Page 1 of 7 12345 ... LastLast
Results 1 to 15 of 96
Thread: PKT Enigma 2
    02 Feb 2007
    Somewhere in Aegean Sea!!
    Default PKT Enigma 2
    Aici o sa gasesti PKT Enigma 2
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default Enigma2 0.3.1 mod PKT 3.4 ipbox 91-9xx-9000
    Enigma2 Tideglo 0.3.1 mod PKT 3.4
    release 0.3.1
    - fixed the recognition of the DVB-C tuner when is present on the slot number 2
    - fixed a bug on channels scan
    - New EMUmanager v0.6
    - New MOUNTmanager v0.6
    - Improved stability when copying the FTP
    - Auto match menu skins for SD / HD
    - Added manual installation packages (BP-> Addons-> Install packages)
    - Added messages to the VFD for the mounting of CIFS and odmontowaniu
    - Auto restart if you are GS
    - Patch for the first boot configuration
    - Patch for icons DD
    - Added Media Center 0.9.2
    - Fixed the first start (fix black screen)
    - Added NETcaster (experymentalnie)
    - Added restart the GUI from the main menu
    - GoogleMaps updated to version dated 31-03-2009]31-03-2009[/url]
    - Added support for files. Trp in MPlayer and MCenter
    - Updated to version mbox 0.4 BETA build 0023 2-nd
    IPBOX 9000
    http://www.upload-drive.com/12955/Ipbox_9000_E2_Tideglo_031_mod_PKT_34_tar_
    IPBOX 910
    http://www.upload-drive.com/12956/Ipbox_910_E2_Tideglo_031_mod_PKT_34_tar_gz
    IPBOX 900
    http://www.upload-drive.com/12958/Ipbox_900_E2_Tideglo_031_mod_PKT_34_tar_gz
    IPBOX 91
    http://www.upload-drive.com/12957/Ipbox_91_E2_Tideglo_031_mod_PKT_34_tar_gz
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default Enigma2 0.3.3 mod PKT 3.4.1 ipbox 91-9xx-9000
    E2 mod PKT 3.4.1 oparta na E2 Tideglo rev 0.3.3
    Zmiany Tideglo w stosunku do rev 0.3.1
    release 0.3.3:
    - fixed a bug on cuberevo-2000hd that caused no audio on all channels
    - fixed many bugs on channels scan (hope now it's ok on all sat)
    - first try to fix continue freezes bug after a real freeze happens
    - fixed some wrong autoresolution bug on many channels (like BBC, csat fr, etc)
    - new kernel version (2.6.17 p0041)
    - new implementation for CI cams (still needs to use upper slot for first tuner and lower slot for second tuner, this will be fixed soon),
    now CI cams should use less cpu time and should rallenty less the enigma2 execution
    Zmiany PKT w stosunku do wersji 3.4
    release 3.4.1:
    - nowy EMUmanager v 0.7
    - dodany mbox_CS - działa jako cardserver+client (testowany z kartą C+ w phoenixie na PL2303)
    - do pobrania zaktualizowane wersje softCAMów
    - poprawki plików konfiguracyjnych softCAMów - bezproblemowa współpraca newcsa (phoenix na PL2303) z moboxem, C**D3 oraz incubuscamd - testowane na kartach C+ i TNK)
    - drobne poprawki skryptów
    Po pierwszym uruchomieniu zalecany jest restart tunera
    Pozdrawiamy Polish Kathi Team
    IPBOX 91
    http://www.upload-drive.com/17124/91_PKT_3_4_1_Tideglo_E2_rev_0_3_3_tar_gz
    IPBOX 910
    http://www.upload-drive.com/17125/910_PKT_3_4_1_Tideglo_E2_rev_0_3_3_tar_gz
    IPBOX 900
    http://www.upload-drive.com/17126/900_PKT_3_4_1_Tideglo_E2_rev_0_3_3_tar_gz
    IPBOX 9000
    http://www.upload-drive.com/17127/9000_PKT_3_4_1_Tideglo_E2_rev_0_3_3_tar_gz
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default Enigma2 0.4.0 mod PKT 4.0 ipbox 91-9xx-9000
    release 0.4.0:
    - fixed boot image that was not shown every time on every TV
    - revert back to python 2.5, now you can use all enigma2 plugins for dreambox receivers wich do not have sources available and wich uses only python files
    - fixed DHCP, now is working by network menu configuration
    - added the option to enable DHCP also with nfs-server to load enigma2 (just change the kernel loading bootargs)
    - fixed the overheading bug on date/time that caused to have always a wrong time/date
    - fixed tuxtxt crashes and outputs management
    - fixed the bug that causes Timezones outside of Europe not to work, always reverts back to GMT time. All times over 3+ GMT and under GMT did not work.
    - spdif audio output on ipbox91hd/cuberevo250hd
    - fixed subtitles on dreamtv-hd skin
    - fixed aspect ratio: Pan&Scan and Pillar box settings reversed
    - fixed menu selection options that were not selectable, like 8MHz bandwith selection, or many fec options
    - fixed skin HD
    - updated skin HD
    - enabled ntfs as module
    - patch for white subtitles (i don't know if this is usefull or not, but i thought it's better to have a
    white subtitle with black background, just more viewable)
    - fixed EPG button (now you can choose wich kind of epg list to view)
    - fixed deep standby broken since 0.3.3 (do not forget to delete all wakeup timers from dgstation firmware, because if you forget it,
    then the box will restart automatically!)
    - added a Satellites configuration with all sat positions (if you think there's something missed you can still add yourself configuration files)
    - added a Terrestrial configuration to support almost all Europe providers (inserted general europe voice,
    obiously i can't add a provider for each one on the worl, so just update the file if you need a specific provider)
    - fixed some other channels scan bugs
    - fixed menu Network test on the "link connection" voice
    - fixed positioner menu crashes
    - MediaPlayer Bug with a gsod on NoneType error using subtitles
    - fixed rotor using diseqc
    - reboot of enigma2 now should works good
    - completed the kernel version p0041 adaption
    - improved a bit CI cams manager
    - fixed many memory bugs that caused the player to crash (let me know if you find more bugs on playing multimedia files)
    - ipkg support, as soon as sifteam will have a download for ipk files you will be able to download them from the browse plugin menu
    - added by default the file /var/etc/rcS_user.sh that is called on boot, so if you want to add any kind of command to be executed on start
    just put them in this file
    - patch for North American satellites (let me know if you find any kind of bugs)
    ATTENTION:
    if you are a NA user, do not forget to change in the "/etc/init.d/rcS" file this value:
    insmod $MODDIR/stmfb.ko display0=1280x720-32@50:12MAL:YUV:RGB;
    into:
    insmod $MODDIR/stmfb.ko display0=1280x720-32@60:12M:NTSC:YUV:RGB;
    This is needed to let you see the boot image and to have a full working display on TV.
    Ok that's all, i know there are some other bugs to be fixed, but i think there were a lot of improvement in this version and
    i'm working to some new drivers so i think before using the new drivers we should test all these improvements and then see if something could be better or not.
    Zmiany PKT
    - adaptation PKT mod to E2 Tideglo rev 0.4.0
    - small fixes
    IPBOX 9000
    Polish Kathi Team • Informacja
    IPBOX 900
    IPBOX 910
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default Enigma2 0.4.1 mod PKT 4.1 ipbox 91-9xx-9000
    release 0.4.1:
    - fixed a bug on setting ip and dhcp on particular cases where dhcp server is off
    changes in PKT
    - adjustment PKT mod to E2 Tideglo rev 0.4.1
    IPBOX 9000
    http://www.upload-drive.com/23148/9000_PKT_4_1_Tideglo_E2_rev_0_4_1_tar_gz_tar_gz
    IPBOX 900
    http://www.upload-drive.com/23149/900_PKT_4_1_Tideglo_E2_rev_0_4_1_tar_gz_tar_gz
    IPBOX 910
    http://www.upload-drive.com/23151/910_PKT_4_1_Tideglo_E2_rev_0_4_1_tar_gz_tar_gz
    IPBOX 91
    http://www.upload-drive.com/23152/91_PKT_4_1_Tideglo_E2_rev_0_4_1_tar_gz_tar_gz
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Exclamation Enigma2 0.5.0 mod PKT 5.0 ipbox 9xx-9000
    release 0.5.0:
    - fixed a bug on rebooting the system
    - better CI cams handling
    - support for upper and lower CI slots on the current live tuner, no more needs to put the cam only on the upper one
    - added new dvdplayer
    - support for timeshift
    - fixed alpha blending colour on images
    - updated e2 cvs to 30/05/2009
    - fixed fstab auto mounting for hdd
    - vsftpd log on file disabled by default
    - fixed a bit keymap for 250hd/200hd, audio subtitles now is mapped
    - added autoload of epg (using myepg now the file will be loaded automatically at enigma2 restarts)
    - some fixes on mediaplayer for some multimedia files
    - many fixes all around for better stability, now i think most part of drivers are done
    - updated arabic language
    I know there are still some bugs that sometimes break our balls too much, but i'm trying to solve all, just wait and hope
    the funniest thing is finding those bugs
    I would like to thank all people around Enigma2 for cuberevo, many teams are making really great stuff, i like how cuberevo
    community is going on, i think this is the spirit our box should be!
    I would like also to thank people making really great plugins, we will win all together!
    See you on next release.
    Zmiany PKT
    - zaimplementowany nowy card driver dla zintegrowanych czytników
    - przystosowanie configów softcamów do współpracy ze zintegrowanymi czytnikami kart
    - poprawka dla restartu mboxa
    - nowe bootlogo PKT - thx Crash
    - lista kanałów 15-06-2009 by djcrash
    - poprawka długich nazw przy partycjach FAT
    - automatyczna konfiguracja rozdzielczości przy wyświetlaniu bootloga
    - dostosowanie moda PKT do release 0.5.0 Tideglo
    - inne różne poprawki
    ipbox 900:
    http://www.megaupload.com/?d=GTKH6YGB
    ipbox 9000:
    http://www.megaupload.com/?d=2OSNFXJM
    ipbox 910:
    http://www.megaupload.com/?d=YWU2FSO0
    ipbox 91:
    http://www.megaupload.com/?d=WFFORHF9
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    O zi frumoasa! Snow's Avatar
    Default Re: PKT Enigma 2
    Se misca bine, dar e mai buna a lui Zildan. Ca sa aveti toati satelitii folositi lista lui zbigzbig. pkt panelul necesita setat si el pe limba engleza. Altfel chiar daca setati engleza din meniul imaginii, panelul tot in poloneza e. Nu are decat o varianta de icubus si nici macar nu e ultima
    02 Sep 2007
    Timişoara
    Varianta RSP merge si pe 910HD?
    Cu ultimul PKT nu mai merg subtitrarile la filme
    E de la TDT, am sesizat problema si o sa se rezolve.
    02 Feb 2007
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    21 Post(s)
    Din pacate am incercat sa instalez versiunea pachiuita de PKT pentru SIF 050 Flash ... si da ERR 1 dupa ce citeste stickul ...iar daca instalez direct , panelul PKT , peste SIF 050 Flash ... nu rcunoaste pannelul nici ca plugin nici pe Blue Button ! asa ca avem de a face cu un mic KICS !
    17 Jun 2009
    Default Enigma 2 and original Seca3 card NL
    Hi
    I have an orignal Seca3 on a ipbox 91hd with enigma 2.
    (by the way: I tryed NLB but had the same problem)
    Only half of the package I pay for is working. I tryed to update the card drivers 1.1 but still no success. Is there someone please who can help me with some suggestions?
    In my old receiver all of the channels open
    thanks,
    Hansjasan
    VIP PETER36's Avatar
    18 Jan 2009
    PKT mod 5.6 Tideglo rev 0.5.5
    E2 Tideglo
    release 0.5.5
    Ok
    from this release you will get a nightly build image. (this means i
    will not support stupid options like: panels, plugins and so on)
    Soon a sifteam image will be out with panel and many options enabled.
    I choose this way because i want that cuberevo community increase more! Many teams are involved in E2 now, so
    each
    one can do his choice, and sifteam images will be out with another
    image (obviously based on the same Nightly build image version)
    I will publish also how to build your own flash image, so every team can do it.
    - new bootlogo (thanks arken)
    - added bulgarian language
    - added autofs
    - added openvpn
    - added openssl library
    - added 576i to AutoResolution plugin
    - added ftpput
    - added ftpget
    - added netstat
    - "fixed" signal level on tuners
    - teletext exit with "exit" button on remote
    - fixed aspect on screen when exiting from teletext. If watching 16:9 format, it is shrinked, so looks like 16:6 or something
    - fixed positioner setup
    - fixed teletext subtitles
    - remapped few buttons
    - fix for DVB subtitles wich were not shown on some skins
    - fixed bootlogo view on SD television
    - fix the issue with stopping playback while it is paused
    - incorporated the new web interface version (04/06/2009)
    - fixed fast forward for MP3 in MediaPlayer
    - enabled forwarding the second transport stream to the decoder
    - fix avi 23.976fps/24.976fps/29.976fps
    - avi: fix audio track selection early support for redirecting in http streaming
    - added .rec extension file support
    - CI cam drivers handling should now be better
    - lot of fixes on PicturePlayer
    - lot of fixes on MediaPlayer
    - modified epgCache load to allow the load on e2 starts (now crossEpg works perfectly)
    - added estonian language
    - allowed to record/stream multiple channels from the same transponder (FTA only)
    There were a bug when a freeze happen on HD and SD channels, that bug
    showed you a full green pixel screen or an image repeating loop,
    well
    this is bug was really hard to find for me and i'm not sure i've found
    all the cases when it happens, so... let me know if it happens again.
    Many
    people asked me to add smart card drivers made by pacco, but i've not
    did them, so i will not add them like part of my images.
    They can be
    added manually by everyone and each team made the possibilty to
    download and install them, so i will not add them until
    i will make
    my own version (wich i don't know when and how it will be ready, you
    can use the pacco's version wich is good enought)
    Enjoy it! Tideglo
    Zmiany PKT w stosunku do wersji 5.5
    - nowy przebudowany BP - wersja "wielojêzykowa" - mo¿liwo¶æ ³atwego t³umaczenia na inne jêzyki
    - PKT locale EN/IT/ES/DE/PL
    - pobieranie EMU -> BP-> Wtyczki-> Przegl±darka wtyczek-> zielony przycisk
    - zaktualizowano PKT feed
    - nowe skiny i picony by Father Pio
    - nowa zaktualizowana lista kana³ów
    - nowe bootlogo
    - nowy EMUmanager 0.9.2
    - nowy MOUNTmanager 0.6.1
    - oraz wiele innych zmian i poprawek...
    Zapraszamy zainteresowane osoby do t³umaczenia BP na inne jêzyki.
    Pozdrawiamy
    Polish Kathi Team
    900 usb:
    http://www.megaupload.com/?d=QY50QGTU
    900 flash:
    http://www.megaupload.com/?d=Z11SCLHY
    910 usb:
    http://www.megaupload.com/?d=2IZXWYML
    910 flash:
    http://www.megaupload.com/?d=M4UC6QSQ
    91 usb:
    http://www.4shared.com/file/135537297/d9b1b549/mod_56_Tideglo_rev_055_91_USBtar.html
    91 flash:
    http://www.4shared.com/file/135535661/1a4a6ce4/mod_56_Tideglo_rev_055_91tar.html
    9000 usb:
    http://www.megaupload.com/?d=T95X89OF
    9000 flash:
    http://www.megaupload.com/?d=BFLJN0AD
    VIP
    23 Sep 2008
    super img PKT 5.6 vb de cea in flash!!
    am instalat pe ipbox9000,merge perfect
    emu se da jos din plugins/emu!!
