Enigma 2 pe Kathrein UFS-910
Duck Tales Enigma2 for Kathrein UFS910 OLD VERSION !!!!!!!!!!
team DuckTales proudly presents the first enigma2 alpha image for Kathrein UFS-910.
This image should be seen as a proof of concept - there are many bugs and some hardware
which is not supported at the moment. If you are a developer, and you have experience in
(embedded)hardware/linux-dvb-api coding feel free to contact us - you're welcome!
To test this enigma2 image you need a running nfs server and a serial & network
connection to the receiver.
1. extract the tgz file on the server and set the directory in /etc/exports
for example:
/nfs/target_enigma2 192.168.0.0/24(rw,no_root_squash,sync,no_subtree_check)
2. restart nfs server
3. connect via serial console to the receiver
4. turn on the receiver and hit enter in serial console
you should see the following prompt:
Hit any *** to stop autoboot: 0
STB7100-REF>
5. customize the follwoing settings to your network environment and type them into the
serial console (without the doublequotes):
"set ipaddr '192.168.0.25'"
"set serverip '192.168.0.1'"
"set gateway '192.168.0.1'"
7. to set the bootargs also type:
"set bootargs 'console=ttyAS0,115200 root=/dev/nfs nfsroot=/nfs/target_enigma2 rw ip={$ipaddr}:{$serverip}:{$gateway}:255.255.255.0:kathrein:eth0:off mem=64m coprocessor_mem=4m@0x10000000,4m@0x10400000 nwhwconf=device:eth0,hwaddr:${ethaddr}'"
"setenv bootcmd 'nfs a5000000 {$serverip}:/nfs/target_enigma2/boot/uImage;bootm a5000000'"
where /nfs/target_enigma2 is the directory you added to /etc/exports
8. to save the settings type "saveenv"
9. simply type "boot" or restart the receiver with the power-switch. now enigma2 should boot.
greetings from team DuckTales
ONLY devs can contact us at [Only registered and activated users can see links. Click Here To Register...]
Porneste de pe NFS.
Nu merge decat cu FTA.
Nu scaneaza.
Are iesirea video in format 570i si unele televizoare cu HDMI sau DVI nu o suporta.
Merge insa pe SCART pe orice TV.
Se misca natural.
Voi continua cu un tutorial.
Cateva ecrane de pe enigma 2 pe UFS-910
[Only registered and activated users can see links. Click Here To Register...][Only registered and activated users can see links. Click Here To Register...][Only registered and activated users can see links. Click Here To Register...]
Re: Enigma 2 pe Kathrein UFS-910
Asta inseamna ca in o luna - doua o sa merga si pe kathy gbox si ccam....viitorul sun bine :)
Poate si pe IPbox9000 si atunci o sa sune si mai bine !!
Nu pot sa cred ca o firma ca ipbox scoate doi modele HD 900,9000 si o sa lasa fara suport la firmware!!Eu din ce am inteles si din ce am vorbit cu sifteam deja lucreaza pt enigma 2 pt ipbox.
se poate descarca vers BA pentru pornirea Enigma2. Este nevoie de NFS server de linux, How-To 11, despre setarile fisierului bootp.conf.
A aparut Enigma E2-317 pentru Flash, doar pt. cei versati care sint in stare sa-si reanimeze receiverele in caz de crash.
Functioneaza stabil pe vers. 1W + HDMI 720P
DAS IMAGE LAEUFT STABIL AUF EINER 1W KATHI AN HDMI MIT 720P. HIER TRETEN KEINE PROBLEME AUF.
BEI ANDEREN KONIFGURATIONEN KANN ES ZU PROBLEMEN FUEHREN, WELCHE ABER MIT MEHRFACHEM BOOTEN GELOEST WERDEN KANN. MEHRFACH KANN BIS 20 SEIN!!
e2-kf-317 pe Kathrein UFS-910
Au aparut aseara cele 2 versiuni de flash si USB, scoase de o echipa de care nu am mai auzit pana acum. Se bazeaza tot pe imagine TDT.
E o imagine scoasa la repezeala.
Merge Mbox perfect pe ea.
Si ca sa aveti ce face:
Versiunea [Only registered and activated users can see links. Click Here To Register...] care merge ca si partitie in stickul facut cu KCC.
Versiunea de [Only registered and activated users can see links. Click Here To Register...].
Inca sunt mari probleme cu erorile de scriere pe stick.
Va astept cu primele impresii.
Translation: German » English
Content:
- Warning
- README.tdt
- HOWTO-E2-Flash
- HOWTO-E2-USB
- Notfallscenario thread
WARNING!
The Flash image is to be regarded as a beta. It is only for experienced hobbyist to recommend.
So if you are not from the E2, or stick with our description running brings, is strongly recommended to the fingers to inform.
Next - who no console port with putty and not with telnet know which finger should leave.
Before we approach the flashing dares to be the emergency scenario exactly studied and understood. Lieber in a thread ask before you loslegt.
THE IMAGE IS STABLE AT A 1W Kathi WITH AN HDMI 720P. HERE If there are no problems.
FOR ANOTHER KONIFGURATIONEN CAN cause problems, BUT WITH WHAT MANY BOATS can be resolved. SEVERAL TO 20 MAY BE!
THE KF_TEAM ASSUMES NO RESPONSIBILITY FOR faulty equipment:
THE GUARANTEE MAY LOSE GO!
Those who still turn up here is to understand something of the matter is his or Kathi sorry.
In both cases, we wish much fun with the Flash version of E2-317
The KF-team 19th October 2008
Notfallscenario
FLASH RECOVERY E2 to ORGIMG
If the box is full zerschossen, except since uboot still is.
I did it with the flavor of good altbewerten made ufs910config1.1 tools.
So that it can everybody.
What do I do if only the uboot is loaded
1st ufs910config1.1 loader
2nd Unpacking
3rd setup_ufs910config.exe dan install and start the installed tool
3rd com recruit
4th Setting ips
5th check
6th functions -> restoring Notfallimg
7th Simply follow the instructions.
Additional Information
emergency.ub is included in the packet
their needs can stick
precaution, the stick is automatically formatted
you need information flashimg z.b KF-106 or AAF 2.0e
you need only give the bootargs manually adjust.
Release Notes:
A big thanks to the tireless work of the TDT!
Without them this would never have been possible.
Changes since (Sat, 11 Oct 2008)
319 Little fix in mediaplayer
318 fixed standy-green screen bug, thx to divans tester
317 bb make fix
316 placebo for busybox.mk
315 busybox upgrade to 1.11.2
314 Added DVB-S2 support too SatFinder
313 tuxtxt major fixes, new font, kill tuxtxt if e2 crashes
312 fixes for moderate softstandby
Picon 311 new channels for kids
310 new button-GRAFIX
309 new button-GRAFIX
308 added cool effect in vfd on e2 startup, and extend vfd python interface: vfd_set_brightness (0-7), vfd_set_light (0-1)
307 Fixed vfd driver
Added 306 vfd customchar patch by nebman 2008/02/01
see link: [Only registered and activated users can see links. Click Here To Register...]
Changes by KF Team
- Add fw_printenv for 1rst and 2nd bootloader
- Changed rcS to source all kinds
- / Var / etc / start_config contains switches for startup rpogram y / n
- Added Dropbear
- Added aafusbmount.sh
Flash version additional
- Modified fstab to mount mtdblock6
- Reduced to Languague en ge
- Stripped of all unneeded and pyo py
- Added links to rw part for plug-ins and settings
E2 Flash HOWTO
E2 flash howto rev317
Warning:
This may be erroneous to lead a useless box. Those with no experience with E2 from the USB stick and console via serial cable has, it should not try.
The Flash image is rather full and does not allow additions without being a USB stick installs correctly. Will this trozdem tries, it may be that the box is no longer correct boots.
Sender lists with 2 satellites should be no space problems, but more satellites must be used very carefully with the Plaz be dealt with.
Precondition
- An E2-image, which is on 2nd boot from the USB stick boots. It is an advantage if the possible revision of the image is equal to 317. Here in the forum is an appropriate image>> Here invite <<.
- There is a kernel image for a Flash version with 317 and 2nd-boat used or needed. This is in the package.
uImage-317.2nd
- Unpacking the image parts with rare
a rare E2F-kf-317-2nd.rar
Procedure
1st The stick in the box and E2 from the USB stick boot
2nd UImage the kernel-image 317.2nd and parts on the box copy
ftp <ip-der-ufs910>
am
Put uImage-317.2nd
Put mtdblock3.root-stock.enigma2
Put mtdblock6.var-stock.enigma2
3rd On the login box
telnet <ip-der-ufs910>
4th Old kernel secure
cd / boot
mv uImage uImage.orig
5th Install new kernel
mv / tmp/uImage-317.2nd uImage
6th Sync
sync
7th Box reboot with this kernel
reboot-f
Box off and embroidery from the new boot.
8th Correctness of the kernel check
cat / proc / mtd
Should look like
mtd0: 00020000 00010000 boot firmware: 0xA000.0000-0xA001.FFFF "
mtd1: 001e0000 00010000 "kernel - 0xA004.0000-0xA021.FFFF"
mtd2: 00010000 00010000 "Config FS - 0xA022.0000-0xA022.FFFF"
mtd3: 00b30000 00010000 "Root FS-0xA023.0000-0xA0D5.FFFF"
mtd4: 00010000 00010000 "APP_Modules 0xA0D6.0000-0xA0D6.FFFF"
mtd5: 00010000 00010000 "EmergencyRoot 0xA0D7.0000-0xA0D7.FFFF"
mtd6: 00240000 00010000 "Other Data 0xA0D8.0000-0xA0FB.FFFF"
mtd7: 00020000 00010000 "Boot Configuration 0xA002.0000-0xA003.FFFF"
mtd8: 00010000 00010000 "2nd Boot Configuration 0xA0FC.0000-0xA0FC.FFFF"
mtd9: 00030000 00010000 "2nd boot firmware: 0xA0FD.0000-0xA0FF.FFFF"
mtd10: 00fc0000 00010000 "where Flash / bootloader 0xA004.0000-0xA0FF.FFFF"
It is important mtd1 with 001e0000
mtd3 with 00b30000
and mtd6 with 00240000
mtd7-9 and present
9th IMPORTANT! Stopping processes
pkill rcS
pkill Enigma2
he last command may not Enigma2 process with show
If they do, kill the run again.
10th Image parts Catt
ACHTUNGi! can then only with the appropriate instructions Originaimage geflascht be.
It takes a while the first block!
mtdblock3.root cat-Enigma2> / dev/mtdblock3
mtdblock6.var cat-Enigma2> / dev/mtdblock6
cat / boot / uImage> / dev/mtdblock1
11th Verifying
mount-t jffs2 / dev/mtdblock6 / mnt
ls / mnt
Files must show and no error message
vi / mnt / etc / resolv.conf
This is the right gateway or DNS entry
umount / mnt
squashfs mount-t-o ro / dev/mtdblock3 / mnt
ls / mnt
umount / mnt
If mistakes are here again 7 or even 3rd
12th New bootargs on the 2nd-placed boat
Via serial connection and putty the boot process interrupt
Immediately after reboot enter button repeatedly press
if the boot prompt comes back and press enter.
It should ufs910> as a prompt to appear
setenv ipaddr <deine-ip>
setenv serverip <ip-des-nfs-oder-tftp-server>
setenv gateway <gatewayip>
setenv netmask <networkscreen>
setenv bootargs' console = ttyAS0, 115200 root = / dev/mtdblock3 ip = $ ipaddr: $ serverip: $ gateway: $ netmask: Kathrein: eth0: off mem = 64m coprocessor_mem = 4m @ 0x10000000, 0x10400000 rootdelay 4m @ = 1 = nwhwconf device: eth0, HWaddr: $ ethaddr '
setenv bootcmd bootm a0040000
saveenv
13th Restart
boot
You should now see the box from the flash boats.
If it does not start in the first go - wait 20 seconds, then stop. Wait 20 seconds and turn on.
Since your yes 2nd boat had been in operation, you can always boot from the stick. This box set, wait until the chase is once by (1rst bootloader) and then the exit button up "custom boot" is displayed. At the 14W is the Options button.
Have fun wants the KF-team
E2-USB HOWTO
E2-USB howto rev317
Warning:
This may be erroneous to lead a useless box. Those with no experience with USB stick and console via serial cable has, it should not try.
Precondition
- KF-1.06-mod 2nd boot on the Flash - KF-1.06-mod or equivalent image.
- There is a kernel image for a Flash version with 317 and 2nd-boat used or needed. This package is in / boot / uImage
- IP addresses in Preferences / Network adapt
- E2-kf-317-usb.tar.rar
Procedure
1st A USB flash drive with 2 partitions vfat and once again create ext2.
2nd e2-kf-317-usb.tar.rar on Partition 2 unwrap.
3rd Stick with the KF-1.06 booted box stuck.
4th Vfat kernel to copy
mount-t vfat / dev/sda1 / mnt
mkdir / mnt / boot
cp / boot / uImage / mnt / boot
5th Sync
sync
6th Bootargs for Enigma2 set by the stick.
In addition to the script / config/enigma2.sh of KF-1.06 take.
The script adjust if necessary.
sh / config/enigma2
7th Bootargs of 1rst bootloader and 2nd-check Bootload
/ config / fw_printenv
Shows the Bootargs from 1rst boat.
we need
bootcmd = go a0fd0000
to be
/ usr / sbin / fw_printenv
Shows the Bootargs from 2nd
Here, it should look like
bootcmd = bootm a0040000
ethaddr = 00:1 d: ec: 00:00:00
serverip = 192.168.1.100
ipaddr = 192.168.1.101
gateway = 192.168.1.1
netmask 255.255.255.0 =
bootargsusb = set bootargs console = ttyAS0, 115200 root = / dev/sda1 rw init = / bin / devinit ip = $ ipaddr: $ serverip: $ gateway: $ netmask: Kathrein: eth0: off mem = 64m coprocessor_mem = 4m @ 0x10000000, 4m @ 0x10400000 rootdelay = 10 = nwhwconf device: eth0, HWaddr: $ ethaddr
bootargsusb = run bootusb; usb reset; ext2load usb 0:1 a5000000 boot / uImage; bootm a5000000
bootcmdcustom = run bootusb
bootargs = console = ttyAS0, 115200 root = / dev/mtdblock3 ip = 192.168.1.101:192.168.1.100:192.168.1.1:255.255.255.0: Kathrein: eth0: off mem = 64m coprocessor_mem = 4m @ 0x10000000, 0x10400000 rootdelay 4m @ = 1 nwhwconf = device: eth0, HWaddr: 00:1 d: ec: 00:00:00
8th Box asusschalten
9th Box set - wait until chases are done once,
then Exit (Option button 14W) to press "custom boot" appears, then release.
You should now see the box from the USB stick to boot.
If it does not start in the first go (leave longer than 60 seconds when loading stand E2) - wait 20 seconds, then stop. Wait 20 seconds and turn on.
Drueckt no button when you turn on, then booted the flash.
If you have trouble booting from Flash occur all the sticks away and then boot.
Q: How can I recover the first loader use?
A: KF-1.06-mod flash of boats and over telnet / config / fw_setenv bootcmd bootm a004000
Re: e2-kf-317 pe Kathrein UFS-910
Niste foto se poate?va rog!
Fotos ar fi de culoare verde! Da errors pe banda rulanta. Nu se poate modifica nimic in meniu.
Singurul lucru pozitiv, cum a spus si @zildan, e faptul ca merge mbox pe ea.
AAF-team lucreaza in paralel la un image cu mbox.
Rabdare... :)
Dupa multe peripetii am reusit sa stabilizez aceasta versiune.
Cateva sfaturi:
1. Problemele mari sunt la instalare datorita pierderii de date la dezarhivare.
2. (EDIT) nu mai Recomand formatarea ext3 ( comanda de incarcare kernel e2 se da cu ext2 si nu mai veede partitia).
3. Skynul cu care vine nu merge bine cu alt settings asa ca se schimba din meniu cu skynul default.
4. Se pune DNS din meniu.
5. La restart uneori nu face initializarea la USB si in consecinta nu porneste, daca nu ia un power off.
6. Se copiaza mbox-enigma.sh40 in /var/keys, si cwshare.cfg, mbox.cfg, portlist in /var/keys
7. Se poate pune comanda de pornire mbox in /etc/init.d/rcS sau alt script de acolo.
Concluzia finala: MERGE, dar nu e inca pt cei care nu au nervi, timp si cunostinte de linux.
Am observat ca au modificat alocarea ram-ului, in sensul ca acum apar 45 mega de ram, deci au redus de la video, diferenta pana la 64 fiind alocata video.
Image Info
Enigma2 Team Ducktales Build rev356 AAF Mod 3.0
Basis Team Ducktales Build rev356 vom 20.10.2008
Changelog seit letzten offentlichen Release:
Aenderungen seit E2 rev254 AAF Mod 2.0:
Team Ducktales:
+ Neuer Grafiktreiber fur bessere Bildqualitaet
+ Neuer PTI Treiber mit Hardwaredescrambling Support fur CA1
+ Sonderzeichen in Tuxtxt (Videotext) funktionieren
+ Neue Schriftart im Tuxtxt fur bessere Lesbarkeit
+ VFD Unterstutzung fur eiegene Zeichen
+ VFD Helligkeitsregelung eingebaut
+ Softstandby Fixes
+ Mediaplayer ubernimmt Seitenverhaeltnis von TV Modus
+ Sendernamen bei Premiere Direkt
+ Seitenverhältnis bei 1440x1080 fixed
+ Speicheroptimierung fur mehr Stabilitaet
+ DVB-S2 Support im SatFinder
+ Symbolrate 30000 Problem behoben
+ Audio Problem bei Untertiteln behoben
+ Player aktualisiert
AAF:
+ CAM Setup Menu
+ OSD Snapshot Funktion im Menu
+ aktuelles vfdctl 0.7.1 eingebaut
Danke an Team Ducktales fur das super Basis Image, das gesamte AAF Team, obiwatn76, black_64, ewgene fur seine Skin Arbeit und alle die Dieses Image ermoeglicht und getestet haben.
Sa speram ca Enigma2 Team Ducktales Build rev356 AAF Mod 3.0 e mai stabila.
Are si asta emu meniu.
Cred ca cei de la KF-team (kathi-forum) au vrut sa fie primi care integreaza emu in image si au scos la repezeala ceva...acolo...sa fie.
Enigma2 merge perfect pe HDD SATA intern.
Se misca mult mai bine decat pe stick.
Totul e parca mai vioi. Se pare ca nu se mai pierd fisiere, nu mai da erori de scriere.
Merge excelent si pe hard disk usb, la hdd sata are driver in kernel,
il vede direct?
Ai pus mufa pe placa, este sursa de 1W?
Cum ai reusit sa instalezi BA pe hdd usb ca la mine nu-l vede KCC?
Multumesc!
@blondu
1w sau 14W e puterea in standby, eu am recepror de 1w si am pus mufa sata pe placa. Nu alimentez hardul din receptor, dar se poate pune si merge bine.
@nflorin
Daca itzi vede linuxul hdd il vede si kcc.
Nu instala cu meniul BA, intra la expert in cazul hdd-urilor sau stick-urilor de dimensiuni mai mari.
Trebuie sa deschidem un thread cu tutorial de instalare e2. Am asteptat sa apara KCC mai bun si e2 mai stabila.
