Dislikes:
IPBOX 91 **DGS firmware**
Aici o sa gasiti firmware pt ipbox 91HD.
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
DGS r9047 91HD
DGS r9047
DGS release r9047: ( 5/Mar/2009)
1. Added additional channel scan options for TV or Radio
2. Added repeat function in Video Player
3. Added navigation method for TTXT sub-channel
4. Display the summary when searching channel
5. Save the name of recorded file when user want to schedule in EPG
6. Fixed bug Toptext navigation with TTXT
7. Fixed bug which was CubeRevo always blocked when first boot After update
new software
8. Fixed bug which was CubeRevo-250HD and CubeRevo-mini were not updated
local timer after AC power off even with Automatic time setting
9. Fixed Alphacrypt German Language Encoding bug
10. Included some of the new plugins in CubeRevo SW version.
- Thanks as below developper for plugin.
They are arvy of Shoutcast, coOLOser and pacco of Favpip plug, kneubi of Bitrate plugin and mail,
dexter of Webepg and webepg_import, pippo9000 of epg9kdld, coOLOser of fps,
pong, sudoku, tetris, andd weather of Neumoteam.
11. Updated German language translated by Nilse
12. Removed subtitle language setting in Language Settings Menu
users control through subtitle option on RCU.
13. Modified pop up message 'Service is not available' disappears after 5~6
seconds automatically
14. Adjusted the position of Pillar box
15. Adjusted color table of DVB subtitle for some channels
Note.
1. Added Multi booting function
If you want to multi-boot, download usb_config.img in our homepage(www.dgstation.co.kr)
Then press number button on RCU which you want booting mode.
Multi-booting support as below. Official image is number 3.
1) boot from cdkroot
2) boot from USB with hdd
3) original images
4) boot from release
5) boot from USB without hdd
6) boot from SATA hdd
7) boot from flash
2. The Digifilm channel works in official CAM.
known issues : sync with audio and subtitle
artefact with premiere HD channels from satellite and cable
http://dev.dgstation.co.kr/release/cuberevo-250HD/cuberevo-250HD_r9047.051222.zip
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
DGS r9580
DGS release r9580: ( 29/May/2009)
1. Add function displaying time always on Front panel
2. Add schedule recording title name on webif
3. Fixed video player panic when spdif is off
4. Fixed slow icon on TrickPlay and FilePlay
5. Mapping blue key as check key for 250-hd in filebrowser
6. Change hdd clean process on hddinit script
7. Syunchronized sleep Mode as power_control option
8. Adjust analog output level(advanced quality of Component, Composite and S-Video)
9. Update tp information Thor0.8W and Astra 19.2E
10. Fixed many small bugs
Note.
1. Our Video player is related with CODEC, FPS(frame per second) and resolution.
As you know, even if the Filename Extension is different each other,
if the video codec is same each other, the two files work like same.
If the video file's resolution is more than 720 X 576, it will works very well.
So, we recommend below conditions.
1) resolution : 720 X 576.
2) FPS : 24, 25 and 30 fps.
3) Following video and audio codec.
Video Codec : XVID(Without GMC and Qpel), OpenDivx(less than Divx5.2), MPEG1, MPEG2, H.264
Audio Codec : MP2, MP3, AC3
When file's codec is Xvid, If you remove the GMC and Qpel, it works well.
If the file's video codec is MPEG series, it doesn't support the adjusting sync function on video player.
2. ext3 file system is slower than ext2 normally.
If you record two HD channels with ext3 at the same time, it may fail in record.
we have checked the speed as below
ext2 speed : approximately 7MB/s
ext3 speed : approximately 3MB/s
Known issues(on going).
1. Artefact with Premiere HD channels from satellite or cable.
Caution.
1. we strongly recommend to format your USB memory stick before the new image copy in it, otherwise, it may happen "ER10".
2. you should download usb_all_noboot.img into STB for improving Web interface and plugins, otherwise, the function will be the same as previous one.
http://dev.dgstation.co.kr/release/cuberevo-250HD/cuberevo-250HD_r9580.292250.zip
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
DGS r10336
This README is for CubeRevo HD model series.
This document was approved on 08/Aug/2009 by the DGSTATION.
DGS release r10336: ( 08/Aug/2009)
1. Add iCubeRevo function
: If you have the iPhone(or iPod), you can operate the STB via iPhone(or iPod).
More description is attached. The file name is "iCubeRevo_manual.pdf".
2. Add streaming player function
: Bi-directional stream transmission between STB and PC is possible.
Several protocols(UDP, RTP) are supported. And Multicast or unicast are supported.
More description is attached. The file name is "MultiRoom and Streaming manual.pdf".
3. Add multiroom service function
: Several STBs can access the Server STB and see the Server's file, mp3, video player and channels.
4. Add M3U Player function
: M3U is a format that stores multimedia playlists.
Our M3U player can play XVID(Without GMC and Qpel), MPEG1, MPEG2, H.264.
5. Improv Nordic subtitle (Canal Film HD, Silver HD, BBC HD and so on)
: For the meantime, we didn't display subtitle without PTS or with wrong PTS.
But, at present, we support these subtitle.
6. Improve the channel navigation
: You can see the faster movement at the channel, Fav, epg list and so on.
7. Fixed incorrect aspect ratio for 4:3 channels
: For the meantime, our STB displayed PillarBox, Zoom with a little distortion.
8. Fixed subtitle overlaping on Hotbird.
: Hotbird 13E 11766 V 27500 (channel name : Rai1, Rai2, Rai3)
9. Fixed ttxt subtitle page at the specific pages(775~777)
: Hotbird 13E 11919 V 27500 (channel name : Italia 1, Canale 5, Retequattro)
10. Update russian language file by uncle fedor.
11. Update german language file by Nils.
Note.
1. When multiroom service and streaming player is running, recording and pip doesn't support.
2. Our Video player is related with CODEC, FPS(frame per second) and resolution.
3. ext3 file system is slower than ext2 normally.
2. The timeshift function of multiroom will release on the next.
Caution.
http://dev.dgstation.co.kr/release/c...336.080131.zip
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
