Lian Li Unveils EDGE PSU Lineup at Computex 2024
Lian Li was also keen to show us its unique EDGE PSU series which features a dual-chamber chassis with L-shaped design that allow easier and more direct access for cable connection. The Lian Li EDGE PSU series will be available in 850 W, 1,000 W, and 1,300 W power output versions, with a special EG850 Mesh version with removable fan grill that allows easier cleaning. In addition to all the usual connectors, the Lian Li EDGE PSU lineup also comes with a built-In USB2.0 Hub.
The entire Lian Li EDGE PSU series is rated at 80 Plus Platinum efficiency, except for the EG850 Mesh which is 80 Plus Gold certified and should be the first one available. Bear in mind that the EG850 Mesh has slightly different specifications, but we'll confirm these as it becomes available or comes to our review testbed. The entire series is fully modular with sleeved cables and cable combs. Lian Li is using a new 12VHPWR connector design with more durable contact points for each pin, as well as high-quality electrolytic capacitors. In case you are wondering, the precise dimensions are 182x86x150 mm and as showcased at the event, Lian Li will have both black and white color options for some models.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) EK Introduces New Direct Die Water Block for Socket LGA 1700 14th
EK, the leading computer cooling solutions provider, is rolling out a brand-new water block built from the ground up for the LGA 1700 socket, explicitly designed for delidded Intel Core CPUs. It bears improvements that benefit 14th-generation CPUs and shares almost no parts with the previously released Intel Direct Die water block. It includes a purpose-developed cold plate, cooling fin structure, and mounting mechanism. It relies on standoffs positioned at the four corners of the water block to ensure optimal contact with the CPU, eliminating concerns about applying too much or too little pressure on the bare CPU die, just like the AM5 Direct Die water block. EK's latest water block features EK-Matrix7 compatibility, meaning the product's height and port distance are managed in 7 mm increments for easier loop planning and precise results.
EK-Quantum Velocity² Direct Die D-RGB - 1700 Core Edition
This new direct die LGA 1700 water block is built from scratch and made to squeeze every bit of performance out of the 14th-generation Intel Core CPUs. The top is seethrough glass-like acrylic, with rich D-RGB illumination behind the window, which is riddled with aluminium bars going over the top and two G1/4" extenders that interrupt the flow of the black-anodized aluminium bars. These G1/4" extenders are standard Torque micro extenders. They can be replaced by other products from the EK-Quantum Torque Micro series, be it extenders of different finish, HDP or HDC fittings.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Thermaltake Reveals the TH V2 Ultra EX ARGB Sync AIO & CT EX ARGB Sync
Thermaltake, renowned for its premium PC hardware solutions and just celebrating its 25th anniversary, unveils at Computex 2024 the TH V2 Ultra EX ARGB Sync Snow AIO, along with the CT EX ARGB Sync and the CT EX Reverse ARGB Sync fans. These cooling solutions are available in a range of colors: Black, White, Hydrangea Blue, and Matcha Green. From AIOs to standard blade fans to reverse blade fans, Thermaltake enhances each product with quick magnetic connections, providing excellent cable management tailored to different preferences.
The TH V2 Ultra EX ARGB Sync is a budget-friendly AIO cooler featuring the 2nd iteration of Magnetic Force Design (MagForce 2.0) and a highly customizable LCD. This series includes models equipped with radiators ranging from 240 mm up to 420 mm and 120 mm / 140 mm CT EX ARGB Sync fully modular fans. Both are available in Black and Snow editions.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Acer Announces May Consolidated Revenues at NT$21.13 Billion, Mar
Acer Inc. announced its consolidated revenues for May at NT$21.13 billion with 18.4% growth month-on-month and 16.8% growth year-on-year (YoY), achieving 11 consecutive months of YoY growth. Consolidated revenues for year-to-May reached NT$97.81 billion with 15.9% growth YoY, while revenues from the personal computers [1] business grew 26.0% YoY in May and 22.6% YoY year-to-May.
Acer's strategy to expand multiple business engines continued to gain momentum. Total revenues from businesses other than computers and displays contributed 26.5% of the group's total revenues in May and 29.0% year-to-May.[Only registered and activated users can see links. Click Here To Register...]
(PR) be quiet! introduces Dark Rock 5 Single-Tower CPU Air Cooler
be quiet!, the German manufacturer for premium PC components, is proud to announce a new member to its family of high-end air coolers: Dark Rock 5. With its single-tower design, Dark Rock 5 offers outstanding cooling performance at low noise levels for builds that won't fit dual-tower designs like Dark Rock Pro 5 or Dark Rock Elite. Like its bigger brothers, Dark Rock 5 offers maximum compatibility with high-end consumer motherboards and RAM-modules. With its sleek black design, Dark Rock 5 knows how to impress: whether you use it for gaming, for workstations or as a reliable companion in your home office.
Better performance, easier installation
Dark Rock 5 improves on the high-performance benchmarks of its predecessor, Dark Rock 4, combining a proven and iconic design with cutting edge fan technology. Six high-performance heat pipes are connected to an asymmetrical heat sink with additional cut-outs for high RAM and VRM cooler compatibility, while a consumer-grade Silent Wings 4 120 mm PWM fan delivers perfect air pressure and virtually inaudible operation (29.8dB(A) at maximum fan speed). For those in search for the highest performance, a second fan can be installed optionally at the exhaust side. As with other Dark Rock models, special black coating with ceramic particles enable perfect heat transfer -- and an elegant look.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) G.SKILL OC World Cup 2024 Grand Final: CENS Wins OC Champion Titl
G.SKILL International Enterprise Co., Ltd., the world's leading brand of performance overclock memory and PC components, is pleased to announce that CENS from Germany won the title of OC Champion in the 8th Annual OC World Cup 2024 overclocking competition. After a grueling day of extreme overclocking with liquid nitrogen cooling, using the latest Intel Core i9-14900KF processor and ASUS ROG Maximus Z790 Apex Encore motherboard, CENS is walking away with the grand cash prize of $10,000 USD!
After the first 3 days of exhausting extreme overclocking in the Live Qualifier Stage of the OC World Cup 2024, biso biso, CENS, and Seby qualified for the Grand Final Stage on June 7. The Grand Final round is comprised of a maximum memory frequency challenge and 3 benchmarks with CPU speed fixed at a maximum of 7 GHz, demonstrating the incredible capability of the latest 14th Gen Intel Core processors and the extraordinary overclock skills of each OC World Cup 2024 Grand Final contestant.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Sharkoon Shows New Wooden Mechanical Keyboards at Computex
At Computex 2024, we discovered in Sharkoon's booth, among many other products, the latest additions to its keyboard portfolio: the Sharkoon SGK50 PBT Wood series. These newly announced mechanical keyboards have one particular thing - they are made of wood (body, baseplate, palm rest). To quote Sharkoon, "they are the world's first wooden mechanical keyboards to be mass-produced," so we can expect decent prices for something that was previously considered a premium, limited-edition product. They do look really nice and we already can see them fit to those who appreciate classic, elegant design with a touch of wood.
The keyboards come in three sizes: a 60% model, the SGK50 S2 PBT Wood; a 75% one, the SGK50 S3 PBT Wood; and the full-size 96% format known as SGK50 S4 PBT Wood. The primary difference lies in their size, as the internal components are the same - based on Sharkoon's SGK50 with Gateron G Pro 3.0 Yellow switches and a hot-swap PCB for 3-pin and 5-pin switches. Interestingly, each keyboard is unique in appearance, as the base is CNC-milled from a single piece of wood, giving them slight visual differences. We don't have an exact date for when these wooden mechanical keyboards will be available in stores. However, the prices seem to range from €149.9 to €169.9.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
TechPowerUp x Team Group Computex 2024 Giveaway: Entries Close Tomorro
TechPowerUp and Team Group have partnered to bring you the Computex 2024 Giveaway. We had a deluge of news from Computex for you last week, and it's easy to miss this Giveaway, so we've extended it to tomorrow, June 12, 2024. The Giveaway is open worldwide. Up for grabs, are a Team Group T-Force Xtreem DDR5-7600 32 GB (2x 16 GB) memory kit, a Team Group 1x PD20M Mag 2 TB Portable SSD, a Team Group T-Create Expert Smart 1 TB SDXC Card + R31 Card Reader; and a C222 USB 3.2 Gen 1 256 GB Flash Drive—useful and contemporary memory hardware from Team Group, and it could be yours! Hurry!
For more information, and to participate, [Only registered and activated users can see links. Click Here To Register...].[Only registered and activated users can see links. Click Here To Register...]
Train Today for an IT Certification With This $34.99 Bundle
If you've even started to look for jobs in the tech sector, you know that certifications hold far more weight with most employers than a traditional degree. This e-learning bundle contains a series of online courses that gives aspiring IT professionals exactly what they need: Technical expertise and guidance on how to pass the most crucial CompTIA and Cisco exams with a minimum of wasted time.
What you get here is a series of online video tutorials, each one geared toward a different exam. If you're going for your CompTIA certifications especially, you'll find a roadmap to success that can serve you throughout your career, starting with a course on the Fundamentals ITF+ certification. This is where you can learn everything you need for most entry-level IT jobs, including the basics of file management and the hardware you'll encounter on the job.
For a limited time, you can get this [Only registered and activated users can see links. Click Here To Register...] (reg. $184).[Only registered and activated users can see links. Click Here To Register...]
Possible Specs of NVIDIA GeForce "Blackwell" GPU Lineup Leaked
Possible specifications of the various NVIDIA GeForce "Blackwell" gaming GPUs were leaked to the web by Kopite7kimi, a reliable source with NVIDIA leaks. These are specs of the maxed out silicon, NVIDIA will carve out several GeForce RTX 50-series SKUs based on these chips, which could end up with lower shader counts than those shown here. We've known from older reports that there will be five chips in all, the GB202 being the largest, followed by the GB203, the GB205, the GB206, and the GB207. There is a notable absence of a successor to the AD104, GA104, and TU104, because NVIDIA is trying a slightly different way to approach the performance segment with this generation.
The GB202 is the halo segment chip that will drive the possible RTX 5090 (RTX 4090 successor). This chip is endowed with 192 streaming multiprocessors (SM), or 96 texture processing clusters (TPCs). These 96 TPCs are spread across 12 graphics processing clusters (GPCs), which each have 8 of them. Assuming that "Blackwell" has the same 256 CUDA cores per TPC that the past several generations of NVIDIA gaming GPUs have had, we end up with a total CUDA core count of 24,576. Another interesting aspect about this mega-chip is memory. The GPU implements the next-generation GDDR7 memory, and uses a mammoth 512-bit memory bus. Assuming the 28 Gbps memory speed that was being rumored for NVIDIA's "Blackwell" generation, this chip has 1,792 GB/s of memory bandwidth on tap![Only registered and activated users can see links. Click Here To Register...]
(PR) Jabra Unveils Second Generation of Elite 8 Active and Elite 10
Jabra, a global leader in true wireless sound and hybrid work solutions, is unveiling the Elite 8 Active Gen 2 and Elite 10 Gen 2 earbuds. Building upon the same great design and success of their predecessors, these next-generation earbuds come with enhancements that strengthen the audio experience.
This includes the world's first LE Audio smart case, enhanced spatial sound powered by Dolby Audio for a better music experience, and enhanced Natural HearThrough for better awareness when outdoors. Jabra's Active Noise Cancellation (ANC) has also been made even stronger with improved mid- and low-frequency noise cancellation.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Assassin's Creed Shadows Shows Off New Combat and Stealth Gamepla
Assassin's Creed Shadows, launching on November 15, revealed 13 minutes of brand-new gameplay footage at Ubisoft Forward. In the walkthrough, Yasuke arrives in Fukuchiyama to track a corrupt daimyo. His trail leads him to confront a samurai who is abusing his power, and it's here that Assassin's Creed Shadows showcases its new combat, featuring destructible armor, devastating but risky posture attacks, and multiweapon combat. Yasuke crushes his foes with massive swings from his powerful kanabo before dispatching the samurai in a duel of katanas.
When the time comes to assassinate the daimyo inside his castle, players will be able to choose between Naoe and Yasuke; in the walkthrough, we see Naoe take the lead on infiltrating the towering complex. The stealthiest Assassin yet, Naoe has a host of tools at her disposal that allow her to strike silently and move about unseen. She can go prone and crawl through tall grass, peek around corners, or extinguish lights to hide in the shadows. She can swing and climb using her grappling hook, knock out NPCs, assassinate targets from a distance using her kusarigama, and more.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Star Wars Outlaws Gets New Gameplay and Overview Trailers at Ubisoft F
During Ubisoft Forward showcase, we got a whole new gameplay trailer showing off a lot of details for the upcoming Star Wars Outlaws open-world game that is set to launch on August 30th. In addition, Ubisoft also released the new overview trailer, showing off some of the locations and missions that you will be able to take in the game.
The new gameplay trailer focused on locations and encounters, including Tatooine and Mos Eisley. It follows the protagonist, Kay Vess, on a mission to Mos Eisley, where he needs to track an expert gunslinger. The trailer shows off dogfights, and what to expect from the dynamic side, including stealth aspect of the game. It also reveals how you would be able to gain skills.[Only registered and activated users can see links. Click Here To Register...]
Curious "Navi 48 XTX" Graphics Card Prototype Detected in Regulatory F
A curiously described graphics card was detected by Olrak29 as it was making it through international shipping. The shipment description for the card reads "GRAPHIC CARD NAVI48 G28201 DT XTX REVB-PRE-CORRELATION AO PLATSI TT(SAMSUNG)-Q2 2024-3A-102-G28201." This can be decoded as a graphics card with the board number "G28201," for the desktop platform. It features a maxed out version of the "Navi 48" silicon, and is based on the B revision of the PCB. It features Samsung-made memory chips, and is dated Q2-2024.
AMD is planning to retreat from the enthusiast segment of gaming graphics cards with the RDNA 4 generation. The company originally entered this segment with the RX 6800 series and RX 6900 series RDNA 2 generation, where it saw unexpected success with the crypto-mining market boom, besides being competitive with the RTX 3080 and RTX 3090. This bust by the time RDNA 3 and the RX 7900 series arrived, and the chip wasn't competitive with NVIDIA's top-end. Around this time, the AI acceleration boom squeezed foundry allocation of all major chipmakers, including AMD, making large chips based on the latest process nodes even less viable for a market such as enthusiast graphics—the company would rather make CDNA AI accelerators with its allocation. Given all this, the company's fastest GPUs from the RDNA 4 generation could be the ones that succeed the current RX 7800 XT and RX 7700 XT, so AMD could capture a slice of the performance segment.[Only registered and activated users can see links. Click Here To Register...]
AMD Ryzen 5 9600X ES Overclocked to 5.70 GHz All-core
An AMD Ryzen 5 9600X "Zen 5" processor engineering sample has been overclocked to 5.70 GHz on all cores, and put through the CPU-Z Benchmark. Here, the chip is found to score 871 points in the single-thread benchmark, and 7096 points in the multithreaded benchmark. The overclock to 5.70 GHz is significant, as this is the maximum boost frequency of the upcoming Ryzen 9 9950X flagship part. The single-thread benchmark highlights that "Zen 5" has a similar IPC to the "Raptor Cove" P-core of the Intel Core i9-14900K processor, while the 7096 points multithreaded score is higher than the that of the Ryzen 7 5800X "Zen 3," meaning that AMD is overcoming the deficit of two whole cores (33% of the core-count of the 9600X) with just IPC and faster memory. AMD is expected to launch the Ryzen 9000 series desktop processors in July 2024.[Only registered and activated users can see links. Click Here To Register...]
(PR) macOS Sequoia Takes Productivity and Intelligence on Mac to New H
Apple today previewed macOS Sequoia, the next version of the world's most advanced desktop operating system, bringing entirely new ways of working and transformative intelligence features to Mac. macOS Sequoia is full of exciting new capabilities, including iPhone Mirroring, which expands Continuity by enabling full access to and control of iPhone directly from macOS. Safari gets another big update with the new Highlights feature for effortless information discovery on webpages while browsing. The new Passwords app makes it even easier to access passwords and organize credentials all in one place. Gaming advances with a more immersive experience, as well as a breadth of new titles, including Assassin's Creed Shadows, Frostpunk 2, and more.
macOS Sequoia also introduces Apple Intelligence, the personal intelligence system for Mac, iPhone, and iPad that combines the power of generative models with personal context to deliver intelligence that's incredibly useful and relevant. Built with privacy from the ground up, Apple Intelligence is deeply integrated into macOS Sequoia, iOS 18, and iPadOS 18. It understands and creates language and images, takes action across apps, and draws from personal context, simplifying and accelerating everyday tasks. Taking full advantage of the power of Apple Silicon and the Neural Engine, Apple Intelligence will be supported by every Mac with an M-series chip.[Only registered and activated users can see links. Click Here To Register...]
(PR) QCY Launches MeloBuds Pro: Advanced ANC Wireless Earbuds with Hi-
QCY, a premier audio brand renowned for its expertise in wireless audio technology, announces the launch of MeloBuds Pro Adaptive ANC Wireless Earbuds. These wireless earbuds deliver Hi-Res Audio and stereo sound with powerful ANC while ensuring exceptional comfort for extended wear.
Equipped with Adaptive Active Noise Cancellation (ANC), MeloBuds Pro auto-adjusts noise cancellation to adapt to your ear accordingly by analyzing your ear canal structure and how you wear it. The ANC system contributes to a wide frequency range (20 Hz-2500 kHz), with maximum ANC depth as high as 46 dB. Featuring 6 microphones and a wind noise-minimizing design, AI-based voice pickup technology ensures crystal-clear calls by cancelling ambient noise while enhancing vocals.[Only registered and activated users can see links. Click Here To Register...]
Xigmatek Takes Pillarless Cases to the Next Level at Computex 2024
Xigmatek made huge strides in the case design game this year at Computex. The pillarless left-corner has been a recurring theme with cases this year, but Xigmatek took things up a notch or two. Firstly, it incorporated the seamless pillarless design element, where two separate glass panels don't meet at the pillarless corner creating a glass seam, but rather a single glass panel curves around the edge. Secondly, some of its case designs have clear glass top-panels. The Pano series is a great place to start our coverage. The Pano and Pano Arctic, are black and white trims of the baseline Pano case, with its seamless-pillarless design. You still get a panoramic view of your build, but the top panel metal, with a 3x 120 mm fan/radiator mount.
The vertically partitioned case sees the right compartment end just before the side-facing fan-vents, which are recessed, so even with a thick radiator and fans, nothing gets in the way of a long graphics card. The left compartment has at least 10 cm of crawl space, because the PSU is mounted sideways. This means ample room for motherboards with backside connectivity. The Pano Ultra is 25% larger in volume than the Pano, and has the same layout, except the top panel is now glass, and the bottom panel is designed such that a radiator installation there wouldn't interference with an add-on card installed in the last slot of the motherboard—so there's a compartment down there, you can install a few 3.5-inch drives if you don't have a radiator.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Thermalright CPU and SSD Coolers at Computex 2024
Thermalright brought several new CPU and M.2 SSD coolers to the 2024 Computex. Our tour of the Thermalright Computex booth began with the HR10, a high-performance active cooling solution for M.2-2280 SSDs. Its design involves an aluminium base from which two heatpipes draw heat from the drive, pushing it through an aluminium fin-stack, which is ventilated by a 40 mm fan. The cooler comes in two trims—black and silver/chrome. The Frozen Infinity 360 is the company's flagship AIO liquid CPU cooler. It features a 360 mm radiator, a cube-shaped pump-block which features an infinite-reflection ARGB ornament. Each of the three included 120 mm fans has infinite reflection ARGB diffusers along their sides. The cooler comes in black- and white trims.
The Thermalright Royal Lord is a thick single fin-stack (U-type) CPU cooler. It features a large CPU base that supports HEDT processors, seven 6 mm-thick nickel-plated copper heatpipes, fully soldered construction, and a high static-pressure 120 mm fan with a fluid-dynamic bearing. This cooler supports large CPU sockets such as the Intel Socket E, or AMD sTR5. The Thermalright Burst Assassin 120 EVO, much like the Royal Lord, is a single fin-stack heatsink, but with a narrower fin-stack, a brushed metal 2-tone top-plate, and two 120 mm fans in push-pull configuration, instead of just one. This cooler uses six 6 mm-thick heatpipes, and has dark powder-coating along all its metal bits.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
