IPBOX 910 **NLB firmware**
Prepared by : Dexter
Release date : October 25. 2008
Changes:
* included: internal cardreader enabled
* included: external USB pl2303 cardreader enabled
* updated: nlb panel 1.3 with internet update
* fixed: newcs scripts updated in webif and panel
* fixed: multiboot scripts now using /mnt/usb/usb0
* fixed: skins updated to 3.2, thanks to zbigzbig and Crash for the updates
* added: NLB Panel (start with green button) onscreen menu, webif alternative
* added: Incubus camd v0.5 (not configured! will crash box if not configured)
* added: mount usb stick or Harddrive with Windows filesystem at bootup
* added: format usb stick with Windows filesystem in Webif
* added: hdd sleep period configure option
* added: restore var from usb
* added: switch between nlb and dgs webif (dgs webif has WebTV support!)
* added: plugins - tetris,pong,sudoku,weather
* updated: cam scripts
* updated: mbox Build 0015
* updated: format usb stick with Linux filesystem for multiboot in webif
* updated: Full German translation update (Byti)
* updated: Full Swedish translation update (Wikings1)
* updated: Full Danish translation update (pen1010b)
* updated: Documentation on nlb mod features.
* fixed: mount usb stick with Windows filesystem
* fixed: multiboot - now supports usb_all and usb_all_noboot images
* * Thanks to Byti,Spiderman,Wikings1,teleka for intensive testing and reports
Re: IPBOX 910 **NLB firmware**
nlb8421-910 (v1.110)
Release date : November 9. 2008
Changes:
* fixed: DGS application patch to keep EPG when changing TP, DGS delete them.
* fixed: (910) card reader enabled from boot again.
* updated: NL language files (Gman2006)
* updated: USB scripts updates
* update: nlb panel v1.36 emu changing works now.
* - option to set changable delay during boot with newcs
* - Some cards requires longer initialisation than others.
* - Those without should just use like 3 seconds.
* updated: Webepg v0.6 now works with patched DGS application
* - option to dump favorites as webepg.list
NLB9207 for all abcom HD boxes
DGStation/Abcom CubeRevo Series nlb svn9207 v1.31
WEBIF
login: root
password: relook
Release date : April 4. 2009
Changes:
* updated - Using DGStation release SVN9207
* emu - added - Hypercam 1.1
* emu - added - replace.list config for german provider support
* webif - new carddriver change between dgstation and custom driver, if issues are found.
* skins - deepblue, grey and blue updated to r9207.
NLB9207 hotfix for subtitles missing when switching channels:
Image release: NLB-9341-v1.320
Release date : May 3. 2009
Changes:
* updated - Based on DGStation SVN9341
* emu - updated - Hypercam 1.03
* emu - updated - IncubugCamd 0.82
* emu - updated - mbox 0.5 Build 08
* carddriver- updated pacco carddriver 090502.
* skins - deepblue, grey and blue updated to r9341.
* plugins - updated - favpip v2.1.1
* plugins - updated - bitrate 0.0.6
* plugins - fancontrol 0.1 (change config to /var/etc/fancontrol.config to activate)
* NE*CS - removed cardlevel from all config files. (seems to cause problems)
Hello
Great IMG for my IPBOX 910
but how do i add canals to the favourite list.?
in my TV1000 there is no subtitles - i have to press "subtitles" on the remote and that is not stored - so next time i go to TV1000 i have to do it once more
what to do
Image release: NLB-10513-v1.50
Changes:
* updated - Based on DGStation SVN10513
* emu - updated - mgcamd 1.33
* emu - updated - IncubusCamd 0.92
* emu - removed - hypercamd
* emu - mbox 0.4 build 0022 with gbox-support inserted
* other - updated - streamtools
* webif - updated - dgs webif 1.38
* skins - removed old grey blue skins
* keyupdater included
* many thanx to lareq for the good cooperation in changing scripts and building images
* thanx to giopet aud stauffie for being beta-testers
nlb11102_910 release 24.10.2009
Changes:
* updated - Based on DGStation SVN11102
* fixed DGS-dhcp-bug ... quick and dirty solution, but working ;-)
* emu - IncubusCamd 0.93
* emu - mbox 0.4 build 0023 (gbox support)
* emu - mgcamd 1.33 (starts by default)
* webif - updated - dgs webif 1.4.03
* plugins - updated - favpip v2.3.0
* k*y updater included
* nlbpanel included
* and some other plugins :-)
* info: only cool-skin installed
known bugs:
* rec and dolby led´s are always "on" ... this minor bug will solved soon
some remark:
* we ask you to not convert your old db.dat and to use in this release ... also not by using new PCEditor 1.2.54
If you still want to use old db.dat, then rename it to db.dat.edited and copy it to /var folder and reboot ...
after reboot existing db.dat will be replaced with your db.dat.edited file ... thanx
some remark:
Nu am inteles ce au vrut sa explice aici, sa redenumesc fisierul db.dat in db.dat.edited si sa-l incarc asa ? Am incercat si nu a mers, numai prin metoda clasica a luat lista de sateliti salvata inainte.
