Salut tuturora.
Deschid acest topic de discuti,fapt care asa am putea sti ca gasim ceva la Uploud (softcam,key,emulatori,etc) pentru receptorul nostru(vostru).
Salut tuturora.
eu asa ceva am , si sunt madru de el
si merge tot ce se poate vedea:tv:
Asta este al meu....
Shot at 2007-06-27
Detali:
Equipped with the latest technology and design, the CI-8100 PVR is a Personal Video Recorder and Digital Satellite Receiver with 2Common Interface Slots.
As a PVR, CI-8100 PVR utilizes the loaded software functions with hard disk drive. This allows for assorted trick play, diverse formats of recording, and recorded services playback, all through time shift recording function.
As a digital satellite receiver, it can receive encrypted services via common interface module, as well as FTA broadcasts. Viewers can now enjoy both outstanding stability and comfort in this affordable satellite receiver loaded with the very best technology HUMAX can offer. The simple installation and operation, user-friendly three-dimensional OSD, highest quality audio output with Dolby Digital Audio, and advanced video clarity made for TV and VCR are all designed to enrich the viewer experience.
- 160GB harddisk
- 2x Common Interface slots
- MPEG-II Digital & Fully DVB Compliant
- Max. 5000 channels receivable
- Channel list mode in All, Favorite, Satellite, Scrambled
- Finding channels by name
- 5 Favorite channel groups (Max. 100 channels in each group)
- Channel search in automatic, manual and network search
- Channel sorting by Channel Number, Alphabet, FTA
- Installation Wizard helps easy and automatic installation step by step
- DiSEqC version 1.0, 1.2 USALS compliant (2.0 compatible)
- Timer Setting Supports automatic Turn-On and Off daily
- Subtitle supports EBU and DVB subtitle
- Teletext Supports DVB ETS300472 by VBI insertion
- Dolby Digital Audio Output (optical)
- Auto language selection of program for Audio language with user setting in menu
- PAL/NTSC In and Out
- Video format in 4:3, 16:9 and letterbox
- English, German and more than 10 European and Asian OSD languages
- Parental control with block on system, all channels and programs by age limitation
- Software Upgrade via OTA and serial connection (RS - 232C)
- User-friendly EPG and Information Plate
- Extended information shows the full program information
- 2x SCART (TV/VCR)
- 1x RCA Video
- 2x RCA Audio (L/R)
- Momentous pause and play with button during A/V watching
- Fast Forward & Fast Rewind in various speeds
- Jump to live program
- Slow Motion to Forward & Backward in various speeds
- Automatic rewind for a time and play with button (Instant Replay)
- Time shift recording for 60 to 90 Minutes
- Recording live channels and stop
- Recording reservation in EPG information
- Recording reservation with setting start time and duration
- Play back of recorded services with Trick play modes
- Size (WxHxD): 370x60x262mm
- Weight: 3.5kg
- Remote control is included in delivery
Iar asta este urmatorul.Este o achizitie mai veche dar este bun.Diseq-ul sant foarte multumit de el,cate odata il folosesc la rotarea parabolici(pozitioner).C.I.nu are preferinte cum sant la alte receptoare de nu accepta Cam-urile sau nu citeste softul din cam.
Shot at 2007-06-26
# DVB-S2 and DVB-S compliant
# MPEG-2 MP@HL Video Decoder
# MPEG-4 AVC/H.264 HP@L4 Video Decoder
# Multi-format Audio Decoder
# High Definition and Standard Definition
# DVB Common Interface (2 slot) support
# HDMI with HDCP
# Format resolution: 1080i, 720p, 576p
# DiseqC 1.0, 1.2, USALS
# Automatic software updating
# Programs may be sorted numerically, alphabetically, by TV or radio, satellite group, or FTA (free-to-air, freely receivable broadcasts)
# Timer function (coupled with EPG) for pre-programmed switching on and off, among other functions
# Adheres to laws protecting minors
# Expanded display with complete program information
# Parental control function (blocking system or individual channels)
# Sorting programs into individualized categories
# Simple program search
# Common Interface
Two Common Interface (CI) slots are available for Pay-TV channels.
# High definition
HDTV stands for High Definition Television, the high-resolution television of the future
(MPEG-4 AVC/H.264 and MPEG2).
MPEG4/H.264 is an improved compression process for digital television and HDTV, a successor of MPEG2.
1080i and 720p HDTV video formats: "p" stands for "progressive" and "i" for "interlaced" images.
# Standard definition
SDTV stands for Standard Definition Television, which is the basic PAL signal.
The HDCI-2000 uses the latest image enhancement technology to make even SDTV programs appear sharper than ever, using a HDMI or YUV output.
# Dolby digital sound
The HDCI-2000 comes equipped with an optical digital output for extremely realistic spatial sound.
[Only registered and activated users can see links. Click Here To Register...] Despre Echosmart cred ca stie toata lumea ce poate....
Deocamdata atat:D :cheers:
As vrea sa aflu si eu daca la alte receptoare (cele cu displey mic)se intimpla?si cum se poate rezolva?.Eu am incercat acuma sa ai fac un upgrade via OTA dar imi vine mesaj pe ecranul tv ca nu sant actuale.Iar pe siteul oficial al receptorului am gasit,si doresc sal fac eu.Problema este urmatoare.Displeyul este mic de dimensiune si singurele mesaje care iti apar este ;Stand By,Signal,On,Off.Quote:
Originally Posted by Turku [Only registered and activated users can see links. Click Here To Register...]
Cand fac upgrade cum fac sa imi dau seama de mesajul ErsE,FuSE,crc,donE,boot,daca nu imi apare pe displey,fapt care cum am specificat imi vin doar mesajele enumerate mai sus.
Stau de o ora si nu imi apare nimicadin mesajele astea.
Parerea mea este ca din 1145 de membri doar 3 au receptoare satelitare.Restul ce ar avea ?
:oops: :oops: :oops: :oops:
Destule,nu cred ca ar fi spatiu pentru ele,in principiu cei ce au in sange acest hobby au cel putin 5modele asa ca....iar la majoritatea sunt descrise in semnatura!!
[Only registered and activated users can see links. Click Here To Register...] Asta este al meu Goldbox Pioneer1530(fost Sky Italia)
Eu am un Metronic,Sat+,Dreambox500 S,si un SkyStar 2 .Aaaa ,am uitat si de Digi scuzama.Quote:
Stiu ca tu ai destule la vanzare.Quote:
Echosmart790
Xsat410
Tevion DFA2004
Amstrad Drx 500 I
SEG DSR 1050
Intertronic SR 810(analog)
Echosmart 770,Echosmart690 (foarte multumit de ambele)si un Opentel 3000DCS(Max tv)care nu stie decit max tv si fta (deocamdata...)
deocamdata am doua Coship-uri Dolce (de fapt NDS :)) )
marti-miercuri astept saimi ajunga 790'ul.
abia astept
STRONG 6355
DM 500
HS - 1160
STRONG 4355
si mi-au mai trecut prin mana
AMSTRAD (analog)
SEG (analog)
STRONG 4401
OPENTEL 4000
ECHOLITE 790-800-890
DM7020
DM7025
SRT 4125 -4155
ECHOSTAR 2110
SUCCES
si altele ca nu mai stiu pe de rost!:lol:
Dupa cum vad pana acum eu sunt cel mai tare... am un SkyStar 2 rev 2.6D :D are si telecomanda ! :D
ss2 nu e receptor :) iar daca e sa o punem am si deaia :)
Un amarat de ECHOLITE790!!!!!!!!
