Aica o sa gasiti firmware de la NLB pentru Ipbox 900HD...
NLB release for IP900 using SVN7473 for CubeRevo mini. It has been tested and verified.
Get it here - nlb7473mini
Upgrade box using usb key.. image file should be named "usb_update.img"
PS: Known issue on first boot startup of box. DHCP not working. You need to go into ip setup and choose save in ip setup for DHCP or STATIC, then all is ok.
For the people who are thinking of testing every option from the WEBIF, please have the following warning in mind:
Don't use MGC**D v1.29a or 1.29a patched since that will hang the receiver. If you use it, you can't change channels and when you kill it the receiver hangs hard. No panic on the display, only a poweroff will work. When you use 1.29a, you won't be able to reboot the receiver from webif. That will hang the receiver to.
If you have selected 1.29a or the patched version. Remove the file /var/etc/use_mgcamd129 or /var/etc/no_lib_mgcamd using a telnet or SSH session. Then shutdown the receiver. That will give you the new and good MGC**D version
In all other options, the image is very stable
WEBIF
login: root
password: relook
rename usb_update_nlb7927mini.img to usb_update.img and update using usb pendrive.
nlb7927mini
* Updated to SVN 7927mini
* fixed: EVOCAMD script now support /var/bin/evocamd
* fixed: MGC**D script fixed to work with binary /var/bin/mgcamd
* fixed: network DHCP correctly initiated at first boot only
* fixed: skin blue/grey - channel search not working
* fixed: firmare upgrade from webif
* included: cool,nlb_blue_nlb_grey skins from @crash
* --------- no downloads needed
* --------- nlb_blue is default used now
* included plugin: hddtemp v0.0.6 by kneubi
* included plugin: script v0.0.2 by kneubi
* updated: Danish menu language file
* * remember to upload configs/files into /var/keys
* DHCP bug fixed
* SVN update to 8022
***Link pentru firmware asta e scos, din cauza ca reprezinta probleme si nu booteze.Ei care il au sa nu il foloseste pt ca o sa pierde pe timpul lor...***
****- LINK REMOVED -- Image does NOT work (funktioniert nicht!) asa au scris si ei de la NLB si au scos pe firmware.E din pacat sa scoate firmware NLB fara sa il testeze.Din cauza asta eu insist sa folosim Sifteam sau ABCOM sau DGS firmware...****
are bug imaginea - PANICQuote:
include: mbox 10.09.2008
changed: mbox fix for viasat channels
-------: restarting mbox did not clear channel without change channel
changed: soft update script now correctly uses /var/bin/soft
-------: selectable from -assign button- menu too
**Am facut update pe link cu nou software pt ca exista o problema cu kernel care a fixat-o acuma NLB..Acuma NLB r8022 v3 functioneaza fara probleme**
nlb8107mini
Changes:
* include: svn8107 from DGS
* include: mbox 17.09.2008
* included: Deutsch translation from svn8022
* include: Documentation on nlb mod features included.
Remember to download skins update on network update
include: mbox 3.10.2008 (0.4 Build 0005)
fixed: cam scripts
-----: if img file was found on usb stick, cam script closed
-----: causing freeze or no decoding
fixed: skins
fixed: /var/bin/soft reference
fixed: IP9 USB Stick setup as HDD, must be above 2GB,
------ 128MB swap is allocated.
updated: reversed to busybox from previous release DGS SVN8022.. killall did not work
updated: Multiboot is updated to support usb stick changes
updated: Full German translation update (Byti)
updated: Full Danish translation update (pen1010b)
updated: Documentation on nlb mod features.
A possible fix for usb_update.img with ip900
AND
removal of "NLB BOOTING" info.
Attached you find small image for ip900 and one for ip9000.
Fastest way is to upload .img file to your /tmp folder and through webif do a firmware upgrade... file is ONLY 132KB..
It takes only 2 second..
usb_env900.zip for ip900 users
usb_env9000.zip for ip9000 users
* fixed: skin update - show resolution in additional info banner
* added: NLB Panel (start with green button) onscreen menu, webif alternative
* added: Incubus camd v0.5 (not configured! will crash box if not configured)
* added: mount usb stick or Harddrive with Windows filesystem at bootup
* added: format usb stick with Windows filesystem in Webif
* added: hdd sleep period configure option
* added: restore var from usb
* added: switch between nlb and dgs webif (dgs webif has WebTV support!)
* added: plugins - tetris,pong,sudoku,weather
* updated: cam scripts
* updated: mbox Build 0015
* updated: format usb stick with Linux filesystem for multiboot in webif
* updated: Full German translation update (Byti)
* updated: Full Swedish translation update (Wikings1)
* updated: Full Danish translation update (pen1010b)
* updated: Documentation on nlb mod features.
* fixed: mount usb stick with Windows filesystem
* fixed: multiboot - now supports usb_all and usb_all_noboot images
* Thanks to Byti,Spiderman,Wikings1,teleka for intensive testing and reports
WEBIF
login: root
password: relook
Prepared by : Dexter
Release date : November 3. 2008
Changes:
* updated: SVN8421 update with fixed DIVX player (libsync issue fix)!!
* updated: nlb panel with internet update
* updated: mgcamd 1.31 included (fixes old need for mgcamd130, and this is now gone)
* fixed: swap setup with HDD and USB
* fixed: skins updated to 3.3, thanks to zbigzbig and Crash for making quick updates
* added: NLB Panel 1.33 (start with green button) onscreen menu, webif alternative
* added: plugins added - WebEPG 0.1 (Readme in the /data folder)
* updated: cam scripts with bigger timeout
* updated: mbox Build 0015 (the one with gbox support)
* updated: Full German translation 8421 update (Byti)
* updated: Full Danish translation 8421 update (pen1010b)
* included: Documentation on nlb mod features.
* added: HDD Swap enable/disable at bootup.
nlb8421mini (v1.110)
Release date : November 9. 2008
Changes:
* fixed: DGS application patch to keep EPG when changing TP, DGS delete them.
* updated: NL language files (Gman2006)
* updated: USB scripts updates
* update: nlb panel v1.36 emu changing works now.
* - option to set changable delay during boot with newcs
* - Some cards requires longer initialisation than others.
* - Those without should just use like 3 seconds.
* updated: Webepg v0.6 now works with patched DGS application
* - option to dump favorites as webepg.list
CubeRevo nlb8478-910 (v1.2)
WEBIF
login: root
password: relook
NOTE: it seems box still freezes at first "language" selection, please just reboot and
all is ok.
Release date : November 29. 2008
Changes:
* added: NFS mount replacement for HDD SD media recording folder
- Read "nlb_image_features.txt" to understand how to configure NFS media folder.
* - Thanks to DGS for assistance on kernel fix.
* - HD Recordings on NFS works too, but will studder! so you are warned.
Reason - MPEG4 recording can be upto 20Mbyte/second, and network is max. 6MByte right now on ipbox.
so its never going to work with only 100Mbit network card.
- can be enabled disabled under IP9000 -> change NFS/HDD media in webif.
* updated: newcs.xml added boxkey code to support German *** cards.
CubeRevo nlb8630 for ip900(Cuberevo mini) and ip910
WEBIF
login: root
password: relook
Release date : December 16. 2008
Changes:
* added: - can be enabled disabled under IP9000 -> change NFS/HDD media in webif.
* - HD Recordings works too, but will studder! so you are warned.
* fix: NFS mount on boxes without internal hdd.
* fix: Slow NFS mount fix (thanks to semack for the help).
* added: - delay option in panel for Nagra3 cards.
* added: - Germans with nagra card should use 20 seconds and it decodes at bootup
* added: ushare for sharing through UPnP protocol (like to PS3) Thanks to Kneubi
* -----: enable/disable/restart in Webif->system options
* added: Option to run boot scripts from /var/etc in hotfix situation.
* plugins: bitrate 0.0.2 and favpip 0.7 .
* updated: newcs.xml added boxkey code to support German NDS cards.
CubeRevo/IP9 Series nlb8728-v1.23
WEBIF
login: root
password: relook
First time boot with freeze/panic, is not fixed yet.. sorry!
Reboot at lang screen and all is okay.
Release date : December 26. 2008
Changes:
* update: - SVN8728 from DGStation.
* SVN - Support *.mkv with video player.
* - If file needs higher class CODEC, file will not be played with video player . In case of too higher bitrate file, it possible to make a problem for playback (especially *.vob and *.mkv.).
* - Fixed crashing problem with higher symbol rate as 30,000(S/R) TP.
* - Upper card reader.
* - Fixed some bug for schedule recording.
* - Fixed record subtitle.
* - Added "post-descrambling with CAM" function on system settings menu.
* - Added HUB function for USB host
* - Support adjust LipSync using page up/down buttons in Videoplayer
* - Support displays elapsing time on banner of MP3 player.
* - Support Sort function on TMP folder in Recorded files menu.
* - Support auto adjustment local time during boot up if the time variation is less than 10 minutes.
* - Updated language table for Slovak, Bulgarian, Polish and Russian
* - Fixed DVB EPG bug for HB13 10891
* - Fixed elapsing time error when schedule recording.
* - Added ITV HD audio or video type options as AC3, H.264, MPEG 2 etc in Advanced Search menu
* - Fixed bugs in scanning and zapping of the channels with diseqc and usals.
* - Added WSS function through SCART.
* added - dual recording support with mgcamd, default configs are made for newcs setup.
* added - nlbpanel 1.38: nlb panel only shows skins available.
* added - webepg 0.61: Auto import at boot, of epg data when /var/file.xml.imported exists.
* changes - ushare binary updated to use Kneubi release.
salutare!!!
care-i parola de conectare pe ftp, ca nu reusesc... pe interfata web reusesc...
merci
root
relook
CubeRevo nlb svn8728 v1.25
for 9000/910/900/250/200
WEBIF
login: root
password: relook
First time boot with Remote not working, is not fixed yet.. sorry!
Release date : January 5. 2009
Changes:
* updated - bootlogo fix.
* fixed - Internal smartcard reader fix for 910/250
* added - IncubusCamd 0.55 real update with dual tuner,pip and recording support.
* added - more information in webif description.
* added - skin fixes for simple infobar, still a dgs bug here if you jump 2 channels.
* added - formatting of Harddrive if box fails to do it during bootup..
* - NOTE: uboot seems to disable some types of HDD during bootup..
* - ----: When box is ready, remove the hdd and connect again.
* - ----: and use this format option to init harddrive.
* fixed - bug in format hdd/usb routine, wrong partition type choosen.
* removed - reset of cam delay when box goes into panic.
* added - webif option to change newcs config file between nordic and german setup in webif..
* added - webif option to change between old and new sci driver (for special card handling)
* updated - vsftpd.conf , updated with 9MB values for max transfer with ftp..
* added - panel 1.39: hotfix update from /var now possible. read features_nlb.txt for information on how to instal, if you got no internet
* added - direct link at top to dgstation original webif.
(get webif update through panel, to fix missing link in webif)
* update - DGS Webif update, for time correction -60 minutes reported in webif using correct GMT.
* added - Execute startup script before main application, found in /var/etc/init.d , script names start with S .
* fix - Cuberevo250 VFD messages fix.
* change - newcs: Default single internal card slot handling for 250/910.
* change - newcs: Default - newcs is not started on 200/900.
Download - [Only registered and activated users can see links. Click Here To Register...]
CubeRevo nlb svn8833 v1.27
for 900/910
Unofficial Custom release - no limits board --> [Only registered and activated users can see links. Click Here To Register...]
WEBIF
login: root
password: relook
Release date : January 18. 2009
Changes:
** special edition based on 9000/Cuberevo firmware *******
* updated - SVN8833 unofficial (BETA) from DGStation.
* Fix - PANIC situation when DGS Webif is open on pc during bootup.
* Changed - HDD Format of ext2 formatted usb/harddrive even if it was ok.
* Updated - multiboot had some issue with usb sticks above 2GB.
* Updated - multiboot install now works on boxes where usb is mounted as harddrive.
* Fix - multiboot webif on port 81 was using old webif directory.
* Changed - ECM info in webif now showing correct info again.
* Added - newcs 1.63 with updated configs (added 357 mhz to all configs).
* plugins - Added shoutcast 0.51, bitrate 0.4, favpip 1.9.4, fps 0.1.3
* skins - deepblue update 3.5 (new livebanner) Thanks to @Crash
* SVN --- - Recording problem with short HD recordings and 2hr stop fixed.
* - simple livebanner (OSD option) still causing crash.
* - DVBSubtitles now pure white with no banner behind.
* - Signal strength bar is now working again.
* - Media player got FastForward/rewind on divx support now (not .VOB files).
* - blind scan - now default/advanced/reset scan.
* - photoalbum now has background.
* - Maturity rating now as agerating number in livebanner.
* - recording with 1tuner boxes, only channels on same transponder shows
in channel list when 1st recording is active.
* NOTE----- this is a BETA, and people with external usb harddrive
can experience recording issues with 2 HD Channel recordings
(Will be seen as STUDDERING and only a reboot solves it).
