iCVS-Image-dm800-20090707
Enigma = 07.07.2009
Plugins = 07.07.2009
Drivers/Modules = 07.07.2009
Second Stage Bootloader = 73
Kernel = 2.6.12-r13
- Own iCVS bootlogo's by yvessun and HD / HD-Picon Skin by kerni
- USB, USB HID, USB MON drivers in kernel
- satellites.xml - enigma² by IhaD
- incl. liba52 (only DM7025)
- Smargo USB Cardreader support FTDI_SIO and PL2303
- MHW EPG
- .recordings patch
- pmt.patch
- AIO / Grab Screenshot
- dccamd and wdog removed
- the following softcams incl. startscripts which you can find in /usr/script/ can be installed via internet:
  • CCcamd
  • CCcamd incl. NewCS
  • CCcamd incl. MPCS
  • dccamd incl. wdog
  • Evocamd
  • Evocamd incl. NewCS
  • mbox
  • mbox incl. NewCS
  • MGcamd
  • MGcamd incl. NewCS
  • rqcamd
  • SCAM
  • Camd3
  • incubusCamd
additionaly:
  • enigma2-plugin-icvs-userscripts
  • enigma2-plugin-icvs-nfs.server
  • enigma2-plugin-icvs-schaedelmeister.hd.settings.astra
  • enigma2-plugin-icvs-schaedelmeister.hd.settings.astra.hotbird
  • enigma2-plugin-icvs-schaedelmeister.settings.astra
  • enigma2-plugin-icvs-schaedelmeister.settings.astra.hotbird
  • enigma2-plugin-extensions-cccaminfo
  • enigma2-plugin-extensions-mediacenter
  • enigma2-plugin-extensions-pauli
  • enigma2-plugin-extensions-mediaplayerdeluxe
  • enigma2-plugin-extensions-permanentclock
  • enigma2-plugin-extensions-remotetv
  • enigma2-plugin-extensions-dreamexplorer
  • enigma2-plugin-extensions-webbrowser
  • enigma2-plugin-extensions-plugins2cf
  • enigma2-plugin-extensions-plugins2usb
  • enigma2-plugin-extensions-plugins2hdd
  • enigma2-plugin-extensions-logdscript
  • enigma2-plugin-extensions-swapscript
  • enigma2-plugin-systemplugins-satelliteeditor
  • enigma2-plugin-systemplugins-serviceeditor
  • HD Picon by ismail.demir
  • HD Picon 36E
  • enigma2-plugin-icvs-hd.picon.skyitalia by skywatcher
  • enigma2-plugin-icvs-hd.picon.kabeldeutschland by skywatcher
  • enigma2-plugin-icvs-hd.picon.astra3 by skywatcher
  • enigma2-plugin-skin-icvs by Kerni
  • enigma2-plugin-skin-dtv-hd
  • enigma2-plugin-skin-dreamtv-hd
  • enigma2-plugin-skin-kerni-hd1
  • enigma2-plugin-skin-nemesis.blackbox
  • enigma2-plugin-skin-nemesis.blueline
  • enigma2-plugin-skin-nemesis.blueline.extended
  • enigma2-plugin-skin-nemesis.blueline.single
  • enigma2-plugin-skin-nemesis.chromeline
  • enigma2-plugin-skin-nemesis.chromeline.cobolt
  • enigma2-plugin-skin-nemesis.flatline
  • enigma2-plugin-skin-nemesis.flatline.blue
  • enigma2-plugin-skin-nemesis.glassline
  • enigma2-plugin-skin-nemesis.greenline
  • enigma2-plugin-skin-nemesis.greenline.extended
  • enigma2-plugin-skin-nemesis.greenline.single
  • enigma2-plugin-skin-nemesis.greyline
  • enigma2-plugin-skin-nemesis.greyline.extended
  • enigma2-plugin-skin-nemesis.greyline.single
  • enigma2-plugin-skin-nemesis.shadowline
Experimental (2.6) ist set aktive for Enigma, Plugins and skins. New git is also now active (please report problems related to this)
OE Build Configuration:
BB_VERSION = "1.6.8"
OE_REVISION = "a640ebe6242427b928af07fb587df638b1ce29f7"
TARGET_ARCH = "mipsel"
TARGET_OS = "linux"
MACHINE = "dm800"
DISTRO = "opendreambox"
DISTRO_VERSION = "1.5.0"
TARGET_FPU = "soft"
Changelog E2
The image can be found in the Database ---> Dreambox - Images DM800 ---> CVS Images
