Page 17 of 30 FirstFirst ... 713141516171819202127 ... LastLast
Results 241 to 255 of 444
  1. #241
    Standard RSP member Beginner the the's Avatar
    16 Feb 2007
    Cool more...
    Hi,
    Dar pe 4177 V ai semnal? mai de mult era fta un MTV Hits Latino - parcă...
    merci.
    Free your mind!
  2. #242
    @the the
    am verificat frecventa 4177 V 30000 5/6 DVB-S2/8PSK ,
    1.din pacate azi nu am reusit sa-l receptionez nici un gram de semnal am folosit tot echipamentul din dotare receptoare,placa tbs 6925
    mentionez ca conditiile meteo nu sant favorabile de cateva zile numai ceata este la madrid
    2. toate canalele de pe frecventa mai sus-mentionata sant codificate in sistem powervu (portaleds.com)
    in data de 22-10-12 am efectuat o scanare si am publicat lista satelitului intelsat 805@55W
    in prima lista randul 18 se afla aceea frecventa 4177 V 30000 5/6 DVB-S2/8PSK pe care l-am receptionat la aceea data cu semnal destul de mare snr=9,3dB
  3. #243
    din pacate lansarea satelitului intelsat 27 sa soldat cu esec
    el urma sa-l inlocuiasca satelitul intelsat 805 aflat in serviciu in pozitia 55W
    Intelsat 27 satellite lost in launch failure
    A Ukrainian-Russian rocket carrying a US-made telecommunications satellite has plunged into the Pacific Ocean shortly after launch.
    The Zenit-3SL rocket, which was being operated from a floating pad south of the Hawaiian islands, failed 40 seconds after the lift-off at 06:56 GMT.
    The Intelsat-27 satellite was due to be positioned over the Atlantic to provide services to the Americas and Europe.
    Officials say no-one was hurt as a result of the incident.
    Staff from the Sea Launch company, which organised the launch, direct all missions from a support vessel that sits at a safe distance of about 6.5km uprange of the platform.
    The firm said it would establish a review board to determine what went wrong.
    "We are very disappointed with the outcome of the launch and offer our sincere regrets to our customer, Intelsat, and their spacecraft provider, Boeing," Kjell Karlsen, president of Sea Launch AG, said in a statement.
    "The cause of the failure is unknown, but we are evaluating it and working closely with Intelsat, Boeing, Energia Logistics Ltd and our Zenit-3SL suppliers. We will do everything reasonably possible to recover from this unexpected and unfortunate event."
    Sea Launch had not long returned from Chapter 11 bankruptcy protection.
    A spectacular rocket failure on its converted oil rig in 2007 forced the firm to restructure its finances as orders slowed and debts mounted.
    It re-emerged in 2011 and had lofted four satellites successfully from the Odyssey platform before Friday's loss.
    The rig-cum-pad and its command ship are based at Long Beach, California.
    For a mission, the pair move south to the equator at 154 degrees West Longitude.
    The 2007 failure ultimately led to the company seeking Chapter 11 protection
    An equatorial launch location gives a rocket a boost from the Earth's rotation, meaning it can lift heavier payloads into orbit.
    Sea Launch is owned now by a Russian-led consortium headed by Energia Overseas Ltd, and is headquartered in Bern, Switzerland.
    The commercial market for launching large geostationary telecommunications satellites is intensively competitive.
    It has been dominated for several years by the European Ariane rocket, operated by Arianespace, and the Russian Proton vehicle, which is sold by International Launch Services (although the latter has experienced a number of failures of its own recently).
    Once the cause of Friday's loss is identified and any necessary corrective action taken, Sea Launch will need to re-instil confidence in the market that its product is a good one.
    The Ukrainian-Russian Zenit-3SL vehicle has a generally good reliability record.
    A modified version, the Zenit-3SLB, is operated from land, flying out of the Baikonur Cosmodrome in Kazakhstan. The most recent of these launches was at the end of 2011.
    Launch contracts from the Luxembourg-based Intelsat company had been integral to Sea Launch's return to business after bankruptcy protection.
    Intelsat-27, which weighed some 6.2 tonnes at launch, was to have provided direct-to-home TV services and mobile broadband connections.
  4. #244
    24 Jun 2008
    Salut.Intelsat 22 de la 72,1 grade est a receptionat cineva?Am incercat 3732 L 30000,canalele din Kenia dar nu am reusit nici cu placuta.Harta Lyngsat west hemi arata bine da semnal nu este.Momentan am parcat la 64,2 est unde cel mai slab semnal este UBC iar canalul din Benin nu-l receptionez.Ceao.
  5. #245
    un pasionat din UK @Kveys a realizat aceasta placuta si afirma ca a crescut semnalul cu circa 2-3% polarizarea liniara pe doi sateliti aflati pe pozitia 66E-83E
    -fara aceste placute nu se receptioneaza semnal
    aici aveti pozele si textul in original:
    Little bit different subject BUT, I found out funny matter today. I made/cut thin plastic "lid" and put it Lnb. Now it give 2-3% better signals from Linear channels 66E-83E. Circular ones weakening clearly identifiable 10% or more when using normal dielectric plate (TM 5402 signal meter). Now first time picture for e.g 66E 3894H. Without that plastic no picture.
    Is it something with crosspolarity or ??
    (on pictures white one only testpiece)
    Thinking first that everyone say I´m crazy or something
    But yes, some channels got better signals than ever. 2-3% not much but enough for some needs. That 66E 3894H need 74% signal (TM 5402) to give picture. Earlier 70-72% and freezy pic sometimes. Why they use 8PSK in C-band
    But my "new channel" 76.5E Indonesian MNC Int. go down 5% (60% -> 55%). Some other channels less signal also but about 60% got little bit more. Thaicom 78.5 some freqs first time over 70%.+++
  6. #246
    Default Intelsat 903 @ 34.5° West -C band
    postul de releviziune KNR isi incepe emisia seara la ora 09.00 pm ora romaniei
    preia si difuzeaza emisiuni apartind postului tv DR1
    din pacate semnalul de receptie pe acest satelit Intelsat 903 @ 34.5° West
    este slab
    aici ma refer la frecventa 4045 L DVB-S2/QPSK MPEG-4 13500 2/3 care am reusit sa-l receptionez si vizionez in conditi bune doar cu tbs 6925 ,fara intreruperi sau macroblocuri in timp ce cu alte receptoare cu turner sensibil nu am reusit nici macar o farama de semnal
    am folosit urmatorul echipament :antena pfa 1.80m , lnb panorama er-861 , tbs 6925 , locatia madrid-spania
  7. #247
    Default Intelsat 903@34,5W
    revin cu noutati privind receptia postului Fox News channel de pe satelitul Intelsat 903@34,5W
    am receptionat semnal si ieri 20.02.2013 dar nu a facut lock fiind extrem de slab
    mentionez ca am reglat antena cat am putut de bine cu ajutorul aparatului satlook micro ,deasemenea am reglat si lnb in focar
    am incercat si cu alte lnb in banda C sa receptionez semnal mai mare , dar din pacate nu am reusit
    semnalul fiind foarte slab practic doar o mica farama receptionabila doar cu ajutorul placi tbs 6925
    nici un receptor satelit vechi/nou sau sd/hd nu a sesizat semnalul
    azi a plouat la madrid semnal fiind mai slab ca in ziua precedenta
  8. #248
    Default intelsat 805@55W in banda C
    Intelsat 805 (55.5°W)
    toate pozele si receptia sa efectuat azi 13.03.2013 ,madrid-spain
    antena pfa 1.80m,lnb panorama er-861,tbs 6925
    best regards bonou2
  9. #249
    canale tv din Peru
    Edupol TV
  10. #250
    Standard RSP member Meridian's Avatar
    01 Sep 2010
    Andromeda
    @bonou - Pe satelitul Amos situat pe 17 E ce intra in banda C?
  11. #251
    din pacate acest satelit are acoperire slaba pe spania abia receptionez ceva frecvente,desi am vizibilitate 100% spre acest satelit
  12. #252
    feed from Rome
    Maratona di Roma
    3675 V 7120 3/4 dvb-s2/8psk
  13. #253
    Default Intelsat 1R at 50.0°W in banda C
    ---------- Post added at 16:21 ---------- Previous post was at 14:36 ----------
    Intelsat 11 (IS-11) @ 43° West in banda C
    poza si receptia sa efectuat azi 17.03.2013 ,madrid-spain
    best regards bonou2
    ---------- Post added at 18:20 ---------- Previous post was at 16:21 ----------
    NSS-806 @ 40.5° West
    best regards bonou2
  14. #254
    Default NSS-10 @ 37.4° West
    NSS-10 @ 37.4° West in banda C
    poza si receptia sa efectuat azi 18.03.2013 ,madrid-spain
    best regards bonou2
  15. #255
    Default Intelsat 907 @ 27.5° West
    Intelsat 907 @ 27.5° West in banda C
    pozele si receptia sa efectuat azi 18.03.2013 ,madrid-spain
    best regards bonou2
    ---------- Post added at 17:30 ---------- Previous post was at 16:09 ----------
    SES-4 @ 22° West in banda C
    antena pfa 1.80m,lnb panorama er-861,tbs 6925 ,golden media uni-box2 hd
    best regards bonou2
