are cineva acest receptor ? se poate "jiji"-tiza :) ? unde as gasii soft pentru el ;ma ajuta si pe mine cineva ?
e asta de aici?
stai ca ma interesez
da man acest recepor poate ceva ?
pentru inceput:
revin cu amanunte
Receptorul este foarte nou pe piata. Ca si procesor are la baza 3329e, astfel incat softurile de [Only registered and activated users can see links. Click Here To Register...][Only registered and activated users can see links. Click Here To Register...]
Are iesire hdmi, insa atentie: receptorul nu este unul hd
Cam Diablo merge?Mersi
Desigur, vine echipat si cu un ci. Uite mai jos specificatiile
Main Features:*
2 Card Reader slots (Conax embedded)
1 CI Slot for CAM modules
Colour: BLACK*
Multi Pictures
Zoom in
Fully Compliant with DVB-S and MPEG2
Plug & Play Self Installing Programmes by Automatic Scaning
High sensitivity Tuner
QPSK Demodulation, Symbol Rate: 2-45Ms/s
8000 programmable Channels, 6000 transponders
Software update by USB and RS-232 Serial port
PAL/NTSC convertible
Aspect ratio adjustment 4:3, 16:9
DISEqC 1.0; 1.2 & USUALS
Multi-language OSD
7-days EPG*
Video/Audio outputs:
- HDMI
- RS232 Serial port
- Modulator
- YPbPr component
- 2x SCART
- RCA video RCA audio L+R out
- SPDIF optical
- USB 2.0 up to 2TB HDD*
General*
System standard: Fully MPEGII/DVB Compliant
Channel Storage: 8000 TV and Radio Channels
Input Frequency: 950~2150Mhz
RF Input level: -65~-25dBm
LNB Control: DiSEqC1.0/1.2
LNB Power:13V/18V (Max, 500mA)
LNB tone switch: 22KHZ
Waveform: QPSK (SCPC, MCPC capable)
Symbol rate: 2~45Mbps
A/V Mode*
Video format: MPEG-II Main profile/Main level
Audio format: MPEG-II layer I&II
Aspect Ratio: 16:9, 4:3
Audio sampling rate: 32,44.1, 48kHz
Audio Type: Mono Dual Mono, Stereo, Joint stereo
Graphic display: 720x576(PAL), 720x480(NTSC)
Microprocessor & Memories*
Processor: 200 MIPS based CPU
RAM: 64Mbits
FLASH: 16Mbits
Power & Environment Condition*
Supply Voltage: Free Voltage (100~250V AC, 50/60Hz)
Supply Power: Max.15 W (with 1 single LNB)
Operating temp: 5C~45C
Physical Specification*
LED display: 4Digits
Weight: 2.0Kg
Dimensions: 300(W) x 235(D) x 65(H)mm
Connection*
Satellite IF input: F-type (Digital)
Satellite IF loop out: 950-2150MHz
RS232: 9 way D Rs232 DCE serial port
Scart: TV / VCR (Optional)
Video: Composite Video I/O, RGB, CVBS
Audio: Audio left, Audio right
Control Output (Optional): 0/12V out
Modulator (Optional): UHF CH 21-69 Adjustable
S/PDIF (Optional): Digital Optical Audio Output
Receptorul e similar cu receptor YUMATU IQ PVR
vin cu noi amanunte:
Dupa cum se stie, receptorul vine cu doua cititoare de card si un slot ci (pentru folosirea unui cam). Este evidenta diferenta de imagine pe hdmi. Softul aferent se gaseste in linkul de mai sus.*
Se pote face captura video atat pe un stick, cat si pe un hdd extern conectat prin usb.*
Subtitrarea dvb merge fara probleme, chiar si pe inregistrare.*
Este un receptor de dimensiuni reduse 25/17 cm, dar foarte bine ventilat mentinandu-se rece pe tot parcursul functionarii.*
Are toate calitatile receptoarele din clasa globo-opticum.
Prezentare:
Interior -tunner-:
Meniu:
<A href="http://imageshack.us" target="_blank">[Only registered and activated users can see links. Click Here To Register...]
Stie si protocolul usals
Cu multumiri pentru asistenta tehnica lui sorin8m!:drinks:
Cu placere. Despre opticum, globo, yumatu si alte clone de genul acesta ma puteti intreba liber ca ma joc zilnic cu ele :)
Chiar daca nu gasim nimica, fac eu rost de la prieteni mei din macedonia :)
Cartela vine introdusa cu cip-ul in sus! Ca si pont :) pentru cei care au de-a face pentru prima data cu acest tip de receptor.
Cartela de Focus si cea de Dolce mere ?Diablo cam poti incerca daca mere?Multam mult pentru timp si raspunsuri.Quote:
Cartela de focus merge si diablo. Dolce nu stiu.
atentie regula 12 *se lasa cu avertisment
Am si un 7100cr o sa incerc la el.Mersi
cat stiu eu Opticum 7100CR are procesor 5119.
Opticum 7300 CI2CX Plus are procesor 3329E
Va multumesc mult pentru informatii sa speram ca merge cu softul de pe truman o sa testez si o sa postez reusita :) sau esecul :( aici
fw for 7300
Opticum7300_CI2CX_1.0.48_EMU
Registration required :agresiv:
Buna. Sunt nou aici. Am un receiver YUMATU IQ PVR , dotat cu usb 0.2 si de cate ori incerc sa introduc keyle pentru yumatu iq aparute pe [Only registered and activated users can see links. Click Here To Register...] receiverul nu recunoaste extensia .bin. Am inteles ca YUMATU IQ este compatibil cu seria Opticum 4000A - Globo 7xxxA, am incercat keyle de pe site ul Truman cat si de pe alte site uri si acelasi rezultat (inclusiv cu alte extensii). Efectiv cand bag sticul in USB ul receiverului (dupa ce il recunoaste), fisierul cu keyle actualizat avand extensia .bin nu il pot updata. Ma poate ajuta cineva va rog, eventual pas cu pas sa nu gresesc la instalare.Am incercat si cu extensia .abs si imi da un mesaj de genul "BootLoader version mismatch, please check!". Ce inseamna asta? Imi trebuie un program aditional? Sau ceva de genul asta? Multumesc mult.
Este model ID 3329E_PVR
S/W VERSIUNE 04000100_1.0.42 EMU
VERSIUNE H/W ALI -29E_VER 2.2
LOADER VERSION M3329 1.1.1
LATEST UPDATE NOV 07.2008
STB SN ALI 3329E_ALI 29E-VER 2.2_YUMATU
STB ID 04000100:00004f
VERSIUNE 1.0.42 EMU
multumesc grantec multumesc RSP forum am reusit sa fac cont aici si am descarcat fisierul minune Opticum 7300 CI2CX PLUS functioneazaaa e jiji-tizat ;)
