Page 1 of 4 1234 LastLast
Results 1 to 15 of 52
Thread: AZBOX & Gigi TV
    Standard RSP member eugennico's Avatar
    03 Feb 2007
    OLT
    Default AZBOX & Gigi TV
    RCS DiGi TV Thor AU OK D+ AU OK TPS AU OK TV Globo OK Premiere AU OK TV Cabo AU OK TPS AU
    Poate verifica cineva?
    03 Feb 2007
    Default Re: AZBOX DIGI TV AU pe croteam???
    Fratilor fiti atenti... e al treilea post pe aceasta tema .... eu inteleg ca e "prima randunica" ... dar...
    Daca e adevarat atunci amicul @elrumano s-a tinut de cuvant
    03 Feb 2007
    OLT
    Fake Fake Fake
    Standard RSP member Danni_X's Avatar
    Quote Originally Posted by eugennico View Post
    Fake Fake Fake
    exact ...Fake Fake Fake !
    ...si n-are treaba cu elrumano !
    01 Apr 2007
    Quote Originally Posted by Danni_X View Post
    ba chiar @elrumano a spus ca merge pe azbox
    AZBOX ST710 - Receptor Digital Combo (Satélite y TDT) - Sintonizador de TDT de ELEVADA SENSIBILIDAD (Optimo para zonas con mala cobertura) - 1 Lector de tarjetas - POWER Scan (busqueda ciega) con total control de cualquier parametro - Audio Dolby Digital 5.1 - 150 satelites programables y 6.000 canales programables y mucho mas...
    http://www.electronicasuiza.com/es/p...os.php4?cat=74
    Oferta! 109,00 € - 18.136 PTA (IVA No Incluido)
    Premiere au
    D+ auto
    Cabo au
    Polsat au
    Tps au
    Digitv thor au
    Acesta este receiverul minune care face AU pe digi si nu numai!
    Pentru cei ce va descurcati cu limba Spaniola intrati aici si minunativa de ceea ce poate acest receiver!
    http://foros.zackyfiles.com/forumdisplay.php?f=428
    Patchuri la zi pentru acest receiver gasiti aici;
    http://www.azboxfiles.com/software.htm
    AZBOX S170 & ST710 - Update Software through a Computer
    Download
    AZBOX S170 & ST710 - How to marriage Nagra 2 Smartcards
    Download
    AZBOX S170 & ST710 - How to log EMM-ECM using Azbox
    Download
    AZBOX S170 & ST710 - Using instructions for Blocker
    Download
    AZBOX S170 & ST710- Actualizar Software Mediante un Ordenador
    Download
    AZBOX S170 & ST710 - Como casar con una tarjeta Nagra 2
    Download
    AZBOX S170 & ST710 - Como loggear EMM's Nagra con el Azbox
    Download
    AZBOX S170 & ST710 - Manual sobre las configuraciones de los blockers para tarjetas Nagra2
    AZBOX S170 & ST710 - Actualizar Software Através de um Computador
    Download
    AZBOX S170 & ST710 - Como parear o vosso cartão Nagra 2 com o Azbox
    Download
    AZBOX S170 & ST710 - Como loggear EMM's Nagra com o Azbox
    Download
    AZBOX S170 & ST710 - Manual sobre as configurações dos blockers para cartões Nagra2
    http://www.azboxfiles.com/manual.htm
    Mai multe ne poate spune elrumano!!!
    CARACTERÍSTICAS TÉCNICAS
    Totalmente Compatible con MPEG 2 / DVB, MCPC/SCPC, recepción de Banda C/KU
    Memoria para 6000 canales y 150 Satélites programables
    7 grupos de canales favoritos
    Función de organizar Canales (Satélite, Codificados, Nombre)
    Búsqueda CIEGA con un control total de los parámetros (BLIND Search)
    Función de búsqueda manual por PID
    Menú Multi Idioma (Portugués, Español, Inglés, Francés, Polaco, Alemán, Ruso, Persa, Árabe, Turco)
    Temporizador para Apagar / Encender / Grabación VCR y cambio de canal
    Soporta DiSEqC 1.2 y USALS
    Función Picture-In-Graphics
    Función Multi-Picture (Mosaico de 4, 9 o 16 imágenes)
    ZOOM In/Out
    Guía de Programas Electrónica (EPG)
    Editor de Canales y Cargador de Firmware para edición/cargar Canales y Software (disponible en nuestro Website)
    Teletexto soportado por OSD y VBI
    Total Bloqueo y control paterno
    Transferencia de datos: receptor-a-receptor con o sin TV o PC-a-receptor
    Conectividad:
    1 Entrada de LNB con salida loop through para un segundo decodificador
    2 Salidas Euroconector (TV & Vídeo)
    Modulador UHF
    Salida de Audio Digital
    Salida de Audio Izquierda y Derecha
    Interfaz RS232C
    Receptor de satelite AZBOX .El mejor y mas completo receptor dedicado a la investigacion y creado para usuario normal, con este equipo se consigue lo que otros muchos receptores linux hacen pero de forma mas sencilla e intuitiva. muchas herramientas disponibles para el estudio. A la vez se puede decir que es un todo en uno gracias a las facilidades de menu para motorizar asi como su power scan para realizar busquedas ciegas de feeds. Características generales: Totalmente Compatible con MPEG 2 / DVB, MCPC/SCPC, recepción de Banda C/KU 1 Lector de tarjetas ,Memoria para 6000 canales y 150 Satélites programables 7 grupos de canales favoritos Función de organizar Canales (Satélite, Codificados, Nombre) Búsqueda CIEGA con un control total de los parámetros (BLIND Search) Función de búsqueda manual por PID Menú Multi Idioma (Portugués, Español, Inglés, Francés, Polaco, Alemán, Ruso, Persa, Árabe, Turco) Audio Dolby Digital 5.1 Temporizador para Apagar / Encender / Grabación VCR y cambio de canal Soporta DiSEqC 1.2 y USALS Función Picture-In-Graphics Función Multi-Picture (Mosaico de 4, 9 o 16 imágenes) ZOOM In/Out Guía de Programas Electrónica (EPG) Editor de Canales y Cargador de Firmware para edición/cargar Canales y Software ,Teletexto soportado por OSD y VBI Total Bloqueo y control paterno Transferencia de datos: decodificador-a- decodificador con o sin TV o PC-a-receptor Conectividad: 1 Entrada de LNB con salida loop through para un segundo decodificador 2 Salidas Euroconector (TV & Vídeo) Modulador UHF Salida de Audio Digital Salida de Audio Izquierda y Derecha Interfaz RS232C ESPECIFICACIONES TÉCNICAS IF / Tuner 1. Frecuencia de entrada 950 MHz a 2150 MHz 2. Nivel de señal de entrada -25 a -65dBm 3. Impedancia de entrada 75 ohm nominal 4. Conector de entrada Conector F, IEC 109-24, Hembra 5. Decodificador FEC l/2, 2/3, 3/4,5/6 y 7/8 6. Demodulación QPSK 7. Símbolo 2-45 Ms/s 8. Frecuencia / Ancho de banda 480MHz / 30MHz Type 9. Aliment. LNB & Polarizacion V13 / H18, 600mA MAX. 10. Control DiSEqC Ver. 1.0 / 1.2 Compatible Decodificación de Audio / Video 1. Decodificador de Video MPEG-2 MP@ML (ISO/IEC 13818-2) 2. Input Rate 60Mbit/s Max 3. Resolución de Video 720 x 576(PAL) 4. Aspecto 4:3, 16:9 5. Decodificador de Audio MPEG-1 (ISO/IEC 11172-3) 6. Modo de Audio Mono L/R, Joint Estereo, Estereo 7. Frecuencia de Audio 32, 44.1, 48 KHz Salidas de Audio / Video 1. RCA Jack Video, Audio L/R, CVBS 2. Euroconector TV / VCR 3. S/PDIF Salida Audio Digital Audio, DOLBY DIGITAL 5.1 Procesador y Memoria 1. Procesador NEC EMMA2 166MHZ, 32 bit 2. Flash ROM 2 MByte 3. DDR-SDRAM 16 MByte Interfaz de Datos 1. Tipo de conector 9 Pin D-Sub (macho) 2. Señal RS-232C, Max. 115200Bps Fuente de Alimentación 1. Voltaje de la fuente 90VAC- 240VAC 50 Hz 2. Consumo eléctrico Max. 40W General 1. Peso Aprox. 3Kg 2. Dimensiones 300(W) x 220(D) x 65(H) mm
    Buuuun.....in primul rand va salut pe toti.....sunt nou pe forum....cu permisul lui "obywans"am intrat pe forum cu numele lui,eu nu sunt inregistrat aici,si nu ca nu vreau sa se stie ceva de mine,doar ca sunt pe prea multe foruri si daca ma credeti nu mai retin parole,nume etcetc....asa ca am sa va spun o chestie cu acest AZBOX.....
    In spania cred ca a aparut pe la sfarsitul anului 2006,aici,in Spania....prin februarie intru in contact cu un tip pe un foro de vanzari cumparari din spania....tipul era deja luat la maciuci de catre cei care vroiau sa cumpere receptorul...dar tipul nu putea sa faca fata la cati cumparatori avea....ookkkkk.....ii trimit un privat si il intreb ce si cum si ce stie sa faca rec asta.....i-mi trimite toate detaliile si in plus,spunandu-i eu ceva de dth romania digitv i-mi raspunde ca acest receptor impreuna cu o cartela care se numeste PLUTO....face auto pe digitv.....asta se intampla IN FEBRUARIE....cand inca nu aparusera azbox combo.......
    Acum,mai nou,s-ar parea ca nu mai e nevoie de aceasta cartela pluto,cu ultimul firmw continua auto pe digi,digital+,tps etcetcetc....atat pe azbox sat cat si pe noile azbox sat-terestru.
    Sper sa nu se supere pretenul meu oby ca am scris cu numele lui....dar la ora asta sunt prea lenesh sa ma inscriu pe pagina.....(cu toate ca am s-o fac)
    Un salut la toata lumea si in special lui "elrumano"
    Dinus
    Golden Member istvan's Avatar
    14 Feb 2007
    Baia Mare
    un nou firmware
    Add: Card Support for Nagra 3 Smartcards
    Fix: Card Support for Cryptoworks (CS Link and ORF)
    Add: Some BISS KeySome EPG fixes
    Add: Multifeeed support for Primiere PPV Channels
    asta da receptor....daca este adevarat, nu gluma...
    RSP-TEAM
    02 Aug 2007
    Post Re: AZBOX DIGI TV AU pe croteam???
    De fapt linkuri sunt destule desi este un receptor relativ nou pe piata - se produce in Portugalia si este in mare masura un receptor destinat pietei peninsulare . Uitati aici un link folositor http://www.foroalejandria.com/foro/f...lay.php?f=1630sau ca de obicei pe www.np-ulc.net la sectiunea receptoare .
    CE SE mai aude de acest receptor minune????ptr ca minune e ,azi 14.08.2007 a aparut un nou soft care are si ART/SHOWTIME-ul de pe 7°w.....mai mere in AUTO pe digi??????
    astept pe cei care au probat
    06 Jan 2007
    Default Re: Digi tv OK pe AzBox
    02 Aug 2007
    Nou sw. ptru AZBOX de astazi 24.08.2007:
    Fixed D+ Autoupdate (TV Cabo next day/s)
    Fixed German OSD
    Fixed Multifeed
    Some EPG Fixes for UPC Astra
    Some fixes on ISO table for Polish OSD and EPG
    Se pare ca au rezolvat destul de repede problema cu D+ baietii !
    Quote Originally Posted by cipcirip99 View Post
    Fixed German OSD
    Fixed Multifeed
    Bun,si gigi mai face sau nu AU cu ultimul soft??
    Quote Originally Posted by Obywans View Post
    pai nu a facut nici cu cel anterior....
