Nabilosat DarkStar II DM500s
Nabilosat DarkStar II E1
For dm500
What is new in this DarkStar II DM500 ?
Updated CVS: 30 August 2008
The image has been completely recoded based on the latest CVS
Updated Skin by porto
New DarkStar II skin customized by porto
Enigma 1 Integrated 8 Days Sky IT EPG
Download 8 days Sky IT EPG, and have it integrated to Enigma1
EPG Event Search
Select a single channel EPG, press 0, enter a keyword and search for your preferred events
EPG Channels Selection
Customize the list of EPG channels to download.We reccomend to restart Enigma upon completing the selection
EPG Channels Update List
Update the EPG channels list when there are changes
Standby after reboot
Your DM will automatically standby after an accidental reboot, such as after a powercut
Scheduled Reboot
Schedule an automatic daily reboot
Network fix
This feature is for DM7020 versions
Updated OpenVPN Kernel Module
The OpenVPN module has been updated. Fully included in DM7020.
Warning Do not download the OpenVPN plugin from the Yellow Panel to DM7020
Main Function Keys
Button 1xOK = Light Info OSD
Button 2xOK = Extra Info OSD
Button Blue = Nabilo Blue Panel
Button 2xBlue = Nabilo Extra Settings
Button Yellow = Nabilo Yellow Panel - Plugins List
Button 2xYellow = Nabilo Yellow Panel - Addons Manager
Button Red = Current Channel EPG
Button 2xRed = Select Channel EPG or MultiEPG
Features
Addons
Dedicated Addons Server
Download and install additional packages from Nabilosat server
Infobar/OSD
Enigma1 Analogic Clock
Channel Orbital Position
Signal SNR, AGC, BER
Infobar Picons
Advanced EMU information
Nabilo Panels features
1) Blue Panel
Extra Settings
Swap File Settings
Inadyn
Hard Disk Settings
Nabilo EPG Settings
Nabilo OSD Preferences
Nabilo Scheduler
Network Services Panel
NFS Server Panel
Mount Points
System Info
Dreambox
Mount Points Info
Process Info
Memory Info
Enigma Setup
Bitstream
Save
Select/Start/Restart EMU
2) Yellow Panel
Forums
Shoutbox
Addons
Scripts
Addons Download Manager
Manual Install Panel
Addons Uninstall Panel
Images Uninstall Panel
Nabilosat Statistics
Many thanks to the Beta Testers Team
Black33, ^^Corrado^^, ^^Maximo II^^, greg, Matrix10, Porto, ^)0(^Nabilo^)0(^, Army, Piefav, Franzjuve, Willow, fbrassin, Neri73, frimmino, astemio, DeepDiver
Credits
Sky IT Epg fully integrated to Enigma 1 by the great MaxZ4.
Many Thanks to lukkino (VDR-Italia) for opentv source code.
PLI-Jade with Gbox+CcCam 2.0.11 Ems (Backup)
PLI-Jade latest
fully installed to work with:
Gbox2.1b
CcCam 2.0.11 (latest)
Both emulators can be working together
Gbox Share Center 1.50 added
Stable and fast sharing
Note: the file should be sent to your DM500S via Flashwizard
download :
PB ENIGMA DM 500 Version 3.0
Version 3.0
Update: 08.02.2009
Neue Skin-Features (alle Skins sind/werden getauscht im Online-Update) ...
in der Programmübersicht wird der Fortschritt der laufenden Sendung
angezeigt
*** AC3
- Aufnahme Deaktiviren und Teletext bei Aufnahme deaktivieren ist
im Expertenmenü schaltbar!
*** Enigma optimiert, um 100 KB kleiner (wichtig für die CVS-Images)
*** NAS gefixed
*** IDE gefixed
*** Fixes in der BA-Verwaltung
*** Diverse kleinere Fixes
*** Deutsche Sprachfiles ok
Re: PB ENIGMA DM 500 Version 3.0
Testat , nu am gasit sa vad spatiul , cred ca sta rau la capitolul spatiului disponibil , imaginea nu e asa clara in cvbs. Poate trebuia sa testez mai mult dar ...mai sant de testat si alte imagini.
SifTeam_500MV_1.9.3D>>>BACKUP
Backup_SifTeam_500MV_1.9.3D
CCcam 2.0.11
Mgcamd 1.31
Setting Vhannibal Dual Feed
Language English Italiano
CCcam.Info
Cryptinfo
keydownload
BY_ANTR@G
download :
TDW 1.70 Maxvar for DM500
TDW DM500 1.70 Maxvar Image
CVS Datum: 27.03.2009
Enigma: 27.03.2009 (tdw mod)
Busybox: v1.01 (tdw mod)
Kernel 2.6.9 (tdw mod)
Tasten Belegung und standart Einstellungen
Standard keyboard layout and settings
Blauetaste TDW Panel
TWD Panel Button Blue
Gelbetaste Addons/Plugins
Yellow button addons / plugins
Gelbetaste Untermenu/subservise
Yellow button submenu / subservise
Rotetaste epg-menu
Red Button EPG menu
OK-Taste lang drucken erreichen sie Bluepanel
OK button long press to reach Blue Panel
Gelbe und Blauetaste konnen sie nach wunsch belegen
Yellow and Blue button allows them to request proof
TDW-Panel abschaltbar unter TDW Panel/extras/TWD Utilities/Fernbedienung
TDW-Panel, TDW-Panel under disconnectible / extras / TWD Utilities / Remote
TDW Cron Manager
Programmverlauf der Sender im Überblick
Program course of the transmitter at a glance
Standart und Netzwerk ECM in der Infobar Abschaltbar
Standard and network in the ECM infobar switched
Zeigen standart und Netzwerk ECM und Verschlusselungsart in der Infobar
Show standart and network encryption and ECM in the infobar
TDW-Panel
OK-Taste lang drucken, erreichen sie TDW-panel
OK button long press to reach TDW-Panel
download
Evolution 2.3 Dreambox 500S edition
Evolution 2.3 Dreambox edition
Dreambox 500/56x0/7000
Technical Infos:
CVS Version: 05.12 2009
Linux kernel version: 2.6.9
GCC 3.4.4 Original CVS
Web Inteface 6.0.4-Expert
Busybox 1.01
BLUE - Blue Panel (Emu Addons)
YELLOW - plugins
RED - EPG
GREEN - subservices
Blue Panel Info:
Start/Stop Emu
Green - News
Red - Sys Info
Blue - Addons
Yellow - Settings
Addons info:
Download Addons - Emus,keys,Plugins,Setting....
Manual Install Addons tar.bz2
Delete Addons
-------- New in Evolution 2.3------------
Fix CCcam bug with external card reader
Fix restart Enigma i hope!!
Changes in Enigma code
Removed epg faster we have now in cvs
Removed not needed files
Update libc.so.6
New boot logo
Latest satellites.xml if you dont like it update your with dreambox edit
New stuff in cvs
Thanks to my freands Ohem2000,dzoni,Alucard for helping me!!
Support and bug report: [Only registered and activated users can see links. Click Here To Register...]
This image doesn't include keys or emulators.
satkeynet is not responsible any damage caused by this software.
DOWNLOAD [Only registered and activated users can see links. Click Here To Register...]
Gemini Project 4.70 DM500 MaxVar
Technical Infos:
* Enigma of: 19.12.2008
* GCC 3.4.4 Original CVS
* Web Interface: 6.0.4-Expert
* Busybox 1.01
* Tuxtxt V1.104
* CIFS 1.44
Remotecontrol:
* BLUE - Blue Panel (BP)
* 2x BLUE - BP -> Extras/Settings
* YELLOW - Quick-Button (can be configured via BP)
* RED - EPG list for active channel
* 2x RED - EPG style menu
* GREEN - subservices
Addons:
* own Addon-Server via Internet, many addons with preview
* Retreiving additional functions via internet from the Gemini-Server and install them automatically
* Personal Addon-Server can be used (configuration via /var/etc/useraddon.xml)
* Create your own Satellites.xml, which only contains the Satellites you really need
* Manual installation or deinstallation of addons
Camd:
* Different Camd´s can be linked to channels/provider (Autocam)
* Changing the name and settings with a menu of its own
* Possibility of establishing a second socket (/tmp/cam1.socket)
Daemon / Server / Clients:
* Automatic test whether the box is connected with the internet or not (To be shown in the infobar)
* Dropbear (SSH) can be set on and off (DM500 - DM7000: Standard->off)
* Added editor to configure the cron-daemon
* Little Apache (HTTP-Server based on HTTPD)
* Upnp Client and Server (for DM500/56x0 must be installed from Gemini-Server as addon)
* Inadyn (Daemon for different DYNDNS-Services)
* Settings for syslogd
* Dreambox can be used as printserver (BP->Extras/Settings->Printer (LPD), FAQ can be found in the database
* Automount, for examples have a look at: /var/etc/automount.conf. Devices, NFS or CIFS will be automatically mounted. Perfect for DVD- or Net-Drives (Editor can be found in the BP)
* NFS-Server (based on the NFS-Kernel-Modules, not for DM500, DM500+ and DM56xx)
Infobar / OSD / Skin / Background-Pictures:
* Position of the Infobar can be changed without editing the skin files
* Provider, Frequencies, Symbolrate and FEC can be displayed in the Infobar (If the Skins supports this function)
* Display of EMM, ECM or "Expertinfos" are adjustable
* Picon (displaying the Channel-Logo)
* Extensions for Skins (Thumbnails, 3D-Font, Pictures for Progressbar)
* Background picture can be turned off (Plasma - Fix)
* Backgroundpictures (Radio- and File Mode) can be used as Screensaver.
* Changing Bootlogo via menu ( 7020 only)
* Backgroundpictures and Bootlogos can be created, testet and used direct on the Box (out of JPG, BMP, GIF or PNG)
* Showing Onlinestatus when the Box is connected to the Internet (must be activated in Expert Menu -> Network)
* Moved Gemini events (Ripper, Calendar, email-Checker) from BluePanel Menu into the infobar (eLabel-Name = geminievent)
Files / Devices
* Support for CD-ROM/DVD-drives ,regardless of using IDE or USB
* Random function for all kind of soundfiles
* Backup function
* Two new root entries for music and pictures can be created in the filemenu (BP->Extras/Settings->Root-Entry)
* Support of the bigger remote on 500 and 500+ (normaly shipped with 70XX/600pvr - activate on BP->Extras/Settings)
* Support for FLAC, OGG/Vorbis and WAV (please install codecs in the BP)
* Functions for SWAP (virtual memory). Create, delete, size and location.
* Device-Manager for HDD / DVD / CF / USB
* Drivers for USB-Cardreaders are now included in the Image but are not loaded automatically!
EPG
* additional functions (e.g. dishnetwork, cache, location)
* search all channels for an event or an own string. Timers can be added immediatly (Press "Menu" in the epg or use use BP -> extras -> EPG-Refresh)
* Infos of the recorded movies can be shown without starting the movie
* refresh EPG using the enigma-timer (BP -> extras - EPG-Refresh)
* autosave for EPG-cache ( BP -> Extras/Settings -> EPG-Settings)
* Duration of current event in the programm overview ( Menu -> Info -> EPG)
* general information about the EPG Data (BP -> Info-> EPG-Settings)
* a time period for the EPG Data can now be defined (BP -> Extras/Settings -> EPG-Settings)
Extras:
* Dreamnetcast (shoutcast-player) with Streamripper (direct recording from server and coding into mp3´s) (for DM500/56x0 must be installed from Gemini-Server)
* RSS und Weather Plugin (for DM500/56x0/7000 must be installed from Gemini-Server)
* System Info: Many extra box infos like HDD temprature, stream-rates (>=7000) or kernel-, memory- and prozessinfos.
* Own scripts can be started via Blue Panel
* Changing the recording parameters (extra before- and after- recording time, storage location and recover-function for your records)
* change the settings for recording (before Time, after-recording time,, location and recover-function)
* Create your own satellites.xml including only the satellites you really need.
* Quick-Button-Menu: Many extra features for the yellow button (e.g permanent clock in OSD, freeze Image, audio selection)
* alarm-clock with volume offset playing own WAV-Files
* Calendar for iCalendar format + reminder ( Supported by MAC, KDE, Thunderbird, Goole calander, Rainlendar...). Standard folder is /var/etc/ical (for DM500/56x0 must be installed from Gemini-Server)
* Support for DreamDVD no matter wether a DVD-Drive is available or not
* New screenshot routines (have a look at the Webif)
* eTorrent - a torrent client based on ctorrent. Can be managed completly over the OSD (for DM500/56x0/7000 must be installed from Gemini-Server)
* disable the TV - output while taking a recording, streaming a movie and manually (usefull for boxes with very low lan-speed)
* update system time via transponder or internet ( Protocol RFC868 )
* eMail-Checker extended with SSL support (Overview of your POP3 or IMAP accounts)
* create password using the BP (BP -> Extras -> Pwassword)
* rotate al kind of pictures. Also automatic rotation using EXIF (must be activeted using the menu)
* Re-Zapp, zapps after X-minutes to the actual Channel (BP -> Re-Zapp)
* Displays, wether the box is an original one or not (using MAC adress, BP -> System -> Dreambox -> Manufacturer)
* the Jukebox, Please install as addon.
Recordings:
* records into different folders ( the settings have to be done in the Timer-Menu)
* LED´s are flashing during record (Boxes without display). Must be set in BP -> Extra -> Record
* import of recorded movies every time you enter the Video-Menu or only once when the Box ist starting (BP -> Extras -> Record)
* Records can now be done in the new Eniga2 format (*meta files) or as usal as "recordings.epl" (BP -> Extras -> Record)
New:
* USB-Cardreaders can be activeted over the menu (BP->Extra->USB-CardReader
* With the variables "show_gemini_server" and "show_camd_plugins" the addondownload and the server can be influenced (/var/etc/Gemini.conf)
Fix + update:
* After- and Prerun at records increased to 20 minutes
* after a backup-restore the datas are available immediately, eg. bouquets
* Crash at web-access to PMT-Pid without a valid PAT
* Flickering of the popup "Channel change: Service not found"
* Prevent the popup "Channel change: Service not found" while the rotor is moving
* have a look at the CVS
Interfaces WebIF:
[Only registered and activated users can see links. Click Here To Register...] (ZAHL = number of cam)
We'd like to thank everybody who participated in the "Gemini suggestion" thread. Unfortunatly many things can not be realized by us, but must be developed by the CVS-Team
This images doesn't contain any keys or softcams. Backups or other modified Images are not released by and won't be supported in any way!!!
Gemini Images may only be used on receivers of the manufacturer Dream-Multimedia-TV.
The use of this Image is on your own risk.
Recommendation:
If you don't install the Image in flash memory, the flash image shouldn't be of a old version. A swap file/partition (>= 16MB) should be present
if several processes running in background. We take no responsibility for direct or indirect damages!
Gemini 4.70 DM Ara drhg NO-Bomb
Gemini 4.70 Ara drhg NO-Bomb
DM500S Nemesis 4.4.1 Skin Rihanna blue and CCcam2.
DM500S Nemesis 4.4.1 Skin Rihanna blue and CCcam2.1.4 by Marwen
with :
*Easylogo V1.2
*CCcam 2.1.4
*CCcaminfo V1.1
* Rihanna Blue
*Nagrab
*Free space in Var 83%
langueges = arabic+english+french
DOWNLOAD
Code:
http://www.4shared.com/file/225841035/102644c8/New_Nemesis_441_Skin_Rihanna_b.html
Nabilosat Darkstar II_Skin Original_DM 500
Nabilosat Darkstar II_Skin Original_SPCS_2.5.16&CCCam_2.1.4_Maxvar_Mod cool753_25.02.2010
Cod HTML:
cool753;
1 st release 25.02.2010
new modification ;
-new bootlogo arabic-sat
-Emu: Spcs 2.5.16 inside (start with image..in blue panel withe volume button for the built-Emu )
-Emu: CCcam2.1.4 inside (start with image..in blue panel withe volume button for the built-Emu )
-send reader.bin in /var/tuxbox/config with ftp
-send CCcam.cfg in /var/ect with ftp
-Skin orginal (Dark)
-French &English language
-big var 77% Free espace with Spcs emu and CCcam and more
-add = CCcaminfo&and Ecminfo&Mgcamdinfo&HackSatKeys V9a&Ngrab recording=inside image (Yellow Button)
-add softcam (entv,foxlife....)
-disable MHW EPG (no frezz)
-Fast image to open channels with Spcs&CCcam
-send this image withe dreamup or falshwizard .
