Am instalat oscam. Porneste, il pot vedea in webif, dar se opreste dupa 5-6 secunde si nu il mai pot accesa. Il pot porni iar, dar face la fel.
Imagine Pure2. Nu-i dau de cap.
script oscam auto start si cronjob enigma 2
in log ce zice? porneste-l cu debug...si vezi in loguri unde se impiedica...
Vad ca merge cu niste settings mai vechi..
Edit: dupa reboot iarasi nu merge.
Cum pornesc cu debug?
Deci, am pus imaginea si tot de la 0. Am instalat din feed oscam, am pus toate fisierele cu care a mers atatia ani. Oscam porneste dupa care se opreste in 3-4 secunde.
Nu mai stiu ce sa fac.
Cum e cu debug? Am bifat in setarile receptorului "enable debug log". Nu gasesc nicaieri tutorial.
Am facut cu telnet:
init 4enigma2
Imi da un sir lung de linii.
---------- Post added at 22:13 ---------- Previous post was at 21:38 ----------
Am reusit sa am un fisier debug.log dar nu inteleg nimic din el :D
urca-l undeva...sau posteaza aici cel putin ultimele rinduri din log... sau porneste-l cu parametrii:
ConfigDir : /usr/local/etc
Usage: oscam [parameters]
Directories:
-c, --config-dir <dir> | Read configuration files from <dir>.
. Default: /usr/local/etc
-t, --temp-dir <dir> | Set temporary directory to <dir>.
. Default: /tmp/.oscam
Startup:
-b, --daemon | Start in the background as daemon.
-B, --pidfile <pidfile> | Create pidfile when starting.
-r, --restart <level> | Set restart level:
. 0 - Restart disabled (exit on restart request).
. 1 - WebIf restart is active (default).
. 2 - Like 1, but also restart on segfaults.
-w, --wait <secs> | Set how much seconds to wait at startup for the
. system clock to be set correctly. Default: 60
Logging:
-I, --syslog-ident <ident> | Set syslog ident. Default: oscam
-S, --show-sensitive | Do not filter sensitive info (card serials, boxids)
. from the logs.
-d, --debug <level> | Set debug level mask used for logging:
. 0 - No extra debugging (default).
. 1 - Detailed error messages.
. 2 - ATR parsing info, ECM, EMM and CW dumps.
. 4 - Traffic from/to the reader.
. 8 - Traffic from/to the clients.
. 16 - Traffic to the reader-device on IFD layer.
. 32 - Traffic to the reader-device on I/O layer.
. 64 - EMM logging.
. 128 - DVBAPI logging.
. 256 - Loadbalancer logging.
. 512 - CACHEEX logging.
. 1024 - Client ECM logging.
. 2048 - CSP logging.
. 4096 - CWC logging.
. 65535 - Debug all.
Ultima parte:
23:56:00.9950 File "/usr/lib/enigma2/python/skin.py", line 1870, in processWidget
23:56:00.9951 KeyError: 'title'
23:56:00.9953
During handling of the above exception, another exception occurred:
23:56:00.9954 Traceback (most recent call last):
23:56:00.9955 File "/usr/lib/enigma2/python/skin.py", line 2030, in processScreen
23:56:00.9955 File "/usr/lib/enigma2/python/skin.py", line 1872, in processWidget
23:56:00.9956 skin.SkinError: [Skin] Error: Component with name 'title' was not found in skin of screen 'Menu'!
23:56:00.9971 [Skin] Error: Attribute 'name' with value '' in object of type 'eLabel' ('AttributeParser' object has no attribute 'name')!
23:56:00.9973 [Screen] Warning: Skin is missing element 'menuimage' in <class 'Screens.Menu.Menu'>.
23:56:00.9987 [Skin] Processing screen 'MenuSummary' from list 'MenumainmenuSummary, menu_mainmenuSummary, MenuSummary, Menumainmenu_summary, menu_mainmenu_summary, Menu_summary, ScreenSummary, SimpleSummary' position=(0,0), size=(480,320) for module 'MenuSummary'.
23:56:00.9999 [Screen] Showing screen '['MenumainmenuSummary', 'menu_mainmenuSummary', 'MenuSummary', 'Menumainmenu_summary', 'menu_mainmenu_summary', 'Menu_summary', 'ScreenSummary', 'SimpleSummary']'.
23:56:01.0109 [Skin] Processing screen 'IconWall_4x3' position=(0,0), size=(1920,1080) for module 'IconWall_4x3'.
23:56:01.0246 [Skin] Error: Attribute 'name' with value '' in object of type 'eLabel' ('AttributeParser' object has no attribute 'name')!
23:56:01.0343 [Skin] Processing screen 'IconWall_4x3_summary' from list 'IconWall_4x3Summary, IconWall_4x3_summary, SimpleSummary' position=(0,0), size=(480,320) for module 'SimpleSummary'.
23:56:01.0346 [Skin] Error: Screen 'IconWall_4x3_summary' widget 'widget' [Skin] Error: The source 'parent.menu' was not found in screen 'IconWall_4x3_summary'!!
23:56:01.0366 Traceback (most recent call last):
23:56:01.0367 File "/usr/lib/enigma2/python/skin.py", line 2030, in processScreen
23:56:01.0368 File "/usr/lib/enigma2/python/skin.py", line 1906, in processWidget
23:56:01.0368 skin.SkinError: [Skin] Error: The source 'parent.menu' was not found in screen 'IconWall_4x3_summary'!
23:56:01.0375 [Screen] Showing screen '['IconWall_4x3Summary', 'IconWall_4x3_summary', 'SimpleSummary']'.
23:56:01.0471 [Screen] Showing screen 'IconWall_4x3'.
23:56:01.2109 [eRCDeviceInputDev] 0 8b 1
23:56:01.2113 [InfoBarGenerics] Key 'KEY_MENU' (139) Break.
23:56:01.8267 [eRCDeviceInputDev] 1 6c 1
23:56:01.8271 [InfoBarGenerics] Key 'KEY_DOWN' (108) Make.
23:56:01.8274 [ActionMap] Map screen 'N/A' context 'DirectionActions' -> Action 'down'.
23:56:02.0588 [eRCDeviceInputDev] 0 6c 1
23:56:02.0592 [InfoBarGenerics] Key 'KEY_DOWN' (108) Break.
23:56:02.1707 [eRCDeviceInputDev] 1 160 1
23:56:02.1710 [InfoBarGenerics] Key 'KEY_OK' (352) Make.
23:56:02.1712 [ActionMap] Map screen 'N/A' context 'OkCancelActions' -> Action 'ok'.
23:56:02.1779 [Skin] Processing screen 'Menu' from list 'Menusetup, menu_setup, Menu' position=(0,0), size=(1920,1080) for module 'Menu'.
23:56:02.1784 [Skin] Error: Screen 'Menu' widget 'widget' [Skin] Error: Component with name 'title' was not found in skin of screen 'Menu'!!
23:56:02.1820 Traceback (most recent call last):
23:56:02.1821 File "/usr/lib/enigma2/python/skin.py", line 1870, in processWidget
23:56:02.1821 KeyError: 'title'
23:56:02.1822
23:56:02.1823 Traceback (most recent call last):
23:56:02.1823 File "/usr/lib/enigma2/python/skin.py", line 2030, in processScreen
23:56:02.1825 File "/usr/lib/enigma2/python/skin.py", line 1872, in processWidget
23:56:02.1825 skin.SkinError: [Skin] Error: Component with name 'title' was not found in skin of screen 'Menu'!
23:56:02.1839 [Skin] Error: Attribute 'name' with value '' in object of type 'eLabel' ('AttributeParser' object has no attribute 'name')!
23:56:02.1841 [Screen] Warning: Skin is missing element 'menuimage' in <class 'Screens.Menu.Menu'>.
23:56:02.1847 [Skin] Processing screen 'MenuSummary' from list 'MenusetupSummary, menu_setupSummary, MenuSummary, Menusetup_summary, menu_setup_summary, Menu_summary, ScreenSummary, SimpleSummary' position=(0,0), size=(480,320) for module 'MenuSummary'.
23:56:02.1864 [Screen] Showing screen '['MenusetupSummary', 'menu_setupSummary', 'MenuSummary', 'Menusetup_summary', 'menu_setup_summary', 'Menu_summary', 'ScreenSummary', 'SimpleSummary']'.
23:56:02.1882 [Skin] Processing screen 'IconWall_4x3' position=(0,0), size=(1920,1080) for module 'IconWall_4x3'.
23:56:02.2031 [Skin] Error: Attribute 'name' with value '' in object of type 'eLabel' ('AttributeParser' object has no attribute 'name')!
23:56:02.2092 [Skin] Processing screen 'IconWall_4x3_summary' from list 'IconWall_4x3Summary, IconWall_4x3_summary, SimpleSummary' position=(0,0), size=(480,320) for module 'SimpleSummary'.
23:56:02.2095 [Skin] Error: Screen 'IconWall_4x3_summary' widget 'widget' [Skin] Error: The source 'parent.menu' was not found in screen 'IconWall_4x3_summary'!!
23:56:02.2117 Traceback (most recent call last):
23:56:02.2119 File "/usr/lib/enigma2/python/skin.py", line 2030, in processScreen
23:56:02.2119 File "/usr/lib/enigma2/python/skin.py", line 1906, in processWidget
23:56:02.2120 skin.SkinError: [Skin] Error: The source 'parent.menu' was not found in screen 'IconWall_4x3_summary'!
23:56:02.2126 [Screen] Showing screen '['IconWall_4x3Summary', 'IconWall_4x3_summary', 'SimpleSummary']'.
23:56:02.2214 [Screen] Showing screen 'IconWall_4x3'.
23:56:02.4029 [eRCDeviceInputDev] 0 160 1
23:56:02.4033 [InfoBarGenerics] Key 'KEY_OK' (352) Break.
23:56:03.2022 [eRCDeviceInputDev] 1 6a 1
23:56:03.2027 [InfoBarGenerics] Key 'KEY_RIGHT' (106) Make.
23:56:03.2030 [ActionMap] Map screen 'N/A' context 'DirectionActions' -> Action 'right'.
23:56:03.4227 [eRCDeviceInputDev] 0 6a 1
23:56:03.4232 [InfoBarGenerics] Key 'KEY_RIGHT' (106) Break.
23:56:03.4234 [eRCDeviceInputDev] 1 6a 1
23:56:03.4235 [InfoBarGenerics] Key 'KEY_RIGHT' (106) Make.
23:56:03.4237 [ActionMap] Map screen 'N/A' context 'DirectionActions' -> Action 'right'.
23:56:03.6236 [eRCDeviceInputDev] 0 6a 1
23:56:03.6241 [InfoBarGenerics] Key 'KEY_RIGHT' (106) Break.
23:56:03.6243 [eRCDeviceInputDev] 1 6a 1
23:56:03.6244 [InfoBarGenerics] Key 'KEY_RIGHT' (106) Make.
23:56:03.6246 [ActionMap] Map screen 'N/A' context 'DirectionActions' -> Action 'right'.
23:56:03.8549 [eRCDeviceInputDev] 0 6a 1
23:56:03.8554 [InfoBarGenerics] Key 'KEY_RIGHT' (106) Break.
23:56:03.9629 [eRCDeviceInputDev] 1 6c 1
23:56:03.9633 [InfoBarGenerics] Key 'KEY_DOWN' (108) Make.
23:56:03.9635 [ActionMap] Map screen 'N/A' context 'DirectionActions' -> Action 'down'.
23:56:04.1949 [eRCDeviceInputDev] 0 6c 1
23:56:04.1953 [InfoBarGenerics] Key 'KEY_DOWN' (108) Break.
23:56:04.2736 [eRCDeviceInputDev] 1 160 1
23:56:04.2740 [InfoBarGenerics] Key 'KEY_OK' (352) Make.
23:56:04.2743 [ActionMap] Map screen 'N/A' context 'OkCancelActions' -> Action 'ok'.
23:56:04.2806 [Skin] Processing screen 'Menu' from list 'Menusoftware_manager, menu_software_manager, Menu' position=(0,0), size=(1920,1080) for module 'Menu'.
23:56:04.2812 [Skin] Error: Screen 'Menu' widget 'widget' [Skin] Error: Component with name 'title' was not found in skin of screen 'Menu'!!
23:56:04.2847 Traceback (most recent call last):
23:56:04.2847 File "/usr/lib/enigma2/python/skin.py", line 1870, in processWidget
23:56:04.2849 KeyError: 'title'
23:56:04.2850
23:56:04.2850 Traceback (most recent call last):
23:56:04.2851 File "/usr/lib/enigma2/python/skin.py", line 2030, in processScreen
23:56:04.2851 File "/usr/lib/enigma2/python/skin.py", line 1872, in processWidget
23:56:04.2852 skin.SkinError: [Skin] Error: Component with name 'title' was not found in skin of screen 'Menu'!
23:56:04.2865 [Skin] Error: Attribute 'name' with value '' in object of type 'eLabel' ('AttributeParser' object has no attribute 'name')!
23:56:04.2867 [Screen] Warning: Skin is missing element 'menuimage' in <class 'Screens.Menu.Menu'>.
23:56:04.2923 [Skin] Processing screen 'MenuSummary' from list 'Menusoftware_managerSummary, menu_software_managerSummary, MenuSummary, Menusoftware_manager_summary, menu_software_manager_summary, Menu_summary, ScreenSummary, SimpleSummary' position=(0,0), size=(480,320) for module 'MenuSummary'.
23:56:04.2944 [Screen] Showing screen '['Menusoftware_managerSummary', 'menu_software_managerSummary', 'MenuSummary', 'Menusoftware_manager_summary', 'menu_software_manager_summary', 'Menu_summary', 'ScreenSummary', 'SimpleSummary']'.
23:56:04.2964 [Skin] Processing screen 'IconWall_4x3' position=(0,0), size=(1920,1080) for module 'IconWall_4x3'.
23:56:04.3111 [Skin] Error: Attribute 'name' with value '' in object of type 'eLabel' ('AttributeParser' object has no attribute 'name')!
23:56:04.3176 [Skin] Processing screen 'IconWall_4x3_summary' from list 'IconWall_4x3Summary, IconWall_4x3_summary, SimpleSummary' position=(0,0), size=(480,320) for module 'SimpleSummary'.
23:56:04.3179 [Skin] Error: Screen 'IconWall_4x3_summary' widget 'widget' [Skin] Error: The source 'parent.menu' was not found in screen 'IconWall_4x3_summary'!!
23:56:04.3202 Traceback (most recent call last):
23:56:04.3203 File "/usr/lib/enigma2/python/skin.py", line 2030, in processScreen
23:56:04.3203 File "/usr/lib/enigma2/python/skin.py", line 1906, in processWidget
23:56:04.3204 skin.SkinError: [Skin] Error: The source 'parent.menu' was not found in screen 'IconWall_4x3_summary'!
23:56:04.3211 [Screen] Showing screen '['IconWall_4x3Summary', 'IconWall_4x3_summary', 'SimpleSummary']'.
23:56:04.3288 [Screen] Showing screen 'IconWall_4x3'.
23:56:04.5059 [eRCDeviceInputDev] 0 160 1
23:56:04.5063 [InfoBarGenerics] Key 'KEY_OK' (352) Break.
23:56:07.0631 [eRCDeviceInputDev] 1 6c 1
23:56:07.0635 [InfoBarGenerics] Key 'KEY_DOWN' (108) Make.
23:56:07.0638 [ActionMap] Map screen 'N/A' context 'DirectionActions' -> Action 'down'.
23:56:07.2712 [eRCDeviceInputDev] 0 6c 1
23:56:07.2715 [InfoBarGenerics] Key 'KEY_DOWN' (108) Break.
23:56:07.2717 [eRCDeviceInputDev] 1 6c 1
23:56:07.2719 [InfoBarGenerics] Key 'KEY_DOWN' (108) Make.
23:56:07.2720 [ActionMap] Map screen 'N/A' context 'DirectionActions' -> Action 'down'.
23:56:07.5028 [eRCDeviceInputDev] 0 6c 1
23:56:07.5032 [InfoBarGenerics] Key 'KEY_DOWN' (108) Break.
23:56:07.6029 [eRCDeviceInputDev] 1 160 1
23:56:07.6033 [InfoBarGenerics] Key 'KEY_OK' (352) Make.
23:56:07.6035 [ActionMap] Map screen 'N/A' context 'OkCancelActions' -> Action 'ok'.
23:56:07.6086 [Skin] Processing screen 'Menu' from list 'Menuadvanced_software, menu_advanced_software, Menu' position=(0,0), size=(1920,1080) for module 'Menu'.
23:56:07.6091 [Skin] Error: Screen 'Menu' widget 'widget' [Skin] Error: Component with name 'title' was not found in skin of screen 'Menu'!!
23:56:07.6122 Traceback (most recent call last):
23:56:07.6123 File "/usr/lib/enigma2/python/skin.py", line 1870, in processWidget
23:56:07.6123 KeyError: 'title'
23:56:07.6124
23:56:07.6125 Traceback (most recent call last):
23:56:07.6125 File "/usr/lib/enigma2/python/skin.py", line 2030, in processScreen
23:56:07.6126 File "/usr/lib/enigma2/python/skin.py", line 1872, in processWidget
23:56:07.6127 skin.SkinError: [Skin] Error: Component with name 'title' was not found in skin of screen 'Menu'!
23:56:07.6138 [Skin] Error: Attribute 'name' with value '' in object of type 'eLabel' ('AttributeParser' object has no attribute 'name')!
23:56:07.6140 [Screen] Warning: Skin is missing element 'menuimage' in <class 'Screens.Menu.Menu'>.
23:56:07.6149 [Skin] Processing screen 'MenuSummary' from list 'Menuadvanced_softwareSummary, menu_advanced_softwareSummary, MenuSummary, Menuadvanced_software_summary, menu_advanced_software_summary, Menu_summary, ScreenSummary, SimpleSummary' position=(0,0), size=(480,320) for module 'MenuSummary'.
23:56:07.6161 [Screen] Showing screen '['Menuadvanced_softwareSummary', 'menu_advanced_softwareSummary', 'MenuSummary', 'Menuadvanced_software_summary', 'menu_advanced_software_summary', 'Menu_summary', 'ScreenSummary', 'SimpleSummary']'.
23:56:07.6176 [Skin] Processing screen 'IconWall_4x3' position=(0,0), size=(1920,1080) for module 'IconWall_4x3'.
23:56:07.6304 [Skin] Error: Attribute 'name' with value '' in object of type 'eLabel' ('AttributeParser' object has no attribute 'name')!
23:56:07.6359 [Skin] Processing screen 'IconWall_4x3_summary' from list 'IconWall_4x3Summary, IconWall_4x3_summary, SimpleSummary' position=(0,0), size=(480,320) for module 'SimpleSummary'.
23:56:07.6362 [Skin] Error: Screen 'IconWall_4x3_summary' widget 'widget' [Skin] Error: The source 'parent.menu' was not found in screen 'IconWall_4x3_summary'!!
23:56:07.6381 Traceback (most recent call last):
23:56:07.6382 File "/usr/lib/enigma2/python/skin.py", line 2030, in processScreen
23:56:07.6383 File "/usr/lib/enigma2/python/skin.py", line 1906, in processWidget
23:56:07.6384 skin.SkinError: [Skin] Error: The source 'parent.menu' was not found in screen 'IconWall_4x3_summary'!
23:56:07.6389 [Screen] Showing screen '['IconWall_4x3Summary', 'IconWall_4x3_summary', 'SimpleSummary']'.
23:56:07.6451 [Screen] Showing screen 'IconWall_4x3'.
23:56:07.8349 [eRCDeviceInputDev] 0 160 1
23:56:07.8353 [InfoBarGenerics] Key 'KEY_OK' (352) Break.
23:56:08.7647 [eRCDeviceInputDev] 1 160 1
23:56:08.7650 [InfoBarGenerics] Key 'KEY_OK' (352) Make.
23:56:08.7653 [ActionMap] Map screen 'N/A' context 'OkCancelActions' -> Action 'ok'.
23:56:08.7676 *********************+++++++++++++++++++++++++++++++++[BACKUPRESTORE] self.bacluppath is %s /media/hdd/
23:56:11.6759 [gRC] Warning: Main thread is busy, displaying spinner!
23:56:12.1350 [Skin] Processing screen 'RestoreMenu' position=(0,0), size=(1920,1080) for module 'RestoreMenu'.
23:56:12.1369 [Skin] Error: Screen 'RestoreMenu' widget 'widget' [Skin] Error: The source 'key_blue' was not found in screen 'RestoreMenu'!!
23:56:12.1389 Traceback (most recent call last):
23:56:12.1390 File "/usr/lib/enigma2/python/skin.py", line 2030, in processScreen
23:56:12.1390 File "/usr/lib/enigma2/python/skin.py", line 1906, in processWidget
23:56:12.1391 skin.SkinError: [Skin] Error: The source 'key_blue' was not found in screen 'RestoreMenu'!
23:56:12.1440 [Skin] Processing screen 'RestoreMenuSummary' from list 'RestoreMenuSummary, RestoreMenu_summary, SimpleSummary' position=(0,0), size=(480,320) for module 'SimpleSummary'.
23:56:12.1453 [Screen] Showing screen '['RestoreMenuSummary', 'RestoreMenu_summary', 'SimpleSummary']'.
23:56:12.1456 [Screen] Showing screen 'RestoreMenu'.
23:56:12.1461 [eRCDeviceInputDev] 0 160 1
23:56:12.1463 [InfoBarGenerics] Key 'KEY_OK' (352) Break.
23:56:12.7878 [eRCDeviceInputDev] 1 6c 1
23:56:12.7883 [InfoBarGenerics] Key 'KEY_DOWN' (108) Make.
23:56:12.7886 [ActionMap] Map screen 'N/A' context 'SetupActions' -> Action 'down'.
23:56:13.0198 [eRCDeviceInputDev] 0 6c 1
23:56:13.0202 [InfoBarGenerics] Key 'KEY_DOWN' (108) Break.
23:56:13.0574 [eRCDeviceInputDev] 1 6c 1
23:56:13.0576 [InfoBarGenerics] Key 'KEY_DOWN' (108) Make.
23:56:13.0578 [ActionMap] Map screen 'N/A' context 'SetupActions' -> Action 'down'.
23:56:13.2827 [eRCDeviceInputDev] 0 6c 1
23:56:13.2832 [InfoBarGenerics] Key 'KEY_DOWN' (108) Break.
23:56:13.2834 [eRCDeviceInputDev] 1 6c 1
23:56:13.2835 [InfoBarGenerics] Key 'KEY_DOWN' (108) Make.
23:56:13.2837 [ActionMap] Map screen 'N/A' context 'SetupActions' -> Action 'down'.
23:56:13.4940 [eRCDeviceInputDev] 0 6c 1
23:56:13.4944 [InfoBarGenerics] Key 'KEY_DOWN' (108) Break.
23:56:13.4946 [eRCDeviceInputDev] 1 6c 1
23:56:13.4948 [InfoBarGenerics] Key 'KEY_DOWN' (108) Make.
23:56:13.4949 [ActionMap] Map screen 'N/A' context 'SetupActions' -> Action 'down'.
23:56:13.7258 [eRCDeviceInputDev] 0 6c 1
23:56:13.7263 [InfoBarGenerics] Key 'KEY_DOWN' (108) Break.
23:56:14.0273 [eRCDeviceInputDev] 1 6c 1
23:56:14.0277 [InfoBarGenerics] Key 'KEY_DOWN' (108) Make.
23:56:14.0279 [ActionMap] Map screen 'N/A' context 'SetupActions' -> Action 'down'.
23:56:14.2227 [eRCDeviceInputDev] 0 6c 1
23:56:14.2231 [InfoBarGenerics] Key 'KEY_DOWN' (108) Break.
23:56:14.2234 [eRCDeviceInputDev] 1 6c 1
23:56:14.2235 [InfoBarGenerics] Key 'KEY_DOWN' (108) Make.
23:56:14.2236 [ActionMap] Map screen 'N/A' context 'SetupActions' -> Action 'down'.
23:56:14.4548 [eRCDeviceInputDev] 0 6c 1
23:56:14.4552 [InfoBarGenerics] Key 'KEY_DOWN' (108) Break.
23:56:14.7893 [eRCDeviceInputDev] 1 6c 1
23:56:14.7897 [InfoBarGenerics] Key 'KEY_DOWN' (108) Make.
23:56:14.7900 [ActionMap] Map screen 'N/A' context 'SetupActions' -> Action 'down'.
23:56:15.0209 [eRCDeviceInputDev] 0 6c 1
23:56:15.0213 [InfoBarGenerics] Key 'KEY_DOWN' (108) Break.
23:56:15.1809 [eRCDeviceInputDev] 1 6c 1
23:56:15.1813 [InfoBarGenerics] Key 'KEY_DOWN' (108) Make.
23:56:15.1815 [ActionMap] Map screen 'N/A' context 'SetupActions' -> Action 'down'.
23:56:15.4038 [eRCDeviceInputDev] 0 6c 1
23:56:15.4043 [InfoBarGenerics] Key 'KEY_DOWN' (108) Break.
23:56:16.6705 [eRCDeviceInputDev] 1 160 1
23:56:16.6709 [InfoBarGenerics] Key 'KEY_OK' (352) Make.
23:56:16.6712 [ActionMap] Map screen 'N/A' context 'SetupActions' -> Action 'ok'.
23:56:16.6733 [Skin] Processing screen 'MessageBox' position=(419,72), size=(1081,127) for module 'MessageBox'.
23:56:16.6778 [Skin] Error: Attribute 'backgroundcolor' with value 'FNCMainPodlogaColor' in object of type 'eListbox' ('AttributeParser' object has no attribute 'backgroundcolor')!
23:56:16.6865 [Skin] Processing screen 'MessageBoxSummary' from list 'MessageBoxSummary, MessageBox_summary, ScreenSummary, SimpleSummary' position=(0,0), size=(480,320) for module 'MessageBoxSummary'.
23:56:16.6879 [Screen] Showing screen '['MessageBoxSummary', 'MessageBox_summary', 'ScreenSummary', 'SimpleSummary']'.
23:56:16.6883 [Screen] Showing screen '['MessageBox']'.
23:56:16.9019 [eRCDeviceInputDev] 0 160 1
23:56:16.9024 [InfoBarGenerics] Key 'KEY_OK' (352) Break.
23:56:17.6504 [eRCDeviceInputDev] 1 160 1
23:56:17.6509 [InfoBarGenerics] Key 'KEY_OK' (352) Make.
23:56:17.6511 [ActionMap] Map screen 'N/A' context 'HelpActions' -> Unknown action 'select'! (Typo in map?)
23:56:17.6512 [ActionMap] Map screen 'MessageBox' context 'MsgBoxActions' -> Action 'select'.
23:56:17.6523 [Screen] Showing screen '['RestoreMenuSummary', 'RestoreMenu_summary', 'SimpleSummary']'.
23:56:17.6534 [Screen] Showing screen 'RestoreMenu'.
23:56:17.6552 [Skin] Processing screen 'MessageBox' position=(419,72), size=(1081,127) for module 'MessageBox'.
23:56:17.6594 [Skin] Error: Attribute 'backgroundcolor' with value 'FNCMainPodlogaColor' in object of type 'eListbox' ('AttributeParser' object has no attribute 'backgroundcolor')!
23:56:17.6649 [Skin] Processing screen 'MessageBoxSummary' from list 'MessageBoxSummary, MessageBox_summary, ScreenSummary, SimpleSummary' position=(0,0), size=(480,320) for module 'MessageBoxSummary'.
23:56:17.6664 [Screen] Showing screen '['MessageBoxSummary', 'MessageBox_summary', 'ScreenSummary', 'SimpleSummary']'.
23:56:17.6667 [Screen] Showing screen '['MessageBox']'.
23:56:17.8819 [eRCDeviceInputDev] 0 160 1
23:56:17.8823 [InfoBarGenerics] Key 'KEY_OK' (352) Break.
23:56:24.8117 [eRCDeviceInputDev] 1 160 1
23:56:24.8121 [InfoBarGenerics] Key 'KEY_OK' (352) Make.
23:56:24.8124 [ActionMap] Map screen 'N/A' context 'HelpActions' -> Unknown action 'select'! (Typo in map?)
23:56:24.8124 [ActionMap] Map screen 'MessageBox' context 'MsgBoxActions' -> Action 'select'.
23:56:24.8136 [Screen] Showing screen '['RestoreMenuSummary', 'RestoreMenu_summary', 'SimpleSummary']'.
23:56:24.8151 [Screen] Showing screen 'RestoreMenu'.
23:56:24.8165 [Skin] Processing screen 'Console' position=(0,0), size=(1920,1080) for module 'Console'.
23:56:24.8185 [Screen] Warning: Skin is missing element 'key_red' in <class 'Screens.Console.Console'>.
23:56:24.8186 [Screen] Warning: Skin is missing element 'key_green' in <class 'Screens.Console.Console'>.
23:56:24.8217 [Console] Executing in run 0 the command 'rm -R /etc/enigma2'.
23:56:24.8218 [eConsoleAppContainer] Starting /bin/sh
23:56:24.8228 [Skin] Processing screen 'ConsoleSummary' from list 'ConsoleSummary, Console_summary, SimpleSummary' position=(0,0), size=(480,320) for module 'SimpleSummary'.
23:56:24.8248 [Screen] Showing screen '['ConsoleSummary', 'Console_summary', 'SimpleSummary']'.
23:56:24.8255 [Screen] Showing screen 'Console'.
23:56:24.8418 [eConsoleAppContainer] Starting /bin/sh
23:56:25.0438 [eRCDeviceInputDev] 0 160 1
23:56:25.0442 [InfoBarGenerics] Key 'KEY_OK' (352) Break.
23:56:27.3334 [eConsoleAppContainer] Starting /bin/sh
23:56:27.3867 [Screen] Showing screen 'Console'.
23:56:27.3868 [eConsoleAppContainer] Starting /bin/sh
23:56:29.5664 [eConsoleAppContainer] Starting /bin/sh
Oscam-urile curente pe care instalezi din feed-uri se opresc exact după câteva secunde.Pune un oscam mai vechi, de pildă 11727-emu și nu o să mai repete figura.
M-am chinuit și eu.Am pus oscam- ul de mai sus și nu mai am probleme.
Am gasit enigma2-plugin-softcams-oscam_11727-emu-r799_all.ipk dar imi da eroare cand il instalez din tmp. si nu il vede apoi receptorul. (vad ca nu instaleaza fisierul .sh in folderul script/cam.)
Trebuie sa postezi log de oscam.
Ce ai postat tu e log de E2.
Daca nu stii cum, intreaba!
Nu stiu cum.
Am pus la config asa:
logfile = /var/log/oscam.log
initial_debuglevel = 1
Si am acest fisier oscam.log, dar nu vad nimic ciudat in el.
Se termina asa:
2025/04/13 15:44:42 00000000 (main) starting thread client work
2025/04/13 15:44:42 00000000 (main) client work thread started
2025/04/13 15:44:43 00000000 s (main) init for all local cards done
Am pus si initial_debuglevel = 65535 si am obtinut un fisier mai lung.
Intra cu telnet sau ssh pe aparat.
Afla cu ce comanda ruleaza :
apoi il "omori" cu:Code:ps -a | grep oscam
apoi il lansezi cu ceva de forma:Code:killall -9 oscam
ce e cu albastru completezi cu ce e la tine, calea executabilului si calea config.Code:/cale..../oscam -c /cale...config/oscam
Cand o ia, ai in timp real in consola mesajele.
Asta e tot.Code:16:43:14 00000000 s (main) creating pidfile /tmp/.oscam/oscam.pid with pid 342
16:43:14 00000000 s (main) signal handling initialized
16:43:14 00000000 s (config) ERROR: Cannot create file "/etc/tuxbox/oscam/oscam.srvid2.tmp" (errno=2 No such file or directory)
16:43:14 00000000 s (main) waiting for local card init
16:43:14 07D5A4A8 h (webif) webif: decompressed 178779 bytes back into 47652
bytes
16:43:14 07D5A4A8 h (webif) HTTP Server running. ip=:: port=8888 (no SSL)
16:43:15 00000000 s (main) init for all local cards done
16:43:15 00000000 s (emmcache) loading emmcache disabled since no reader is using it!
16:43:15 00000000 s (emmcache) loading emmstats disabled since no reader is using it!
16:43:15 532677DE c (client) plain dvbapi-client granted (anonymous, au=off)
16:43:15 532677DE c (dvbapi) Detected /dev/dvb/adapter0/demux0 Api: 0, userconfig boxtype: 0 maximum number of filters is 64 (oscam limit is 64)
16:43:15 532677DE c (dvbapi) Detected /dev/dvb/adapter1/demux0 Api: 0, userconfig boxtype: 0 maximum number of filters is 64 (oscam limit is 64)
16:43:15 532677DE c (dvbapi) Detected /dev/dvb/adapter0/ca0 device, total available descramblers: 16
16:43:18 532677DE c (dvbapi) Demuxer 0 found 0 ECM pids and 2 STREAM pids in CA PMT
Cum se copiaza din telnet (Dreambox Control Center)? Ma chinuiesc sa copiez pe bucati.
Din mesajele de mai sus pare ca nu ai directorul:
/etc/tuxbox/oscam/
Unde ai fisierele de config?
Daca intrii cu putty, copiezi ce e selectat cu nouse-ul, cu click dreapta!
La Pure2 fisierele de configurare sunt in /etc/tuxbox/config
Iar oscam-ul este in /usr/bin/cam
Am asa:
oscam.user
[account]
user = dvbapi
pwd = api
suppresscmd08 = 1
umaxidle = 0
keepalive = 1
au = 1
emmreassembly = 1
group = 1,2,3
preferlocalcards = 2
max_connections = 2
cccmaxhops = 2
cccreshare = 0
cccignorereshare = 1
Iar la config:
[global]
nice = -1
maxlogsize = 300
chaninfo = 1
lb_mode = 1
lb_retrylimit = 800
failbantime = 1576800
failbancount = 2
disablecrccws = 1
disablecrccws_only_for = 09C4:000000;098C:000000;0500:032830,030B00,050F00; 1811:003311,003315;1819:00006D;1884:000000
[cache]
[cccam]
port = xxxxx
version = 2.2.1-3316
reshare = 1
ignorereshare = 1
forward_origin_card = 1
[dvbapi]
enabled = 1
au = 1
pmt_mode = 0
request_mode = 1
delayer = 60
ecminfo_type = 1
user = dvbapi
read_sdt = 2
write_sdt_prov = 1
boxtype = dreambox
[webif]
httpport = myport
httpuser = root
httppwd = (mypassword)
httprefresh = 10
httphideidleclients = 0
httpallowed = 0.0.0.0-255.255.255.255
oscam.dvbapi este gol.
Deci el cauta directorul asta:
Implicit oscam cauta cfg in directorul precompilat, vezi ex in poza de mai jos:Code:16:43:14 00000000 s (config) ERROR: Cannot create file "/etc/tuxbox/oscam/oscam.srvid2.tmp" (errno=2 No such file or directory)
Asta e un alt oscam .... nu e ca la tine.
Vezi daca poti unde cauta la tine.
Scriptul de pornire poate avea ca parametru -C /cale oscam config
oscam.sh:
#!/bin/sh
OSD="Oscam -> config"
PID=`pidof oscam`
Action=$1
cam_clean () {
rm -rf /tmp/.oscam /tmp/oscam*
cam_handle () {
if test -z "${PID}" ; then
cam_up;
else
cam_down;
fi;
cam_down () {
killall -9 oscam
sleep 2
cam_clean
cam_up () {
/usr/bin/cam/oscam -S -c /etc/tuxbox/config &
if test "$Action" = "cam_res" ; then
cam_down
cam_up
elif test "$Action" = "cam_down" ; then
cam_down
elif test "$Action" = "cam_up" ; then
cam_up
else
cam_handle
fi
exit 0
Ti-am trimis PM!
