dB
    13=3856,V,2062,23,2 ;12.5 dB
    14=3905,H,2166,34,4 ;5.7 dB
    15=3921,V,45000,34,4 ;9.3 dB
    16=3938,H,20950,34,4 ;3.9 dB
    17=3952,H,4761,14,2 ;2.5 dB
    18=3986,H,30000,34,4 ;1.9 dB
    19=4022,H,30000,34,4 ;3.6 dB
    20=4028,V,6198,23,3 ;5.3 dB
    Chad Tv, Cis Tv, in general nimic interesant, cel putin pentru mine. Pe 20E este alta viata, dar nu numai acolo.
  7. #352
    05 Feb 2008
    inca nu am reusit din lipsa timp si temperaturi mari/antena era pe 16 est si inca nu am reglat-o cum trebuie/urmatoarea fereastra e in august cind ma duc la tara
  8. #353
    19 Feb 2014
    Oradea
    Ses-6 40.5W
    Salut am reusit sa inchid 2 tp. de pe acest satelit,locatia:Oradea antena 1,5m , LNB Starsat 13 (ps m-am chinuit cateva minute sa postez acest mesaj imi tot aparea mesajul "database error" cred ca pe viitor am sa ma abtin de la alte postari...
  9. #354
    Probabil ca aveai ceva caracter special (de ex grad) in text si din aceasta cauza iti dadea eroarea.
    Daca nu stiai aici "prestam" benevol si ca useri si ca administratori si ca moderatori.
    Si in alta ordine de idei vad ca nu esti in stare sa faci o captura de imagine si ne certi pe noi ca nu rezolvam probleme mult mai complicate.
  10. #355
    19 Feb 2014
    Oradea
    a fost foarte frustrant am folosit opera/chrome/mozilla si imi dadea aceeasi eroare,cat despre calitatea pozelor asa le postez eu RAW sa zic asa,important este ca pasionatii de receptii satelitare sa vada si sa inteleaga detaliile tehnice,frecventa,nivel-putere semnal. ps:am tras si perdelele in special pentru as putea captura aceste imagini pentru voi stima
    EUTELSAT 10 Est
    Djoma tv (3783R2251) receptia la limita (8.5 db.)
  11. #356
    Vad ca ai enigma2 pe aparat, e simplu sa faci o captura din webif.
    Felicitari pt receptii.
  12. #357
    19 Feb 2014
    Oradea
    (Oradea - Antena 1,5M - LNB STARSAT 13k - Amiko 8900 imagine E2 Openpli)
    Arabsat -20E
    Express AM7 -40E
    NSS-12 -57E
  13. #358
    19 Feb 2014
    Oradea
    SES-6 40.5W
    Un singur tp inchis de pe acest satelit cu antena din dotare 3935 L 9600 (CANAL RED) restul canalelor au fost codate recent in Irdeto.
  14. #359
    19 Feb 2014
    Oradea
    Eutelsat10A - 10 Est
    Am gasit 2 frecvente destul de puternice peste 10db. pentru cei care isi doresc sa receptioneze acest satelit cu antena de 1.5m.
    Este vorba de Tele Tchad 3855 R 2062 (11db.) si Djoma 3783 R 2251 (10db.) @khalifa
    ---------- Post added at 16:54 ---------- Previous post was at 15:44 ----------
    Satelitul NSS-12 pozitia:57 Est
    Va pun la dispozitie 3 frecvente de pe acest satelit cu semnal accesibil pentru o receptie stabila cu antena de 1.5m
    3798 R 19167 pachetul BFBS codat - semnal 8.3 db
    3916 R 4167 OBN (7 db.)
    3941 L 3585 FANA (8.1 db.)
  15. #360
    19 Feb 2014
    Oradea
    Va pun la dispozitie cateva poze cu antena mea de 1,5m si LNB Starsat 13k ,scuze nu puteam face aceste poze folosind interfata Webif ;( @khalifa
