List of Harddisks which run ok in CubeRevo boxes
List of Harddisks which run ok in CubeRevo boxes:
CubeRevo
3.5 inch
HITACHI
- Model : HDP725050GLA360 / 500GB / 7200rpm / SATA
- Model : HDT725032VLA360 / 320GB / 7200rpm / SATA
SAMSUNG
- Model : SP2504C / 250GB / 7200rpm / S-ATA II
- Model : HD501LJ / 500GB / 7200rpm / S-ATA II
- Model : HD753LJ / 750GB / 7200rpm / S-ATA II
WESTERN DIGITAL
- Model : WD1600AAJS / 160 GB / 7200rpm / ATA II
- Model : WD2500AAJS / 250GB / 7200rpm / S-ATA II
- Model : WD2500AVJS / 250GB / 7200rpm / SATA 3Gb
SEAGATE
- Model : ST3160811AS / 160GB / 7200rpm / S-ATA II
- Model : ST3250824AS / 250GB / 7200rpm / S-ATA II ( but version G not recognized )
Cuberevo mini
2.5 inch
SAMSUNG
- Model : HM121HI / 120 GB / 5400rpm / SATA1 1.5Gb/s
WESTERN DIGITAL
- Model : WD1600BEVS / 160GB / 5400rpm / SATA1 1.5Gb/s
- Model : WD800BEVS / 80GB / 5400rpm / SATA1 1.5Gb/s
SEAGATE
- Model ST9160823AS / 160GB / 7200rpm / SATA2 3.0Gb/s
3.5 inch
HITACHI
SEAGATE
- Model : ST3320820SCE / 320GB / 7200rpm / SATA
Re: List of Harddisks which run ok in CubeRevo box
acestea sunt toate HDD-uri interne....
A testat cineva hdd externe cu alimentare pe e-sata ?
Am pus un hdd model mai vechi sata 1 WESTERN DIGITAL
WD1600JS / 160 GB / 7200rpm / SATA I si merge ok.
Se pare ca sunt suportate mult mai multe hdd-uri decat cele din lista asa ca nu ezitati sa le testati.
In seara asta pun unul extern pe e-sata de 500GB, va tin la curent daca merge.
Segate FreeAgentPro 500 GB - MERGE pe 900HD !
Am pus Segate FreeAgentPro 500 GB extern (firewire,usb2.0,e-sata) model ST305004FPD1E3-RK.
merge ok.
Cand testez fac inregistrare+play si verific in info.
Recunoaste modelul, marca, tot !
Sunt curios care nu merg.
Discutabil este controlul soft al alimentarii. La ora la care va scriu hdd-ul e conectat de aprox 2 ore si se invarte non stop, ceea ce poate sa-i reduca durata de viata.
Din ce am prins eu 9000 si poate chiar si 910 taie alimentarea din soft la hdd-urile alimentate de catre receptor(in general interne).Poate confirma posesorii de 9000 si 910.
Urmeaza sa pun si un WD de 1T extern pe e-sata, va tin la curent.
Re: Segate FreeAgentPro 500 GB - MERGE pe 900HD !
daca nu folosesti pe HDD dupa 2-3 minute il opreste ipbox 9000 singur.Si cu e2 se opreste dupa 5 min cu un script.
WD extern 500 GB My Book Studio Edition (usb,e-sata,firewire 400,800), NU MERGE.
1 Attachment(s)
Si ultimul update care a aparut ieri....
Asta este tot lista veche, nu stiu de ce apare la ei pe siteul de download ca actualizat (daca era noua, probabil ar fi actualizat si pe pagina de web data ultimului update). Pe DenkTenk am gasit o lista actualizata de membrii forumului. Din pacate nu am reusit sa fac rost de HDD de laptop mai mare de 160 Gb si care sa mearga in IPBox 910HD. Am comandat in 2 locuri un Samsung HM320JI (320 Gb) dar nu e nici pe stoc la distribuitor. Cred ca o sa iau unul de 160... sper sa-mi ajunga.
I also favor the view that it would be appropriate only truly relevant data and not crap according to DGS. 60% reportedly supported HDD in IP9xxx works.....
Pt ipbox 9000HD HDD care suporta:
*modele testate de la DGS poate exista si alte modele care sa functioneaza.
▣ HDD List
l Cuberevo
▶ Supporting Harddisk List
▷ 2.5 inch
1) Samsung
- Model :
2) Western Digital
- Model :
3) Seagate
- Model :
▷ 3.5 inch
1) HITACHI
- Model : Model : HDP725050GLA360 / 500GB / 7200rpm / SATA
- Model : Model : HDT725032VLA360 / 320GB / 7200rpm / SATA
2) Samsung
3) Western Digital
4) Seagate
- Model : ST3250824AS / 250GB / 7200rpm / S-ATA II ( Mainboard Ver.G Not Working )
▶ Non-Supporting Harddisk List
▷ 2.5 inch
1) TOSHIBA
- Model : MK1652GSX / 160 GB / 5400rpm / ATA-8
2) Western Digital
- Model : WD3200BEVT / 320GB / 5400rpm / SATA 3Gb
- Model : WD2500BEVS / 250GB / 5400rpm / SATA
▷ 3.5 inch
1) HITACHI
- Model :
Pt modelul 900HD sunt:
▣ HDD List
l Cuberevo-mini
▷ 2.5 inch
1) Samsung
- Model : HM121HI / 120 GB / 5400rpm / SATA 1.5Gbps
- Model : HM250JI / 250 GB / 5400rpm / SATA 1.5Gbps
2) Western Digital
- Model : WD1600BEVS / 160GB / 5400rpm / SATA 1
- Model : WD800BEVS / 80GB / 5400rpm / SATA 1
3) Seagate
- Model : ST9160823AS / 160GB / 7200rpm / SATA2 3.0G )
- Model : ST980811AS / 80GB / 4200rpm / SATA )
▷ 3.5 inch
1) HITACHI
2) Seagate
▷ 2.5 inch
1) TOSHIBA
2) Western Digital
- Model : WD3200BEVT / 320GB / 5400rpm / SATA 3Gbs
▷ 3.5 inch
1)
- Model :
Pt model 910HD sunt:
▣ HDD List
l Cuberevo-mini2 (3000HD)
- PCB : Cuberevo-mini II Ver.D1, 2008.07.30
- SMPS : DG-320PVR MUREX
▷ 2.5 inch ( O : Support, X : Not Support, NA : Not Available )
Samsung
Western Digital
Seagate
▷ 3.5 inch ( O : Support, X : Not Support, NA : Not Available )
Samsung
SP2504C / 250GB / 7200rpm / SATA
Western Digital
WD2500AVJS / 250GB / 7200rpm / SATA3 Gb
WD1600AAJS / 160GB / 7200rpm / SATA2
Seagate
ST3250824AS / 250GB / 7200rpm / SATA2
ST3160811AS / 160GB / 7200rpm / SATA2
HITACHI
HDP725050GLA360 / 500GB / 7200rpm / SATA 3Gb
HDT725032VLA360 / 320GB / 7200rpm /SATA2 3Gb
TOSHIBA
Western Digital
Eu am bagat in IPBox 910HD un:
Seagate 2.5" / ST9250827AS / 250GB / 5400rpm / SATA II
merge perfect.:dance:
SATA, e-SATA , USB HDD support of AB IPBox 9xxxHD series.You can check compatibility of some HDD when connecting via SATA or e-SATA interface intable below. There are mentioned only models that were physically tested in the table. Ifthere is a concrete model (e.g. WD5000AACS) mentioted it means that whole model line isalso compatible (e.g. WDxxxxAACS). Some HDDs use SSC function – receiver may notidentify it. In such a case use connection of your HDD through external USB box. AB IPBoxreceivers do not support simultaneous operation of two hard discs (internal and external butif you use internal HDD you can also use your USB flash memory to playback MP3 or JPEGfiles.It is necessary to format your HDD after first turning on with installed HDD.
There is “HDD check during start” item in Menu – Advanced setting – HDD setting turned intono to quicken the start. If a problem with records occurs try to turn it into yes and restart yourreceiver. HDD checking performs automatically. If a problem resists try to format your HDD.
Ieri am montat in IPBox 910HD un Samsung HM320JI şi pot confirma că merge brici!
deoarece ala de 250 l-am pus in laptop, am bagat in STB altul de 160 GB:
scsi0 : sata_stm
Vendor: ATA Model: FUJITSU MHZ2160B Rev: 0000
Type: Direct-Access ANSI SCSI revision: 05
SCSI device sda: 312581808 512-byte hdwr sectors (160042 MB)
