DVB-S2 Omicom S2 PCI Rev. 3
DVB-S2 Pro OMICOM S2 PCI 16/32 APSK ACM is a professional PCI card for providers, streaming, control and other custom solutions. Based on STV0900 demodulator.
Support 8PSK/QPSK/16APSK/32APSK modulation.
Support really high Symbol Rates:
DVB-S2 QPSK up to 63 Msps Max.
DVB-S2 16/32 PSK up to 63 Msps Max.
Omicom DVB-S2 Pro PCI card is ready to recieve any signal from satellite including modern experimental and reserved for telco data transponders. It can be used in DVB-IP gateways, Home Theaters, satellite data and other solutions.
You can also use our Omicom DVB-S2 Pro card in PCIe slot. You just need to get the PCI to PCIe adapter as an option. Adapter can be installed in any PCIe slot with 1x lane, 4x, 8x and 16x. And it works fine without any additional drivers with Windows XP, 2003, Vista, 7, 8 and Linux.
PCI to PCIe adapter
This adapter is well-tested and works fine with our Omicom DVB-S2 Pro PCI card!
Email us to order now Omicom DVB-S2 Pro PCI, PCI to PCIe adapter is optional [Only registered and activated users can see links. Click Here To Register...].
Main Features:
1. DVB-S2/S Transponders Receiving
2. 8PSK/QPSK/16APSK/32APSK mode
3. Support Multiple Transport Stream
4. Support Generic Stream capture
5. Transponders blind scan
6. Up to 140 Mbit/s channel bit rate capture
7. High-speed Data download via Satellite
8. Windows 7, Windows 7 Media Center, Windows XP, Linux compatible
9. Supported by DVBDream, DVBViewer, DVBlogic, ProgDVB, Skynet, TSreader…
DVB-S2 Pro OMICOM S2 PCI 16/32 APSK ACM with STV0900 BAB Revision demodulator specification
1. Receiving Frequency: 925~2175 MHz Tuning Range
2. Input level: -69~ -23dBm
3. DVB-S2/DVB-S DIRECTV 8PSK QPSK 16APSK 32APSK
4. 8PSK /QPSK/16APSK/32APSK mode
5. Symbol Rates: DVB-S2 QPSK: 63 Msps Max. DVB- S2 16/32 PSK: 63 Msps Max
6. Code Rates: DVB-S2 QPSK: 1/4,1/3,2/5,1/2,3/5,2/3,3/4,4/5,5/6,8/9,8/10 DVB-S2 8PSK: 3/5,2/3,3/4,5/6,8/9,9/10 16APSK: 2/3,3/4,4/5,5/6,8/9,9/10 32APSK: 3/4,4/5,5/6,8/9,9/10
7. DiSEqC 1.2 compliant
Software compatible:
SAT TV - WMS7, DVBLink TvSource, ProgDVB, DVBDream, AltDVB, BlazeDTV, SichboPVR.
SAT Inernet - BDADataEx, Omicom-Data, StreamReaderEx-BDA
Drivers for DVB-S2 PCI OMICOM rev.3 card (v.2012 / 05/25)
OMICOM-BDA-V1_3_525_0.zip
hxxp://www.skymaster.com.ua/rus/sputnikinet/files/
thank you for our suport to @anas.tasia, @Rentner
va multumesc pentru ajutorul acordat @anas.tasia, @Rentner
