incubusCamd pe Kathy = Cccam
IncubusCamd
este ultima aparitie pentru Kathy si Ipbox.
Disponibil pe procesoare : sh4 (testat pe Cuberevo, Cuberevo mini, kathrein ufs910 cu e2)
Merge pe e2 la kathrein si pe ipbox 9000/900 cu dgstation firmware
Protocoale: cccam, g**x, newcamd 5.20, newcamd 5.25, radegast old, radegast new, aroureos
La kathy se instaleaza pe e2 ca si client cccam astfel:
in /var/etc
incubusCamd.conf
incubusCamd,prio
in /var/bin
incubusCamd.sh4_e2
incubusCamd.conf se pun liniile in 2 locuri dupa exemplul de mai jos
[Prov:FF00]
# this provider is a stand-in for all providers not declared------------------
# For example i choose to use gbox protocol on all other provider.
#card_server_url_0=gbox://
card_server_url_0=cccam://test:test@192.168.1.6:12000
########################### servers configuration ############################
# This is the section for the multi-server configuration.
# First release use this only to connect on ONE cccam server and on ONE gbox
# server.
# gbox://<localhost>:<localport>:<password>@<peer_address>:<peer_port>:<peer_pass>
# cccam://<username>:<password>@<hostname>:<port>
[Servers]
#card_server_url_1=gbox://<localhost>:<localport>:<password>@<peer_address>:<peer_port>:<peer_pass>
Lansarea se face simplu:
cd /bin
incubusCamd.sh4_e2 sau fara extensie daca il redenumiti
20/06/2008, V0.50, First public release
camd33 and camd35 is really much unstable so I think it's not yet ready for public,
asap it will be ready i'll publish it
This is the first release, you can't see any log on the console because
I don't wanna people read infos that could put them on the strange way.
However logs on console are really good to know if bugs are the cause of your problem or
simply if you are so noob to not be able to configure it correctly.
Read very well config files and don't say something you don't know.
This is not a fully working cam, some functions are not implemented/enabled because they are not ready for public and
I think people don't wanna functions that are working not really good as they expected!
(also this version is a beta version, but i wanted to put some hopes on people that believe a cam is better than othern one,
we have tested the cam on many decoders and we can say this cam is not bad at all also in beta and not full working mode )
So for the first release I choose to public only client side of the cam.
I want to thank raton_craquero for givin' me the possibility to know really a lot of things on how to use dvb_api and i have
to admit that i really like his config file structure and his log functions, so i decided to use them with his agreement
Thank you!
Re: incubusCamd pe Kathy = Cccam
Scuze ca raspund asa de tarziu. Am uitat.
Deci Incubus e numai client de ccam, lasi serverul in optibox si pentru kathy faci o line F, la care ii faci linie corespunzatoare dupa exemplul din primul post.
problema mea este ca pe optibox am cccam 2.0.8 si linia F este de forma
F: user1 pass1
linia C este de forma
C: <hostname> <port> <username> <password> <wantemus>
vreau sa desfiintez optibox si sa merg doar cu kathy .ce nu inteleg in incubusCamd liniile sunt de forma
in exemplul lui Zildan cum ar trebui sa arate liniile mele si daca trebuie sa dau vreo comanda dupa editare ? am inteles ca incubus este doar client de cccam doar de asta am nevoie ,sa primesc...
Nu merge decat cu o singura linie de cccam , nu stie sa traga din mai multe, este facut prin reverse engeneering, ca doar nu s-a inghesuit DMM sa faca public protocolul.
CCCam e sustinut clar de DMM, cum iti explici ca pe DM100 a aparut urgent si pe altele, desi sunt de 2 ani pe piatza nu merge!
Deci linia F este de forma:
F:user1 mass1 2 0 1 { 0:0:2 } { } { } xxx.no-ip.info
si linia din incubus aferenta:
card_server_url_0=cccam://user1:mass1@xxx.no-ip.info:1200
unde 1200 e portul serverului de cccam
buun,si linia F:user1 pass1 2 0 1 { 0:0:2 } { } { } xxx.no-ip.info ,mai apare undeva sau numai
card_server_url_0=cccam://user1as1@xxx.no-ip.info:12000
in cele 2 locuri indicate de tine ...?,
banuiesc ca xxx.no-ip.info este adresa din xxx.dyndns.org:12000 ?
din pacate nu merge ceva nu este in regula ,ori nu stiu eu ce sa fac
este cineva care foloseste incubuscamd pe kathrein ca si client de cccam ?
poate ma scoate din namol
Merge sigur.
Poate nu stie bine cu dyndns. eu am probat cu IP!
incercand noua imagine care se instaleaza prin flash si urmand instructiuniile din acest thread pt. a instala "incubus" observ ca acesta nu ramane activ dupa pornirea din "AAF-panel"
practic imi apare cu celelalte emmuri (4 in total cu incubus) ii dau start din butonul verde , ies din meniuri si ma duc pe alt prg. si cand accesez din nou "AAF-panel" imi scrie " no activ emmu" ( am schimbat si "emu" cu bin" din liniile de comanda date de wambertos , fiindca am observat ca fisierul "emu" nu poate fii accesat - imi apare : /var/emu - ( sageata ) /var/bin deci fisierul "incubus" l-am copiat in /var/bin cu 755)
zidan am incercat si eu cu ip sau domeniu liniile date ca exemplu si nu am reusit sa deschid nici un prg. ( nu vorbesc aici de prb. de mai sus cu incubusul pe noua imagine prin flash)
1 Attachment(s)
pentru a instala incubusCamd in enigma2 in cazul in care imaginea nu are lynk de download descarcati
dezarhivati zipul si veti avea un incubuscamd.tar pe care il copiati cu ftp in directorul /tmp din kathy.
(Unzip and copy incubuscamd.tar to /tmp in kathy)
Apoi dati din telnet comenzile:
(In telnet type )
Code:
cd /var
tar xvf /tmp/incubuscamd.tar
rm /tmp/incubuscamd.tar
Editati in /var/keys/incubuscamd.conf si puneti liniile dupa exemplele de mai sus.
(Edit /var/keys/incubuscamd.conf and put your line.)
Testati comanda:
(In telnet type )
Code:
ping www.sateliti.info
Daca apare ok adica aveti raspuns la ping de forma:
(If you have )
Code:
PING www.sateliti.info (91.121.159.123): 56 data bytes
64 bytes from 91.121.159.123: seq=0 ttl=54 time=44.859 ms
64 bytes from 91.121.159.123: seq=1 ttl=54 time=43.630 ms
atunci startati incubus din meniu.
( net is ok , start incubus from menu)
Daca nu aveti raspuns la ping verificati setarile de retea si atentie la GW.
(If you don't have ping OK check gateway.)
Spor la treaba si astept confirmari.
Mare atentie la retea pentru ca la mine era GW pus prost desi la instalare am setat bine.
i have problems with inubuscamd in kathy
it's work but when i wach 10 min it's stop and i must restart camd to make wach again .
i have linux cccam server but i don't now why is not work without stoping and freezing
please any help :comp:
Install only incubus emu in TDT-383 AAF All In One Flash 1.0. Space in flash is limited.
yes i install new emu in flash but it's same problem
did i need configure C line in my cccam linux server diferent for katty or it's same like for dreambox ?
In CCCAM linux server put only F line:
in kathrein /var/keys/incubus.conf:
[Prov:FF00]
card_server_url_0=cccam://user1:mass1@192.168.1.6:12000
# server.
# gbox://<localhost>:<localport>:<password>@<peer_address>: <peer_port>:<peer_pass>
[Servers]
#card_server_url_1=gbox://<localhost>:<localport>:<password>@<peer_address>: <peer_port>:<peer_pass>
thanks for quick replay now it's work beter thanks
what wersion of incubuscamd you use , do you make me upload or send to my e mail
thanks
In flash version [Only registered and activated users can see links. Click Here To Register...]
