Enigma 2 RSP TEAM 1.2 ipbox 9000HD
ENIGMA 2 for ipbox cuberevo (ipbox 9000HD rel1 and rel2)
Bassed on SIFTeam release 0.2.0
RSP panel
New WEBIF by tic2000
Intelligent EMU management:
- at every emu install it checks on the server and if there is a new version you can install it
- in the emu start/stop menu you can see only what you have installed
- you can't install an emu if you don't remove it previously (for those already installed of course)
- the partition with the label "RECORD" is automatically mounted on /hdd/movie; the other partition are mounted in /tmp/[device]
- when mounting the HDD you can see only valid Linux partition
- it supports cifs; you have to enable it in the menu and edit the configuration file (var/config/amnt.cfg) with the ip of the pc,
user and password used to login and the folder name you want mounted.
- Settings update from menu (RSP>Installer>Update Seting> )
Multumim pe @zildan care e inima la tot asta project!!!!
Webif de la tic2000
Re: Enigma 2 RSP TEAM 1.2 ipbox 9000HD
:bravo::bravo::bravo::please::please::please:
@zildan is the god of RSP TEAM for Enigma 2!!!!!!
:cheers:
zildan,From espaƱa, we are several(different) that we use yours crux, great work! Already we were touching New other one version for los900, y910. I repeat congratulations and great work :):drinks::bravo::bravo:
can you please advise:
1. how to install MPCS which disappeared from menu
2. how to enter to the file mode (envelope button does not work anymore)
for when will go out rps team enigma2 for 900hd??
Va rog daca se poate sa postati un "How to" pentru instalarea imaginii in flash sau pe stick pentru IPBOX-9000HD.
Sunt nou in domeniu (IPBOX), insa posed DM-7000s printre primele aparute, asa ca stiu cate ceva...
multumesc mult
este aici [Only registered and activated users can see links. Click Here To Register...] dar va pica mainile daca cautati, mai degraba vezi 100 de posturi cum se fac chestii care sunt deja explicate prin forum. :)
multumesc pentru raspunsul prompt si amabil, insa acel how to l-am citit si incercat, insa este facut special pt 900 si 910, nu am reusit sa trec peste pasul 1c si m-am gandit daca nu cumva trebuie un config special pt 9000.
imi cer scuze, insa sunt incepator in ipbox
mbine ;)
imi adun memoriile si iti voi zice cum fac eu, totul din telnet si consola.
este aici
rog raspunsuri mai amabile, chiar daca cineva are dreptate sau nu.
cathedral e in bransa de destul de mult timp si nu merita sa fie tratat astfel, iar eu ma voi gandi mai bine data viitoare daca recomand prietenilor sa lase rdi si sa caute ajutor pe forumurile competente, ca vad ca iar am picat la mijloc :|
numai bine
@cathedral:
iti zic cum am eu, cu hdd dar e tot aia si cu stick, daca nu ai hdd inauntru. daca totusi ai hdd e mai bine sa-l folosesti, e mai rapid decat orice stick. ;)
0. se baga stick in stb.
1. telnet ip_box si te logezi.
2. se demonteaza partitia "umount -f /dev/sda2" asta in caz ca e montata se verifica cu "df -h"
3. "fdisk /dev/sda"
4. "p" vezi cate partitii ai pe stick
5. le stergi pe toate "d" [enter] "1" [enter] si tot asa pana stergi toate partitiile (sunt de la 1 la 4 cele primare)
6. te apuci sa creezi partitiile de care ai nevoie, "n"[enter]"p"[enter]"1"[enter][enter]"+500M"[enter] si ai creat prima partitie :)
7. si tot asa creezi si partitia 2 "n"[enter]"p"[enter]"2"[enter][enter]"+500M"[enter]
8. partitia 3 "n"[enter]"p"[enter]"3"[enter][enter]"+500M"[enter]
9. partitia 4 "n"[enter]"p"[enter][enter][enter] (aici nu mai zici numarul partitiei deoarece pot fi maxim 4 partitii primare)
10. "p" unde ar trebui sa-ti arate ceva de genul:
Disk /dev/sda: 2063 MB, 2063597056 bytes
64 heads, 62 sectors/track, 1015 cylinders
Units = cylinders of 3968 * 512 = 2031616 bytes
Disk identifier: 0x027e67c3
Device Boot Start End Blocks Id System
/dev/sda1 1 265 525729 83 Linux
/dev/sda2 266 524 513856 83 Linux
/dev/sda3 525 783 513856 83 Linux
/dev/sda4 784 1015 460288 83 Linux
11. eu folosesc prima partitie ca si swap, e bine sa-l ai, astfel trebuie sa face tipul primei partitii linux swap "t"[enter]"1"[enter]"82"[enter] daca mai dai odata "p" o sa arate astfel:
/dev/sda1 1 265 525729 82 Linux swap / Solaris
12. acum scri tabela de partitii in mbr "w"[enter] in acelasi timp va iesi din fdisk dupa ce scrie tabela de partitii:
Command (m for help): w
The partition table has been altered!
Calling ioctl() to re-read partition table.
Syncing disks.
13: acum le formatam:
- "mkswap /dev/sda1"[enter]
- "mkfs.ext3 -b 4096 /dev/sda2"[enter]
- "mkfs.ext3 -b 4096 /dev/sda3"[enter]
- "mkfs.ext3 -b 4096 /dev/sda4"[enter]
14. acum trebuie sa le punem label, altfel imaginea din flash le va sterge si crea cum vrea el, nu vrei asta, crede-ma :)
- "e2label /dev/sda2 ext3"[enter]
- "e2label /dev/sda3 ext3"[enter]
- "e2label /dev/sda4 ext3"[enter]
15. pui enigma pe partitia 3 sa zicem:
- "mount /dev/sda3 /mnt/usb/"[enter]
16. iei clientul preferat de ftp, si pui arhiva cu Enigma in /mnt/usb/
17. "cd /mnt/usb/"[enter]
18. "tar xzvf release_031_cuberevo_mini2.tar.gz"[enter] asta daca pui enigma de la sif, altfel cum ii zice la arhiva ta, astepti pana termina de dezarhivat, "sync" ca sa scrie din cache.
19. "cd /"[enter] "umount /dev/sda3"[enter]
20. inainte asigura-te ca ai un cablu null modem intre PC si ipbox si ai deschis putty pe consola "reboot -f" iar cand apare ca booteaza apesi "ctrl+z" ca sa intrerupi procesul de bootare.
21. schimbi cativa parametri de bootare:
setenv menu_1 'front_puts BOOT-FLASH;setenv bootargs "console=ttyAS1,115200 panic=3 root=/dev/mtdblock3 bigphysarea=1500 quiet";setenv bootcmd "bootm a0060000";saveenv;boot'
setenv menu_2 'front_puts BOOT-SATA-part-1;setenv ipaddr 192.168.11.4;setenv gateway 192.168.11.1;setenv netmask 255.255.255.0;setenv bootide "run bootargside;ide reset;ext2load ide 0:3 a5ff0000 boot/uImage;bootm a5ff0000";setenv bootargside "setenv bootargs console=ttyAS1,115200 panic=3 root=/dev/sda3 rw rootfstype=ext3 init=/bin/devinit ip=$ipaddr::$gateway:$netmask mem=128m coprocessor_mem=4m@0x10000000,4m@0x10400000";setenv bootcmd "run bootide";saveenv;boot'
setenv menu_3 'front_puts BOOT-SATA-part-2;setenv ipaddr 192.168.11.4;setenv gateway 192.168.11.1;setenv netmask 255.255.255.0;setenv bootide "run bootargside;ide reset;ext2load ide 0:4 a5ff0000 boot/uImage;bootm a5ff0000";setenv bootargside "setenv bootargs console=ttyAS1,115200 panic=3 root=/dev/sda4 rw rootfstype=ext3 init=/bin/devinit ip=$ipaddr::$gateway:$netmask mem=128m coprocessor_mem=4m@0x10000000,4m@0x10400000";setenv bootcmd "run bootide";saveenv;boot'
saveenv
power off, power on si astfel daca apesi butonul 1 la boot va porni din flash, daca apesi butonul 2 la boot va porni enigma de pe partitia 3 iar daca apesi pe butonul 3 va porni enigma de pe partitia 4.
schimba ip-urile dupa nevoile tale.
astept intrebarile ;)
nu pot edita postul prin proxy. am pus comenzile intre " ca sa le diferentiezi, [enter] inseamna exact apasarea tastei enter. ;)
In sfarsit un "How to"si pentru cei care nu stiu Linux!
Multumesc @amorak !
What is user and password for this E2 img. When I try to enter in E2, with FTP, I can*t, cos all user and passwords I tried are refused!!?
I tried with (root ipbox) and (root sifteam) but didn*t go!
Rgs!
Trapper
hello, you have thought about taking a new enigma, or an update? thanks and greetings from Spain. :):wellcome::cheers:
