oscam auto install linux pc server ubuntu
Installation via putty
Code:
svn co http://streamboard.tv/svn/oscam/tags/1.10/ oscam-1.10
Code:
cd oscam-1.10
wget https://raw.github.com/manio/vdr-plugin-dvbapi/22733ee/patches/oscam-vdr.diff
patch < oscam-vdr.diff
Code:
mkdir build
cd build
cmake -DWEBIF=1 -DHAVE_DVBAPI=1 ..
make
sudo make install
Code:
svn co http://streamboard.tv/svn/oscam/trunk/ oscam-1.2
cd oscam-1.2
mkdir build
cd build
make
sudo make install
add oscam emu to /usr/local/bin atribute 755
add configuration files and place them in /usr/local/etc
auto start oscam on reboot via putty
nano /etc/crontab
# /etc/crontab: system-wide crontab
# Unlike any other crontab you don't have to run the `crontab'
# command to install the new version when you edit this file
# and files in /etc/cron.d. These files also have username fields,
# that none of the other crontabs do.
SHELL=/bin/sh
PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
# m h dom mon dow user command
17 root cd / && run-parts --report /etc/cron.hourly
25 6 * root test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily )
47 6 7 root test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.weekly )
52 6 1 root test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.monthly )
@reboot root /usr/local/bin/oscam -b
save ctrl+o
exit ctrl+x
reboot
oscam 11578 .x64 with emu
rework code ref gbox_maxecmsend
fix for gbox_max_ecm_send
change default to 5
clean up some ecm stuff
download:
