Intel's Upcoming 800-series Chipsets Leak in Detail
What appears to be the full details of all of Intel's upcoming 800-series chipsets have leaked and although [Only registered and activated users can see links. Click Here To Register...], no details of the other SKUs have leaked to date. Maybe the biggest news is that there won't be an H870 chipset this time around, according to the leaker @jaykihn0 over at X/Twitter. The full range appears to be Z890, B860 and H810 for consumers, W880 for workstations and Q870 for corporate desktops. That said, the Z890 and W880 are identical in terms of slots and ports, but whereas the W880 gains full ECC support and Intel vPro and remote management, it loses the CPU and bus overclocking features of the Z890. The Q870 loses four chipset PCIe 4.0 lanes, one 20 Gbps or two 10 Gbps USB 3.2 ports, but is otherwise similar to the Z890, minus all the overclocking features, but with Intel vPro and remote management.
The B860 ends up on the chopping block as always and loses not only 10 chipset PCIe lanes compared to the Z890 chipset, but also four lanes from the CPU and four lanes on the DMI interface to the chipset. On top of that bifurcation goes out the window toigether with PCIe RAID and the chipset is only capable of having two 20 Gbps or four 10 Gbps USB 3.2 ports, but at least memory overclocking is still on the table. Finally, the H810 chipset is as basic as it gets, with no extra CPU PCIe lanes beyond the 16 lanes for a graphics card, but they are at least PCIe 5.0 this time around. The chipset itself is only equipped with a mere eight PCIe 4.0 lanes and it gets zero 20 Gbps and two 10 Gbps USB 3.2 ports. Note that all platforms support one or two Thunderbolt 4 / USB4 ports, but it's unclear if this is native support or via an add-on chip. Also note that the USB ports are shared and the maximum count is that for the 5 Gbps ports in the details below, so the Z890 for example, doesn't have 25 USB 3.2 ports in total, but rather only 10. All in all, we'll see a migration to PCIe 5.0 for the x16 slot across the entire 800-series chipset range and from the B860 and up, all chipsets will have a dedicated PCIe 5.0 x4 interface that will most likely be used for an M.2 slot. Also, the PCIe lane count is the maximum, but due to Intel's HSIO layout, some resources will be shared with SATA and Ethernet, which means not all PCIe lanes will be accessible.[Only registered and activated users can see links. Click Here To Register...]
ViewSonic's XG323-4K-OLED2 brings dual-mode, DisplayPort 2.1 and 140 W
ViewSonic has launched a new OLED gaming monitor in the Chinese market that not only is a dual-mode 4K 240 Hz / 1080p 480 Hz display, but it also brings DisplayPort 2.1 connectivity as part of the package. The XG323-4K-OLED2 is said to sport a 31.5-inch LG OLED panel with an anti glare coating, that delivers up to 450 nits brightness, but it can reach as high as 1300 nits in HDR mode. The 10-bit OLED panel delivers 0.03 ms Grey to Grey response time, 98.5 percent of the DCI-P3 colour gamut and it's also VESA DisplayHDR True Black 400 certified. There's also support for VRR via some form of AMD FreeSync version.
However, what stands out here is the paired back design, especially considering that the XG323-4K-OLED2 is being sold as a gaming monitor. We get a more traditional square stand and a much thicker display back compared to most other gaming OLED displays. That said, we're not quite sure what ViewSonic was thinking when the base of the stand was designed, as it's not flat. Connectivity, besides two DisplayPort 2.1 port with full 80 Gbps UHBR20 support, also consists of a USB Type-C port with DP Alt-mode and 140 W USB PD support—a first as far as we're aware—as well as more mundane options like two HDMI 2.1 inputs, one USB 3.2 Type-B input, three USB 2.0 outputs and an audio jack. The stand supports the standard tilt, swivel and height adjustments, as well as rotation. Finally the XG323-4K-OLED2 sports a pair of 5 W speakers and a remote control. JD.com is listing the display of RMB 10,999 which is just north of US$1,500. It's unclear which, if any other markets ViewSonic will offer the XG323-4K-OLED2 in.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Minisforum Launches UH125 Pro Mini PC with Intel Core Ultra 5 CPU
Minisforum, a leader in mini PC innovation, today announces the launch of the UH125 Pro, a game-changing mini PC that redefines what's possible in compact computing. The UH125 Pro delivers a powerful blend of performance, efficiency, and versatility, making it the ultimate solution for professionals, gamers, and creators alike.
Unleashing the Power of Intel Core Ultra 5:
UH125 Pro lies the lightning-fast Intel Core Ultra 5 processor, featuring Intel 4 technology and a 3D high-performance hybrid architecture. This cutting-edge processor delivers a remarkable 65 W TDP 4, resulting in a dual improvement in performance and efficiency. With 14 cores (4 Performance Cores + 8 Efficiency Cores + 2 LP Efficiency Cores), 18 threads, 18 MB L3 Cache, and a maximum Turbo Frequency of 4.5 GHz, the UH125 Pro effortlessly handles even the most demanding tasks.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
NVIDIA GeForce RTX 4070 Ti SUPER with AD102 GPU Appears on German Reta
The GeForce [Only registered and activated users can see links. Click Here To Register...], initially speculated to be an Asia-exclusive release, is now confirmed for worldwide distribution. This development comes as the [Only registered and activated users can see links. Click Here To Register...], the first model equipped with this configuration, has appeared on German online retailer listing, [Only registered and activated users can see links. Click Here To Register...]. Previously using AD103-275 GPU SKU for the regular GIGABYTE RTX 4070 Ti SUPER Windforce model, the "MAX" variant now comes with AD102-225 GPU SKU. Priced at over 950 Euros, it commands a premium over the standard Windforce model. The "MAX" designation not only indicates the different GPU but also boasts an official 30 MHz higher clock speed. The Max variant also employs the more robust cooling system typically found in the GeForce RTX 4080/4090 class. This is a departure from the smaller RTX 4070 Ti design used in the SUPER variant with the AD103 GPU.
While the performance and power consumption differences between the AD102 and AD103 versions may be negligible for most users, the adoption of larger cooling systems in many custom designs could prove beneficial. This enhanced thermal management might appeal to enthusiasts and overclockers looking to push their graphics cards to the limit. While the regular AD103 card measures 261x126x50 mm, the MAX model with its AD102 and beefier coolers measures 331x136x55.5 mm. Overclockers could push the performance of this card further, and we wait to see what will come out of the AD102-225 silicon on the RTX 4070 Ti SUPER platform.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
FTC Issues Warning to ASRock, Zotac, and GIGABYTE About Warranty Pract
The United States Federal Trade Commission (FTC) has taken action against three prominent PC companies, ASRock, Zotac, and GIGABYTE, for their unlawful warranty practices. The FTC has issued stern warnings, urging these companies to immediately cease their actions that have been found to be in violation of consumer protection laws. The trio has been engaging in practices that unfairly restrict consumers' ability to repair or modify their own devices with the "warranty void if removed" stickers. The FTC has made it clear that these companies cannot void warranties or deny service simply because a consumer has opened or repaired their product. "Consumers have a right to repair their own products, and companies shouldn't make that harder by putting up illegal barriers," said Samuel Levine, Director of the FTC's Bureau of Consumer Protection, adding that "Manufacturers who try to circumvent the law will face the consequences."
The FTC's investigation revealed that these PC companies have been including deceptive warranty terms that claim consumers will void their warranties if they open or modify their devices. However, the Magnuson-Moss Warranty Act (MMWA), a federal law, prohibits such practices unless the company can demonstrate that the consumer's actions directly caused the need for repair. The FTC has ordered the companies to stop these unlawful warranty practices immediately and to clearly inform consumers of their right to repair their devices without voiding the warranty. All three manufacturers are given a 30-day period to update their promotional and warranty information on their websites to indicate the updated information. Failure to comply with the FTC's directives could result in significant fines and further legal action.[Only registered and activated users can see links. Click Here To Register...]
South Korean Research Team Develops Method to Grow Sub-Nanometer Trans
A research team from the South Korean Institute for Basic Science (IBS) has developed a new method for growing 1D metallic materials less than 1 nm wide. They applied this technique to create a new structure for 2D semiconductor logic circuits, using the 1D metals as gate electrodes in very small transistors. However, creating very small transistors that can control electron movement within a few nanometers has been challenging. The size of semiconductor devices depends on the width and efficiency of the gate electrode. Current manufacturing processes can't make gate lengths below a few nanometers due to limitations in lithography. To address this, the team used the mirror twin boundary (MTB) of molybdenum disulfide, which is a 1D metal only 0.4 nm wide, as a gate electrode. The IBS team achieved the 1D MTB metallic phase by altering the crystal structure of a 2D semiconductor at the atomic level.
The International Roadmap for Devices and Systems (IRDS) predicts semiconductor technology to reach about 0.5 nm by 2037, with transistor gate lengths of 12 nm. The research team's transistor demonstrated a channel width as small as 3.9 nm, surpassing this prediction. The 1D MTB-based transistor also offers advantages in circuit performance. Unlike some current technologies (FinFETs or GAA) that face issues with parasitic capacitance in highly integrated circuits, this new transistor can minimize such problems due to its simple structure and narrow gate width.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Cambridge Audio Launches the Melomania P100 Wireless Headphones
Cambridge is excited to launch the first over-ear model in the award-winning Melomania wireless headphones series - Melomania P100. Melomania P100 builds on over 50 years of audio expertise and an unashamed passion for music to deliver truly emotive sound from meticulously tuned premium drivers and Hi-fi-grade Class AB amplification.
World-class 60-hour battery life (extending to 100 hours with noise-cancelling turned off) ensures that the effortlessly engaging listening experience could easily last a working week or a lengthy holiday. P100 joins the recently launched M100 true wireless earphones to form the new Melomania range for 2024.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Nanya and Winbond Boost Memory Production Amid Rising Demand and Price
As memory prices and volumes increase, manufacturers Nanya and Winbond have ceased the production cuts they implemented last year, with production now back to normal levels. Market research agencies and supply chain analysts indicate that memory shipments are expected to continue recovering in Q3 2024. Currently, memory factories are operating at a capacity utilization rate of 90% to full capacity, which is significantly higher than the 60% to 70% capacity utilization rate of wafer foundries with mature processes. Last year, Nanya adjusted its production volume reducing it by up to 20%. This year, production has gradually increased, reaching 70% to over 80% in the second quarter, and has now resumed normal levels.
Nanya anticipates that DRAM market conditions and prices will improve quarter by quarter, with the overall industry trending positively, potentially turning losses into profits in the third quarter. Nanya announced yesterday that its consolidated revenue for June was 3.363 billion yuan, marking a monthly increase of 0.35% and an annual increase of 36.83%, setting a high for the year. The cumulative consolidated revenue for the first half of the year was 19.424 billion yuan, a 44.4% increase compared to the same period last year. Nanya will hold a press conference on July 10 to announce its second-quarter financial results and operating outlook.[Only registered and activated users can see links. Click Here To Register...]
AMD Could Prepare Strix Point APUs for Business Use
According to a new leak by Hoang Anh Phu, the upcoming AMD Ryzen 9000 Strix Point desktop series and Ryzen AI 300 for laptops, both dedicated to consumers, will be complemented by the usual commercial and business counterparts: the AMD Ryzen PRO series sporting improved security and manageability features. The first Ryzen PRO model based on Strix Point was spotted in shipping manifests, confirming the series' existence. However, the launch date remains uncertain. Hoang Anh Phu, suggests an October launch for these CPUs.
Hoang's recent accurate leaks include the Radeon PRO W7900 Dual-Slot and Ryzen 8000F series for the DIY market. AMD is expected to introduce the Ryzen AI 300 PRO series six months after the April launch of the Ryzen 8000 PRO, including desktop and mobile variants. The leaker also revealed new PRO variant names: Ryzen AI 9 HX PRO 370 and Ryzen AI 7 Pro 360. While exact specs remain unconfirmed, the first one is rumored to be a 12-core processor. On the other hand, it's more likely that the Ryzen AI 7 PRO 360 will be a 10-core version.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Basemark Releases Breaking Limit Cross-Platform Ray Tracing Bench
Basemark announced today the release of a groundbreaking cross-platform ray tracing benchmark, GPUScore: Breaking Limit. This new benchmark is designed to evaluate the performance of the full range of ray tracing capable devices, including smartphones, tablets, laptops and high-end desktops with discrete GPUs. With support for multiple operating systems and graphics APIs, Breaking Limit provides a comprehensive performance evaluation across various platforms and devices.
As ray tracing technology becomes increasingly prevalent in consumer electronics, from high-end desktops to portable devices like laptops and smartphones, there is a critical need for a benchmark that can accurately assess and compare performance across different devices and platforms. Breaking Limit addresses this gap, providing valuable insights into how various devices handle hardware-accelerated graphics rendering. The benchmark is an essential tool for developers, manufacturers, and consumers to measure and compare the performance of real-time ray tracing rendering across different hardware and software environments reliably.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Intel Arc "Battlemage" Xe2 GPUs with 448 EUs (56 Xe cores) Spotted in
Intel very much does intend to make discrete gaming GPUs based on its Xe2 "Battlemage" graphics architecture, which made its debut with the Core Ultra 200V "Lunar Lake-MX" processor as an iGPU. With its next generation, Intel plans to capture an even bigger share of the gaming graphics market, both on the notebook and desktop platforms. "Battlemage" will be crucial for Intel, as it will be able to make its case with Microsoft and Sony for semi-custom chips, for their next-generation consoles. Intel has all pieces of the console SoC puzzle that AMD does. A Xe2 "Battlemage" discrete GPU sample, codenamed "Churchill Falls," has been spotted making its transit in and out of locations known for Intel SoC development, such as Bangalore in India, and Shanghai in China.
Such shipping manifests tend to be incredibly descriptive, and speak of an Arc "Battlemage" X3 and Arc "Battlemage" X4 SKUs, each with 448 execution units (EU), across 56 Xe cores. Assuming an Xe core continues to have 128 unified shaders in the "Battlemage" architecture, you're looking at 7,168 unified shaders for this GPU, a staggering 75% increase in just the numerical count of the shaders, and not accounting for IPC increase and other architecture-level features. The descriptions also speak of a 256-bit wide memory bus, although they don't specify memory type or speed. Given that at launch, the Arc A770 "Alchemist" was a 1440p-class GPU, we predict Intel might take a crack at a 4K-class GPU. Besides raster 3D performance, Intel is expected to significantly improve the ray tracing and AI performance of its Xe2 discrete GPUs, making them powerful options for creative professionals.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) MSI Announces the New Cubi NUC Series Mini PC
MSI, a global leader in computer hardware and solutions, launches the brand-new Cubi NUC series mini-PC and proudly announces that it has been honored with the esteemed Red Dot Design Award for 2024. This recognition underscores MSI's commitment to innovation and design excellence in the technology industry. The MSI Cubi NUC Series, which includes the Cubi NUC 1M, Cubi NUC 1MG, and Cubi NUC 13MQG, is recognized for its exceptionally sleek design that seamlessly integrates into any modern workspace or home environment. It has been meticulously crafted with great attention to detail, and its compact form factor is complemented by environmentally friendly materials, such as PCR plastics and recycled molded pulp for packaging. This aligns with MSI's commitment to sustainability and environmental responsibility.
The exclusive software Power Meter is an innovative tool that provides valuable insights into energy consumption and environmental impact. It can calculate carbon emissions and electricity costs, allowing users to make informed decisions and minimize their ecological footprint. The software also features a one-click power-saving button that will enable users to save energy without compromising performance. This empowers users to contribute to a sustainable future while enjoying cutting-edge technology.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
AOOSTAR Launches GEM13 Mini PC with AMD Ryzen 7 Hawk Point
AOOSTAR has released a new Mini PC for its GEM series powered by an AMD Ryzen 7 Hawk Point processor. Despite its compact size (130 mm x 126 mm x 45 mm), the AOOSTAR GEM13 integrates an AMD Ryzen R7 8845HS Octa-Core processor with 16 threads, running at speeds of up to 5.1 GHz, and an NPU for AI with up to 38 TOPS. It includes a powerful 12-core Radeon 780M iGPU RDNA 3 that reaches a speed of 2.7 GHz. This setup should be sufficient to support a wide range of applications and games running in 720p and 1080p resolution. For internal memory and storage, it supports up to 32 GB DDR5 5600 MHz and up to 1 TB storage via an M.2 2280 NVMe PCIe x4 SSD. Inside, there is enough space to install an additional 2.5" SATA internal storage unit.
For network connectivity, it features a combination of WiFi 6, Bluetooth 5.2, and two RJ45 2.5G network ports. As for interfaces, it sports 2x USB 3.0 ports, 2x USB 2.0 ports, a full front USB-C, a 3.5 mm audio jack, and two HDMI 2.1 video outputs. It also has a USB4 Type-C with DisplayPort 1.4 data, power, and video output that could be used for an eGPU to increase gaming performance. The AOOSTAR GEM13 comes with a small 100 W external power supply and Windows 11 Pro as the operating system.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) ASUS Announces NUC 14 Pro+ With Intel Core Ultra CPUs
ASUS today announced the ASUS NUC 14 Pro+, an ultracompact PC that offers best-in-class performance thanks to the power of the new Intel Core Ultra processor, which gives it the ability to locally run generative AI workloads. The machine's robust computing capabilities are further boosted by certified Bluetooth dongle-free connectivity, energy-efficient WiFi Sensing, and three AI engines (GPU, NPU, and CPU) that enable high throughput, low power consumption, and fast response. The eye-catching 5 x 4-inch anodized aluminium chassis is perfect for corporate or home office settings, and it features toolless access for fast, safe, and easy upgrades.
Style meets AI-driven performance
Available with Intel Core Ultra 9, 7, or 5 CPUs, the Intel Arc GPU for enhanced graphics, and Intel AI Boost (NPU), the ASUS NUC 14 Pro+ meets most computing needs and combines style with powerful performance. Together, its three AI engines - GPU, NPU, and CPU - enable higher throughput, lower power consumption, and faster response to locally run generative AI workloads. The Intel Core Ultra processors represent Intel's most power-efficient client processors to date. Compared to its predecessor, the NUC 13 Pro Mini PC, the ASUS NUC 14 Pro+ offers significantly enhanced AI processing performance, offering unmatched stability and up to 35% faster local computing, especially noticeable in tasks such as text-to-image generation using stable-diffusion software.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
AMD is Becoming a Software Company. Here's the Plan
Just a few weeks ago, AMD invited us to Barcelona as part of a roundtable, to share their vision for the future of the company, and to get our feedback. On site, were prominent AMD leadership, including Phil Guido, Executive Vice President & Chief Commercial Officer and Jack Huynh, Senior VP & GM, Computing and Graphics Business Group. AMD is making changes in a big way to how they are approaching technology, shifting their focus from hardware development to emphasizing software, APIs, and AI experiences. Software is no longer just a complement to hardware; it's the core of modern technological ecosystems, and AMD is finally aligning its strategy accordingly.
The major difference between AMD and NVIDIA is that AMD is a hardware company that makes software on the side to support its hardware; while NVIDIA is a software company that designs hardware on the side to accelerate its software. This is about to change, as AMD is making a pivot toward software. They believe that they now have the full stack of computing hardware—all the way from CPUs, to AI accelerators, to GPUs, to FPGAs, to data-processing and even server architecture. The only frontier left for AMD is software.[Only registered and activated users can see links. Click Here To Register...]
(PR) ATP Announces I-Temp Operable 8 TB E1.S SSDs
ATP Electronics, the global leader in specialized storage and memory solutions, proudly unveils the N651Si Series E1.S solid state drives (SSDs), which offer best in class performance, endurance, and data retention capabilities for the most demanding applications.
Supporting industrial temperature operating range (-40°C to 85°C) along with hardware power loss protection (HW PLP), the new SSDs offer the highest levels of reliability and total cost of ownership value in harsh environments, making them especially beneficial for mission-critical applications running under extreme temperatures, such as automotive, data logger, data centers, and defense/aerospace. Engineered for 1U Edge servers, the EDSFF offering with 9.5 mm symmetrical enclosure is available with up to 8 TB capacity and is constructed with 512 Gb prime NAND die 176-layer 3D triple level cell (TLC).[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
AMD Ryzen 9 9900X Benchmarked in Geekbench 6, Beats Intel's Best in Si
As AMD prepares to roll out its next-generation Ryzen 9000 series of CPUs based on Zen 5 architecture, we are starting to see some systems being tested by third-party OEMs and system integrators. Today, we have Geekbench 6 scores of the Ryzen 9 9900X CPU, and the 12-core, 24-thread processor that has demonstrated impressive performance gains. Boasting a base clock of 4.4 GHz and a boost clock of up to 5.6 GHz, the CPU features only 120 W TDP, a significant reduction from the previous 170 W of the previous generation. In Geekbench 6 tests, the Ryzen 9 9900X achieved a single-core score of 3,401 and a multicore score of 19,756.
These results place it ahead of Intel's current flagship Core i9-14900KS, which scored 3,189 points in single-core performance. Regarding multicore tasks, the i9-14900K scored 21,890 points, still higher than AMD's upcoming 12-core SKU. The benchmark of AMD's CPU was conducted on an ASUS ROG Crosshair X670E Gene motherboard with 32 GB of DDR5 memory. As anticipation builds for the official release, these early benchmarks suggest that AMD will deliver a compelling product that balances high performance with improved energy efficiency. The top tier models will still carry a 170 W TDP, while some high-end and middle-end SKUs get a TDP reduction like the Ryzen 7 9700X and Ryzen 5 9600X dial down to 65 W, decreased from 105 W in their previous iterations.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
AMD Ryzen 9000X3D Series to Keep the Same 64 MB 3D V-Cache Capacity, O
AMD is preparing to release its next generation of high-performance CPUs, the Ryzen 9000X3D series, and rumors are circulating about potential increases in stacked L3 cache. However, a recent report from [Only registered and activated users can see links. Click Here To Register...] suggests that the upcoming models will maintain the same 64 MB of additional 3D V-cache as their predecessors. The X3D moniker represents [Only registered and activated users can see links. Click Here To Register...], which vertically stacks an extra L3 cache on top of one CPU chiplet. This design has proven particularly effective in enhancing gaming performance, leading AMD to market these processors as the "ultimate gaming" solutions. According to the latest information, the potential Ryzen 9 9950X3D would feature 16 Zen 5 cores with a total of 128 (64+64) MB L3 cache, while a Ryzen 9 9900X3D would offer 12 cores with the same cache capacity. The Ryzen 7 9800X3D is expected to provide 96 (32+64) MB of total L3 cache.
Regarding L2, the CPUs feature one MB of L2 cache per core. Perhaps the most exciting development for overclockers is the reported inclusion of full overclocking support in the new X3D series. This marks a significant evolution from the limited options available in previous generations, potentially allowing enthusiasts to push these gaming-focused chips to new heights of performance. While the release date for the Ryzen 9000X3D series remains unconfirmed, industry speculation suggests a launch window as early as September or October. This timing would coincide with the release of new X870 (E) chipset motherboards. PC enthusiasts would potentially wait to match the next-gen CPU and motherboards, so this should be a significant upgrade cycle for many.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) QNAP Introduces Cost-efficient 10 GbE-ready TS-432X and TS-632X T
QNAP Systems, Inc., a leading computing, networking, and storage solution innovator, today launched new entry-level business NAS models including 4-bay TS-432X and 6-bay TS-632X, tailored for personal studio and SMBs to optimize workflows and collaboration. Featuring a quad-core processor, high-speed 2.5GbE/10GbE ports, and PCIe expansion capabilities, both new models excel in performance and versatility to streamline multi-device file backups, data security, and file management while also simplifying data storage, search, and sharing tasks.
Andy Chuang, Product Manager of QNAP, stated "With the rising popularity of 10GbE applications, the TS-432X and TS-632X offer ideal solutions for small to medium-sized businesses seeking smaller-capacity 10GbE NAS options. Users can benefit from a versatile storage solution featuring multiple LAN ports and PCIe expandability, all within a modest budget."[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
