Nu foloseste nimeni dp forum card nds3 pt sky it in newcs+cccam? De exmplu e folosesc edg nemesis 4.4 si am intalat cccam2.011 newcs 1.65 aici are configul ca si cardserver 1.65 ND3 este oare posibil in aceasta configuratie sa mearga fara sa se prajeasca cardu configul arata astfel:
<?xml version="1.0"?>
<newCSconfig>
<readers name="Card Readers">
<device>
<name>lower</name>
<type>Sci</type>
<mhz>357</mhz>
<node>/dev/sci0</node>
<export>No</export>
<enabled>yes</enabled>
<blocksa>No</blocksa>
<blockua>No</blockua>
<blockga>No</blockga>
<!-- <boxkey>0000000000</boxkey> -->
<!-- <rsa>0000000000</rsa> -->
<irdeto-camkey>0000000000000000</irdeto-camkey>
<irdeto-camkey-data>00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 0000000000000000000000000000000000000000000000000000000000000</irdeto-camkey-data>
<crypto-special>No</crypto-special>
<ipk>00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 0000000000000000000000000000000000000000000000000000000000000</ipk>
<ucpk>0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000000000000000</ucpk>
<PTShandshake>No</PTShandshake>
<carddetect>Yes</carddetect>
<newcamd_port>11000</newcamd_port>
<autosid>Yes</autosid>
<Seca-PPV>no</Seca-PPV>
<pincode>0000</pincode>
<sid>
<allow>
<!-- <id>0000</id>
<id>0001</id>
<id>0002</id> -->
</allow>
<deny>
<!-- <id>0000</id>
<id>0001</id>
<id>0002</id> -->
</deny>
</sid>
<priority>round</priority>
</device>
</readers>
<radegastserver>
<enabled>no</enabled>
<port>10001</port>
<allow>
<hostname>127.0.0.1</hostname>
</allow>
</radegastserver>
<cache>
<emm>20</emm>
<ecm>-1</ecm>
</cache>
<httpd>
<server><port>3002</port><enabled>yes</enabled></server>
<user><name>newcs</name><password>newcs</password><accesslevel>admin</accesslevel></user>
</httpd>
<debug>
<password></password>
<level>normal</level>
<type>init</type>
<output>console,tcp</output>
<console_options>normal,init</console_options>
<tcp_port>3001</tcp_port>
<tcp_options>normal,init</tcp_options>
</debug>
<newcamdserver>
<name>newcs</name>
<user><name>dummy</name><password>dummy</password><au>off</au><allow>lower</allow><allow>upper</allow></user>
</newcamdserver>
</newCSconfig>
