I've put together a quick modification to CCcamInfoPHP which formats a blocking list specific to your peers.
This should be much shorter than the global block lists and can be updated to suit your situation as often as you like.
CCcamInfoFilter
These modifications generate a block line specific to your peers to filter "OLD" and "FAKE" cards to be added to the C: Lines in CCcam.cfg.
Instructions for use:
1.) Click the newly added "Filter" button in CCcamInfoPHP.
2.) A page will appear with a box containing a pre-formatted line.
3.) Select and copy this line and insert into CCcam.cfg at the end of every C: Line
Example:
If a C: Line is C: friend.dyn!dns.org 12000 user pass no {0:0:3} and the block line generated is ,500:20a10,500:20a20,500:20a30,d02:8c,d03:c0,d03:c 4 the C: Line becomes C: friend.dyn!dns.org 12000 user pass no {0:0:3,500:20a10,500:20a20,500:20a30,d02:8c,d03:c0 ,d03:c4}
Installation:
1.) Locate the directory for CCcamInfoPHP containing config.php. This is usually %programfiles%\CCcamInfoPHP\htdocs.
2.) Back up the file meniu.php by renaming it.
3.) Copy the modified meniu.php and filter.php to the same folder.
If you have CCcamInfoPHP running on other than the default hostort of 127.0.0.1:4001, you will have to make appropriate changes to $url in filter.php.
download : http://rapidshare.de/files/47822556/...ilter.zip.html
