Page 3 of 3 FirstFirst 123
Results 31 to 39 of 39
Thread: Mbox Manager
  1. #31
    06 Sep 2007
    Default Re: Mbox Manager
    Pentru PC e brici si asa , dar daca se poate face sa mearga in tray ar fi super.
  2. #32
    Standard RSP member saturn's Avatar
    28 Feb 2009
    La urmatoarea versiune se va minimiza in tray.
    Pe XP am testat si e OK, sper sa mearga si pe alte sisteme de operare bine.
    DM800 + DM3800 + Inverto + ceva offset alb + CCCam
  3. #33
    28 Feb 2009
    Mbox Manager 1.73 (2009.09.11)
    - Added NewCS log auto-authentification for protected console
    - Fixed newline on edit/view files at FTPClient
    - Minimize to SystemTray
    - Telnet port editable
    - Telnet can be disabled (disable it only when the application crash on profile activation)
    With disabled Telnet:
    - the uploaded files will have the system default attribute
    - can't remove folders and change attributes with FTPClient
    - mbox control not work (start, stop, restart)
    Download
  4. #34
    28 Feb 2009
    Mbox Manager 1.74 (2009.09.12)
    - Bugfix: upload files fixed for AzBOX (include config files and add.data)
    - Added Autorefresh information ( options > autorefresh )
    - Increase ecm/pid values to 9
    Download
  5. #35
    28 Feb 2009
    Mbox Manager 1.75 (2009.09.14)
    - Added SSH support (for PC servers); new file: settings\putty_ssh.exe
    - Changes on NewCS Log colors
    - Some changes on FTPClient
    Download
  6. #36
    28 Feb 2009
    Mbox Manager 1.8 (2009.09.22)
    - Added NewCS Status command (create html file)
    - Added results counter on Card Search, showed on the title bar
    - Distinct ecm/pid values for each profiles
    (to save and use another value, not default, go to Status-Decode, change the ecm/pid value and press refresh button - right bottom corner)
    - Mbox start fix with SSH
    - Some small fixes
    Download
  7. #37
    28 Feb 2009
    Mbox Manager 1.81 (2009.10.02)
    - Added Peer Group (in Action menu): assign peers to groups (example: bad peer, good peer, friend, family)
    - Added Status filter by peer group: show or hide peers from a group
    More peers with same boxid can't be in different groups! (C lines)
    Download
  8. #38
    28 Feb 2009
    Mbox Manager 1.82 (2009.10.08)
    - Webserver Changed, the older webhosting was closed (atbhost.net)
    - Updated cccam.channelinfo file (October 2009)
    After update will work again all web functions: update checker, messages, remote status, compatible box.
    All web data losts, for using remote status (with account) you will need to register again.
    Sorry and thank you!
    Download
  9. #39
    28 Feb 2009
    Default Mbox Manager 1.9
    Mbox Manager 1.9 (2009.11.06)
    - Autorefresh position save
    - Customizable default status filter
    - Added Intruder Alert Table: count alerts when the mbox log is enabled (MBOX Log -> Intruder Alerts)
    - Added Offline peer alert function (Options -> Settings -> Peer Alert)
    Info: If this function is enabled, on data refresh will appear a list with your offile peers who are offline more than setted days. If you have some exception peers (don't want to alert you), add them to the ignore list (you can add/remove when the alert window is showed).
    Download
