Multumim mult ptr efortul depus. F. utile facilitatile. La mai mare![]()
Mbox Manager is another software which you can manage all your mbox data like peers, cards, providers, etc. This application for running needs Microsoft .Net Framework.
Mbox Manager 1.0 (2009.07.03)
Base features:
- Create one or more profiles for diffrent boxes, with autoload the default profile;
- Tables with your peers, cards and providers;
- Logging your MBox and NewCS activity;
- Edit Mbox's config files from your box;
- Build add.data file and send for execution;
- Control your mbox: Start, Stop and Restart;
- Data refresh; download temp files with the statistics from box and save history;
Some of the base functions are inspired from MCC (Mbox Control Center)
Other features:
- Peers aditional information: favorite ranking (betweeb 0 and 5), write comment, e-mail address, forum accounts for contact, percentage of our online status and local existence;
- WatchDog function at MBOX Log; everytime when you receive a CW for you, this will be write from which peer came, distance, boxid and the response time in miliseconds;
- Create graphical representation of your saved history;
- Update checking on startup: for new Mbox Manager versions and/or for new Mbox versions (you can enable or disable in settings);
- Every base page and Refresh button have a shortcut-key for faster navigation;
Download:
http://www.2shared.com/file/6548129/...anager_10.html
Cateva functii lipsesc fata de fratele sau MCC, totusi prezinta cateva facilitati noi precum cum ar fi:
- statistici despre peer (procentajul prezentelor), cu care putem vedea cat % peer-ul este online si % a avut local cand a fost online (aceste valori sunt doar orientative, calculele facundu-se din istoria salvata)
- la fiecare "refresh" de informatie se salveaza o asa numita istorie, care daca se aduna se poate reprezenta grafic evolutia anumitor parametri
- se poate da "nota" pt peer (de la 0 la 5, initial e 0), ajuta atunci cand dorim sa facem curat (uneori se intampla)
- salvarea unor comentarii pt un peer (de ex. daca a anuntat ca va fi offline 20 zile putem salva acest lucru si nu vom uita)
- salvarea datelor de contact: e-mail si/sau conturi pe diverse forumuri specificand user+adresa web
- in caz ca este setata optiunea, la pornirea programului se verifica daca a aparut o noua versiune de mbox sau de manager, ele putand fi descarcate direct din program (salvarea se face in directorul "downloads")
- oriunde am fi in program putem vedea de la cine si in cat timp a sosit CW-ul nostru, in caz ca logarea mbox si watchdog sunt activate
In prim pas e nevoie de crearea unui profil si recomandat puternic salvarea acestuia pentru a nu mai rescrie la fiecare pornire. Bifand "default" profilul se va activa automat la pornire.
Testat pe XP cu DM800 si partial pe Win7 cu DM500.
Sper sa mearga si cu alte configuratii...
Numa' bine!
DM800 + DM3800 + Inverto + ceva offset alb + CCCam
The quieter you become, the more you are able to hear...
Eu iti multumesc tie Gelule, pentru rabdarea acordata la teste![]()
Mbox Manager 1.01 (2009.07.05)
- Show values on history graphic, when the mouse moving over the graphic's zone
- Some small fixes
Download:
http://www.2shared.com/file/6571959/...nager_101.html
For update just overwrite the files.![]()
La versiunea noua cand intru la NewcsLog si dau Start programul crapa.
E facut dupa un program de la cccam?Tu l-ai modificat?
Am si doua linii C din newcamd care nu apar la peers,e adevarat ca avand aceeasi adresa dns la pornirea programului imi spune ca apar ca duplicate si le ignora.
PS: Pare totusi mai vechi,la add.data sunt linii de la mbox 0,4 care acum nu mai sunt in cwshare.
Stimate Zmeura,
nu este copiat, nici modificat si nicidecum dupa cccam. Niciodata nu l-am vazut in functiune, precum am scris si in descriere (cea in limba engleza, care stiu ca nu e tocmai corect scris gramatical, dar sper ca se intelege cat de cat) functiile de baza sunt inspirate (nu copiate) vizual din Mbox Control Center. Programul a fost scris de la zero (cu scop experimental) si e prima aplicatie pe care am scris in C#, deci pot fi anumite probleme din pacate...
In ceea ce priveste despre liniile C, adevarat ca eu am doar o singura linie, am putut testa doar dupa ceea ce am eu, am sa ma uit sa vad ce se poate face in cazul a mai multor linii. Multumesc.
Numa' bine!![]()
Apropo, add.data...
Poi acolo nu stiu ce e activ, ce nu e... eu m-am luat dupa exemplul dat in pachetul mbox (ultima versiune). Odata cu modificarea acestuia acolo, se va putea schimba si aici.
Eu intrebam ca nu stiam de ce are CCcam.channelinfo in settings,nu era o acuzatie sau ceva.In newcs pentru a imi afisa numele programului trebuie sa editez in cccam.channelinfo toate liniile 1801:002111 cu 1801:000000 deoarece mie asa mi-l detecteaza newcs-ul,dar asta e la mine,nu stiu la alt tip de card.Acum am vazut si la MCC ca de fapt este lista de la cccam,dar cu lista lui imi afiseaza bine,cu toate ca si acolo e trecut 1801:002111.Probabil a setat sa citeasca doar provid si sa nu ma ia in seama si caid.
Legat de detectarea liniilor cu aceeasi adresa dns mie imi spune "Incorect line in share.info file: (duplicate card_id)" si nu imi mai afiseaza nici una dintre linii,nici online nici offline.
Nu stiu legat de ce se intampla cu ultima versiune,de ce nu pot intra la NewCS Log.Astept,poate confirma sau infirma cineva problema.
Dap... cccam channel info, e doar pentru NewCS Log ca sa arate numele canalului cu care tocmai lucreaza. Din pacate nu am toate cartelele in local si nu pot testa fiecare situatie. Pot modifica doar in cazul in care primesc raspunsuri, si iti multumesc pt informatii.![]()
Mbox Manager 1.1 (2009.07.09)
- Added Messages. From now you can send (receive) messages to (from) your peers who is using Mbox Manager (other aplications are not compatible). If the sent message is not received in 15 days, the message will be lost
- NewCS Log fix for older .Net Framework
- More C lines error fixed
Update server moved, older versions will not find the new versions, only this one.
Download:
http://www.2shared.com/file/6627554/...anager_11.html
Mbox Manager 1.11 (2009.07.12)
- Fixes at Messages
- Main Menu icons
Download:
http://www.2shared.com/file/6661316/...nager_111.html
Mbox Manager 1.2 (2009.07.15)
- Added "Card not Found" alert function (option->settings->card alert): if you insert cards in this list, when you refresh the information, application will be alert you if one or more of these cards not found (recommended for your own/local cards)
- Added search in config files
Download:
http://www.2shared.com/file/6694960/...anager_12.html
Mbox Manager 1.3 (2009.07.17)
- New parameter on Profiles: Type (local windows or remote linux)
- Added Mbox for Windows support (for pc-dvb cards like SkyStar). For old saved profiles, only need is to select the profile type.
- For windows profile type, add NewCS Control (start, restart, stop)
- Some new provider logo
Some people ask "Why the application connect to the webserver". Simple, it is for update checking. If you don't want to use this feature, disable from options and check manually when you wish (Actions->Check for Updates).
Download:
http://www.2shared.com/file/6734116/...anager_13.html
Mbox Manager 1.4 (2009.07.24)
- Added Card Search (actions menu)
- DoubleClick on Status Table jump to Peer's Page
- Updated CCcam.channelinfo file (July 2009) - used by NewCS Log
- Added Timeline and Remove on History Graphics
Download:
http://www.2shared.com/file/6832794/...anager_14.html
Mbox Manager 1.5 (2009.08.17)
- Added new Page (Web/Network). Include a small FTP Client, Remote Status function and Homepage.
- FTP Client: download, upload, create or delete files and folders, rename and change attributes.
- Remote Status: This function can send your status in 4 types: E-mail, Account, Local and Online Web Server. If you want to see what will send, press the "Create Test Message" button.
- Homepage: Show the Mbox Manager's Homepage. The account is only for remote status (at account type).
- Some small fixes
Download:
http://www.2shared.com/file/7236906/...anager_15.html
