Results 1 to 3 of 3
Thread: WLanManager 0.1 beta for IPBOXHD
    02 Feb 2007
    Somewhere in Aegean Sea!!
    Default WLanManager 0.1 beta for IPBOXHD
    DOWNLOAD http://www.megaupload.com/?d=3C1BQM7N (bad) English: WLanManager 0,1 Beta for cuberevo Ipbox HD Enigma2 by ipbox2008 before proceeding installation, verify that your compatible pen wireless or with the chip zydas here Supported Zydas ZD1211 devices - Linux Wireless is compatible with the driver relative zd1211 or zd1211b (eventually, modify /etc/init.d/wlan.sh Instructions: - telnet ipdeldecoder - cd /tmp - copy with a program ftp (simil fzilla) the file wlan_ipboxHD.tar.gz in /tmp - copy with a program ftp (simil fzilla) the file inst.sh in /tmp - give permissions 755 to the file inst.sh (chmod 755 /tmp/inst.sh) - execute ./inst.sh ---> this procedure inserts in the startup file /var/etc/rcS_user.sh. By default the wlan is disabled. It goes then activated at the end from plugin WLanManager (blue key) Before activating it but you must shape the characteristics of your net wireless (at least those) (in the release successive I will put to them in the menu of the plugin). - you must edit /etc/wpa_supplicant.conf inserting: - the type of net [you as an example take the several types (wep, wpa, wpa2) and relative the row-model present in the same folder] - the name of your net wireless, - the password of access to your net wlan. - you must edit the /etc/init.d/wlan.sh: in place of these parameters IP_ADDR= 192.168.2.109 MASK= 255.255.255.0 GW= 192.168.2.1 NAMESERVER= 192.168.2.1 you put those compatible ones to your network (normally 192.168.1.10x, 255.255.255.0, 192.168.1.1) (also to these I will put them parameters in the menu… is a version BETA) - reboot decoder - gone with the blue key in the menu of the plugin and WLanManager to activate autostart - reboot for the last time and you must have the wireless working Control, if you want, that it happens in log /var/log/wlan.log Cinevacare se poate sa face un test sa vedem daca functioneaza ok!
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    21 Post(s)
    Default Re: WLanManager 0.1 beta for IPBOXHD
    astept cu interes o versiune compatibila RALink !
    Standard RSP member inocentul's Avatar
    05 Jun 2008
    Dambovita
    VuSolo 4K/DM500hd a8p modat kit Ridax/1,9m Al+Gibertini1,25m Al+1,0mAl triax+diseq10x1,Sony 49XH 9505
