"HOW TO" si EROARE pt IPBOX 91&9xx&9000
*****De la "www.satgrekco.gr" *****
Lista cu error:
Er 1 - Error CRC - face control la firmware (trece din nou pe firmware via usb)
Er 2 - Error CRC - face control la firmware (trece din nou pe firmware via usb)
Er 3 - ID Seller Not correspondent - face control la firmware (trece din nou pe firmware via usb)
Er 4 - ID Product Not correspondent - face control la firmware (trece din nou pe firmware via usb)
Er 5 - Name H / W Not correspondent - face control la firmware (trece din nou pe firmware via usb)
Er 6 - Version Model H / W Not correspondent - face control la firmware (trece din nou pe firmware via usb)
Er 8 - Erase (cancellation) fail - apeleze la service
Er 9 - Flashing (writing) fail - apeleze la service
Er 10 - on the front panel - Unable to update via usb stick - trebuie sa fie trecuta noua bootloader "upgrade with UBOOT1.3.1 with pendrive"
ERR 79 - version db (settings) incorrect - trebuie sa fie trecuta noua database (with a flashing image containing the db)
ERR 80 - Problem communication CPU / Motherboard - apeleze la service
ERR 81 - Problem communication CPU / Motherboard - apeleze la service
ERR 82 - Tuner improperly inserted - scoate si verifica cum ai instalat pe tuner
ERR 83 - Tuner improperly inserted - scoate si verifica cum ai instalat pe tuner
Network Streaming out with PC (pt ipbox)
# Network Streaming out with PC
To make a network stream with your PC, you need a software that converts a media file to TS format and sends it out through internet-network. There are many softwares, but we recommend the software "VLC".
You can download the software VLC from the official website, [Only registered and activated users can see links. Click Here To Register...].
Please refer to the website for the installation.
Streaming out Media File >
Click "File > Open File".
Click "Browse.." button and select the file you want.
Click the checkbox "Stream/Save" and click "Settings..." button.
Select "UDP" checkbox and put the IP address and Port number. The IP address and Port number are of which you want to send to. If you want to send it to your settopbox, put your settopbox's IP address and Port number.
Select Video codec "mp2v", and "mpga" for Audio codec. Bitrate values are qualities of Video and Audio. The quality and speed are in inverse proportion to each other.
You may find a text line like this ":sout=#transcode{vcodec=mp2v,vb=1024,scale=1,acodec=mpga,ab=192,channels=2
}:duplicate{dst=std{access=udp,mux=ts,dst=224.1.1.2:1234}}" on the top of Stream output option window. At the front of "vcodec=mp2v", put "fps=25,". Then result may be going to be like this":sout=#transcode{fps=25,vcodec=mp2v,vb=1024,scale=1,acodec=mpga,ab=192
,channels=2}:duplicate{dst=std{access=udp,mux=ts,dst=224.1.1.2:1234}}"
And then, click OK button.
All your works to stream media file out have been done.
The streaming out will start as clicking OK button of the last window.
Streaming out DVD >
Click "File > Open Disc..".
Select Title, Chapter, Audio track as you want. (we don't support subtitles track)
# Network Streaming out with SetTopBox
Before sending streams out, please make sure that your Settopbox is connected to any of Networks. And a HDD is required for streaming out function. No HDD will not work.
At the main menu, "User's option", there may be the entry "IP Channel".
You can receive streams and also send streams out with this IP Channel function. There are basically 2 functions. "RECV" and "SEND". Move right to the "SEND" button. There are some options need to be set.
"Dest. IP Address" - The IP address that you want to send the stream to.
"Port" - The number of the port of the IP address that you want to send the stream to.
"Protocol" - The way how the stream is transported. At this time, only the "UDP" is available.
"Channel" - The channel you will send out. If you have only 1 tuner, you can only send out the channel what you are watching. If you have 2 tuners, you can send out the channel what you are watching, or, you can send out the channel, from the other tuner, not you are watching.
"Channel list" - You can send the list of your channels to receivers. Receivers can see the list of channels, and even are able to change the channel to what they want. So, you can determine the list of channels, with the Left, Right key. "None" will not send the channel-list. "All" will send the whole of yours. "Select" will send the list of the only channels you select. At "Select" button, you can select channels by pressing key OK.
"START" - Start to streaming out. It may delay the system to get ready, but it will be fine after some seconds.
Now you can send out AV streams through the Network, Internet.
To stop streaming, click "STOP" button.
# Receiving Network Stream with SetTopBox
Before receiving network streams, please make sure that your Settopbox is connected to any of Networks.
You can receive streams and also send streams out with this IP Channel function. There are basically 2 functions. "RECV" and "SEND". To receive network streams, you have to create a channel. That we call, "IP Channel".
IP Channel receives streams from ethernet, not from tuner. So to create a IP Channel, we have to set several options.
Press Yellow key to add a new IP Channel to your settopbox.
"Cast Mode" - There are two types, "Uni-Cast" and "Multi-Cast". If you want to receive from Multicast IP address, select "Multi-Cast". Multicast IP address is in the range of 224.0.0.0 to 239.255.255.255. Unless, select "Uni-Cast".
"Network Protocol" - The way how the stream is transported.
"IP Version" - The version of internet protocol. Usually, it is "IPv4".
"IP Address" - The IP address of your settopbox. If the cast mode is Multi-cast, put the Multicast IP address.
"Port Number" - The number of the port of the IP address.
"Channel Name" - The channel name of this - new IP channel.
"Video PID" - The PID of Video in the network stream. If you don't know about this very well, set it to 0.
"Audio PID" - The PID of Audio in the network stream. If you don't know about this very well, set it to 0.
Pressing OK button, now you have just create a new IP Channel.
Selecting the channel from Channel list, you can watch network stream. Buffering may take some seconds, but it will play soon.
# Using Multicast
Multicast delivers source to multiple receivers. One server can send out the network stream to numbers of clients. To use multicast, server should send the network stream out to the multicast IP address. And client should receive from the multicast IP address. Multicast IP address is in the range of 224.0.0.0 to 239.255.255.255. If server sends out to the IP address 224.1.1.2 and port the 1234, client receive from the IP address 224.1.1.2 and the port 1234.
And before using multicast, please check multicast protocol is available in your network. Usually, local network system supports multicast protocol.
# Remote control via Net
If a settopbox is streaming out and sending channel-list, clients can receive AV stream and also the list of channels that server offers. And clients can change the channel that server is streaming.
At the menu, "User's option > IP Channel", there may be serveral IP Channels that you created.
Focusing channel entry, which you want, press Blue key. Then a small channel list would be shown if server is offering channel-list.
(If server is sending out to multicast IP address and client is receiving that, client has to put the server's real IP address to receive channel list.)
And if you select a channel in the channel-list from the server, server changes the channel that streaming, hence you can watch the channel you want.
# Receiving Network Stream with PC
Unfortunately, receiving network stream, from DGStation settopbox, with PC doesn't work good. We are trying to make it as soon as possible. (At this time, it works when PCR PID is same with VID PID. And the player has to buffer as enough cache. And it is confirmed that the player "VLC" doesn't play sound but video only, the player "M Player" plays video and audio.)
Conectarea USB hard disk pt ipbox 9000HD si 900HD
Aica o sa gasiti informatii cum sa conectati un HDD usb la ipbox 900 si 9000
Cum facem multiboot in ipbox 9000HD
Cum sa facem multiboot in ipbox 9000
Trecem pe nlb7473 image in flash. Trecem pe image cere dorim la plic media ,punem pe usb stick in spate lui ipbox la usb, si dupa mergem la webinterface
facem format in usb stick.
Dupa mergem Firmware options si apasam Multiboot
Scriim numele lui image la cutie enter name of new image si apasam extract. Dupa mergem mai jos in Select usb bootimage to use si alegem care image dorim sa face boot si apasam change.
Ca sa intoarcem in bootimage scriim in internet explorer pe IP care are ipbox de exemplu 192.168.1.10:81. Intram in webinterface lui flash image si mergem si alegem de unde dorim sa face boot ipbox in data viitoare.[/QUOTE]
****[Only registered and activated users can see links. Click Here To Register...]
Re: Cum facem multiboot in ipbox 9000HD
salut, multumim si tine o tot asa . :)
ps: e nevoie de competitie . :)
"How to" cum sa trec la un firmware nou!!
Aceasta vă va arăta cum să instalaţi driver-usb-vă PC-ul in
1. Descărcaţi şi instalaţi flash tools (versiunea 1.0.2) program de pe PC-ul
2. Inchide trece prize pe partea din spate şi apăsaţi pe butonul de pornire / oprire (standby) de la partea din fata a acceptat (runda mare de stanga) pană cand veţi vedea de afişare (USB actualizare)
3. Conectaţi intre PC-ul si STB cu cablu USB
6. PC-ul detectează nou dispozitiv hardware (important), pentru a instala driverul USB
7. Driver Installation Wizard apare
8. Selectaţi "stabilirea unei liste sau o anumită locaţie (avansat)" şi apăsaţi "Next".
9. Selectaţi "Includeţi in această poziţie de căutare" şi faceţi clic pe "Căutare"
10. Desemnaţi in folderul C: / Program Files / Flash_tools) şi faceţi clic pe "Next"
11. Expertul va arăta pentru fişierul de driver.
12. Selectaţi USB PENTRU Vesta - C: / Windows / Inf / vestausb.inf şi faceţi clic pe "Next"
12,1. Dacă sistemul de fişiere solicită, in unele cazuri, Navigarea C: / Program Files / Flash_tools / vestausb şi faceţi clic pe "OK"
13. Faceţi clic pe "Finish" atunci cand acest lucru este făcut.
Important: Această comandă este foarte important; Vă rugăm să urmaţi instrucţiunile pas cu pas.
In cazul in care este instalat cu succes, este gata să descărcaţi cel mai recent upgrade de la STB
FTP conection 9000HD with PC
1)Make download this file.
2)After you can go to this site and you will find all the information
about to do a conection with ftp
3)You can transfer files and how you can you can see in this site.
The settings you can transfer in /var
The key in /var/key
And the config for the sharing in /var/keys
***Cum sa activezi pe sloturi interne****
1) face download pe file care dau mai jos...
2)Face Unrar.
3)Instalezi la ipbox pe ipbox 9000HD mgcamd-newcs si nu pe simplu mgcamd.
4)Te conectezi cu ipbox prin ftp....
5)Faci copy pe mg.cfg si newcamd.list care sunt la files care ai facut download in /var/key,iar pe newcs.cfg il faci copy in /var/tubox/config daca utilizezi pe sifteam.Daca utilizezi pe NLB atunci faci copy pe toate 3 files in var/key.
6)Bagi pe carta care ai cu chip jos in slot (mai bine prefera pe al doila slot).
7)Face restart in ipbox si dupa mergi la un canal din provider de la carta astepti putin si face lumina
You may find a text line like this ":sout=#transcode{vcodec=mp2v,vb=1024,scale=1,acod ec=mpga,ab=192,channels=2
}:duplicate{dst=std{access=udp,mux=ts,dst=224.1.1. 2:1234}}" on the top of Stream output option window. At the front of "vcodec=mp2v", put "fps=25,". Then result may be going to be like this":sout=#transcode{fps=25,vcodec=mp2v,vb=1024,s cale=1,acodec=mpga,ab=192
,channels=2}:duplicate{dst=std{access=udp,mux=ts,d st=224.1.1.2:1234}}"
Streaming out DVD >
# Using Multicast
Re: "How to" cum sa trec un firmware nou!!
Procedura este pentru conectare PC-IPBOX prin cablu usb.
In cazul in care nu aveti un asemenea cablu (eu nu am avut) se poate utiliza procedura originala de update data de producator.
Se redenumeste fisierul in usb_update.img.
Se copiaza pe stick.
Se conecteaza stick-ul la box.
OFF din spate, ON din spate concomitent cu apasare on/off din fata si la aparitia BOOTING pe ecran se apasa sageata sus de pe panou frontal.
Apare USB UPGRADING si la sfirsit DONE.
OFF din spate si apoi porneste imaginea noua.
Atentie la imaginea utilizata.
Daca nu e pentru 900HD da error. ([Only registered and activated users can see links. Click Here To Register...])
Tested diseq 1.1 with emp centauri 8 input
6 satellites
eutelsat 7east ( input 1 in diseqC switch ) input A at receiver settings and uncommited switch 1
hotbird 13 east ( input 2 in diseqC switch ) input B at receiver settings and uncommited switch 1
Astra 2a-b-d 28.2 east ( input 3 in diseqc ) input C at receiver and uncommited switch 1
Astra 19.2 east ( input 4 in diseqC ) input D at receiver and uncomitted switch 1
Hellasat 39 east ( input 5 in diseqC ) input A at receiver and uncommited switch 2
Badr 26 east ( input 6 in diseqC ) input B at receiver and uncommited switch 2
if i had 2 more satellites, i should configure them as input C at receiver and uncommited switch 2 and finally the last one input D at receiver and uncommited switch 2
Thats all
Probleme cu tuner cable si terestrial
Aica scrie pe metoda cum se poate sa faceti sa functioneaza tuner cable si terestrial care au probleme.Asta tuner se schimba gratis de la abcom.Daca din pacate aveti o versiuna din asta (revizia) cititi pe pdf mai jos.
"how To" Ipbox 900&9000hd
Aica o sa gasiti primul manual "how to" pt ipbox 900&9000HD.Care explica primele lucruri care trebuie sa faceti cu aparatul asta.Este in format PDF.
**Astept pm cu intrebarii sau probleme care au aparut"
"how To" Cum instalez o imagina la ipbox 900HD
How to cum instalez o imagina la ipbox 900HD
Multumesc pe SNOW
"HOW TO" pentru MBOX 0.4 ca sa face reshare!!
"Cum trebuie sa fie C: line in cwshare.cfg"
c lines in cwshare.cfg
C: { 127.0.0.1 34000 dummy dummy 01 02 03 04 05 06 07 08 09 10 11 12 13 14 }
C: { 127.0.0.1 34001 dummy dummy 01 02 03 04 05 06 07 08 09 10 11 12 13 14 }
C: { 127.0.0.1 34002 dummy dummy 01 02 03 04 05 06 07 08 09 10 11 12 13 14 }
34000 lower slot (prima linia e pt slot de jos)
34001 upper slot (al doila linia e pt slot de sus)
34002 phoenix external cardreader (al treila linia e pt phoenix)
Liniile trebuie sa se corespunde cu poarte care avem la newcs pt cartele
Code:
<readers name="Card Readers">
<device>
<name>lower</name>
<type>Sci</type>
<node>/dev/sci0</node>
<newcamd_port>34000</newcamd_port>
<autosid>yes</autosid>
<priority>round</priority>
</device>
<device>
<name>upper</name>
<type>Sci</type>
<node>/dev/sci1</node>
<newcamd_port>34001</newcamd_port>
</device>
<device>
<name>Phoenix Interface</name>
<type>phoenix</type>
<mhz>357</mhz>
<node>/dev/tts/0</node>
<newcamd_port>34002</newcamd_port>
<autosid>Yes</autosid>
<Seca-PPV>no</Seca-PPV>
<pincode>0000</pincode>
</device>
</readers>and three times a xxxxx.list named
Dupa facem trei files cu nume 34000.list (pt slot de jos), 34001.list (pt slot de sus) , 34002.list ( pt phoenix important pt ei care au ipbox 900).Fiecare files contine asta:
34000.list
contine
SF: { 0000 } ->for whole package
34001.list
contine
34002.list
contine
si pe toate asta trei files il bagam la /var/keys
Cu ultima versiuna merge ok!Daca nu merge cartela noastra atunci trebuie sa modificam ce contine file xxx.list.Chestie care o sa facem mai incolo.Daca aveti numai o carta sau doi folositi pe setings numai pt o poarta.
Re: "HOW TO" si EROARE pt IPBOX 900&9000
nu-mi e pra clar, din ce-ai postat tu acolo 3401 vien pentru pheonix
si care sunt cele trei "files" care trebuie introduse in keys?
Faci un files pt ei care au phoenix. xxx.list (xxx=poarta care foloseste cartela la newcs)
La file asta punem pe linia mai jos....
daca nu merge cartela trebuie sa adaugam inca ceva setarii care o sa scrim mai terziu
***functioneaza numai cu ultima versiuna lui mbox 0.4 0003 ****
"HOW TO" pentru FLash tools.
Flash tools 1.0.2
1)Facem download pe file care dau mai jos.
2)Facem unzip pe file si il instalam la PC.
3)Pornim pe program si apare imagina de mai jos.
4)Alegem USB decit SERIAL.
5)Dupa apasam pe buton FILE care e dreapta.Si se deschide un meniu care cere sa gasim pe file cu FIRMWARE care dorim sa instalam.
6)Dupa ce alegem pe file si vedem ca e incarcat la flash tools.Conectam pe ipbox cu PC cu un cablu USB.
7)Inchidem pe ipbox din spate.Si il pornim din nou din spate dar la aceas timp apasam si butonul on/off care e in fata si nu il lasam pina sa afiseaza USB UPGRADE.
8)Calculatorul cere niste drivers ca sa recunoaste pe IPBOX.Asta drivers sunt la plic acolo unde e instalat la pc flash tools.
9)Dupa ce terminam cu drivers,apasam pe buton Down.Si asteptam sa se face bara lui flash tools 100%.
10)Atentie!!Nu a terminat upload de firmware.Se uitam la display de ipbox si asteptam sa termina cu ERASE si cu FLASH si numai cind apare DONE.Atunci inchidem pe ipbox din spate si il pornim din nou.Si vedem ca avem pe nou firmware instalat.
"HOW TO" flash tools 1.0.2
Aici o sa gasiti un how to cu foto pt flash tools 1.0.2.Si cum facem upload un nou firmware.
