Results 1 to 4 of 4
Thread: RSP TEAM 3.45 E2 0.50 (only for IPBOX 9000)
    02 Feb 2007
    Somewhere in Aegean Sea!!
    Default RSP TEAM 3.45 E2 0.50 (only for IPBOX 9000)
    New WEBIF by tic2000
    - RSP panel reaction speed increased
    - Intelligent EMU management:
    - each time you choose emu install, latest revision of EMU on server are checked and menu is redesigned, to include them
    - in the emu start/stop menu you will see only those that you have installed
    - you cannot re-install an emu if you don't remove it first
    - "RECORD" labeled partition is automatically mounted on /hdd/movie; the other partitions are mounted in /tmp/[device]
    - when mounting the HDD you can see only valid Linux partition
    - it supports cifs; you have to enable it in the menu and edit the configuration file (var/config/amnt.cfg) using the appropriate PC IP address,
    login username and password and the folder name you want to mount
    http://www.upload-drive.com/file/763...45-tar-gz.html
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    O zi frumoasa! Snow's Avatar
    05 Jan 2007
    Default Re: RSP TEAM 3.4.5 E2 0.5.0 (only for IPBOX 9000)
    hehehe, merge de rupe testat de mai bine de 24 de ore. stiu ca o sa ma injure unii dar incubusul nu s-a blocat in tot acest timp
    24 Jun 2009
    Default Re: RSP TEAM 3.45 E2 0.50 (only for IPBOX 9000)
    thank for great work
    but there is a problem with network ,, DHCP not worked
    also what is the username and password for FTP ?
    Regards,,
    05 Jan 2007
    root - ipbox
    dhcp work on me
