Code:
If you want to test different experimental keys, try vPlug 2.4.3 (install + import its keys file)
Now you can enter via2.6 keys (if any!) yourself without updating .mdl files.
vPlug 2.4.2
Via2.6 OK!
December 16, 2009 – 1:40 pm-Added Viaccess 2.6 support, 11727 HB 13E.
How to use it:
0- install the last vPlug (you probably already have it)
1- Open vPlug.ini file, find its ProviderID_IgnoreList line, then remove “023B00,” from it.
2- Overwrite your vModules\Viaccess.mdl file with the new Viaccess.mdl file.
3- enjoy it as long as it lasts!
Pentru tutoriale instalare Skystar, ProgDVB, AltDVB, and much more click [Only registered and activated users can see links. Click Here To Register...]
Pentru tutorial instalare plugins click [Only registered and activated users can see links. Click Here To Register...]
