DAB+ Metropolitain la 5°W
Eutelsat 5 West B (5°W)
11461 H,5780,3/4-Metropolitain
DAB-ul francez Metropolitain la 5°W, cu doua console/terminale;
1.utilitarul tune-s2, sau neumoDVB, daca l-aveti instalat,pentru a inchide semnalul,
2.unde se pune linia de comanda, precum se vede in linkul (video) de mai jos:
Code:
dvbstream -o 301 | fedi2eti 301 239.0.1.11 5001 | dablin_gtk
Metropolitain 1
0 : RTL (0xf211) Pri subch= 1 start= 0 CUs= 66 PL=eep-3a bitrate=88 DAB+
1 : RTL2 (0xf215) Pri subch= 2 start= 66 CUs= 66 PL=eep-3a bitrate=88 DAB+
2 : FUN RADIO (0xf217) Pri subch= 3 start=132 CUs= 66 PL=eep-3a bitrate=88 DAB+
3 : M RADIO (0xf225) Pri subch=13 start=198 CUs= 66 PL=eep-3a bitrate=88 DAB+
4 : AirZen Radio (0xf2fe) Pri subch=10 start=264 CUs= 66 PL=eep-3a bitrate=88 DAB+
5 : RADIO CLASSIQUE (0xf221) Pri subch=11 start=330 CUs= 66 PL=eep-3a bitrate=88 DAB+
6 : LATINA DAB+ (0xf21c) Pri subch=12 start=396 CUs= 66 PL=eep-3a bitrate=88 DAB+
7 : SKYROCK (0xf214) Pri subch= 8 start=462 CUs= 66 PL=eep-3a bitrate=88 DAB+
8 : SKYROCK KLASSIKS (0xf2fc) Pri subch= 9 start=528 CUs= 66 PL=eep-3a bitrate=88 DAB+
9 : NRJ (0xf2f8) Pri subch= 4 start=594 CUs= 66 PL=eep-3a bitrate=88 DAB+
10 : CHERIE FM (0xf2f9) Pri subch= 5 start=660 CUs= 66 PL=eep-3a bitrate=88 DAB+
11 : RIRE ET CHANSONS (0xf226) Pri subch= 6 start=726 CUs= 66 PL=eep-3a bitrate=88 DAB+
12 : NOSTALGIE (0xf2fa) Pri subch= 7 start=792 CUs= 66 PL=eep-3a bitrate=88 DAB+
satelescu
10.0E DAB+ Radio Salisbury
Eutelsat 10A @ 10.0E
11221 V,30000,5/6.QPSK2- DAB+ Radio Salisbury
Code:
-tune-s2 11221 V 30000 -adapter 0 -system DVB-S2 -lnb UNIVERSAL
-dvbstream -o 701 | fedi2eti 701 239.232.1.201 4000 | dablin_gtk
Salisbury 701
0 : BFBS Gurkha (0xc2fc) Pri subch= 3 start= 60 CUs= 24 PL=eep-3a bitrate=32 DAB+
1 : BOOM LIGHT (0xc9c2) Pri subch=14 start=400 CUs= 18 PL=eep-3a bitrate=24 DAB+
2 : TalkRadio (0xcaeb) Pri subch=17 start=466 CUs= 24 PL=eep-3a bitrate=32 DAB+
3 : Virgin Radio (0xc3d8) Pri subch=18 start=490 CUs= 24 PL=eep-3a bitrate=32 DAB+
4 : Nation 00s (0xc2fd) Pri subch=15 start=418 CUs= 24 PL=eep-3a bitrate=32 DAB+
5 : Tomorrowland OWR (0xc2c3) Pri subch=19 start=514 CUs= 24 PL=eep-3a bitrate=32 DAB+
6 : Hot Salisbury (0xcfc2) Pri subch=10 start=322 CUs= 18 PL=eep-3a bitrate=24 DAB+
7 : BFBS Rewind (0xc9c5) Pri subch=20 start=538 CUs= 24 PL=eep-3a bitrate=32 DAB+
8 : Nation 60s (0xccf1) Pri subch=23 start=610 CUs= 24 PL=eep-3a bitrate=32 DAB+
9 : Easy Radio (0xcbf2) Pri subch=22 start=586 CUs= 24 PL=eep-3a bitrate=32 DAB+
10 : Hot Gold S'bury (0xc1c3) Pri subch=11 start=340 CUs= 18 PL=eep-3a bitrate=24 DAB+
11 : AWNSR (0xccea) Pri subch=13 start=382 CUs= 18 PL=eep-3a bitrate=24 DAB+
12 : Nation Rocks (0xc2fb) Pri subch=24 start=634 CUs= 24 PL=eep-3a bitrate=32 DAB+
13 : Times Radio (0xc0d8) Pri subch=16 start=442 CUs= 24 PL=eep-3a bitrate=32 DAB+
14 : Nation Dance (0xc2e7) Pri subch=25 start=658 CUs= 24 PL=eep-3a bitrate=32 DAB+
15 : Nation Love (0xc2ec) Pri subch=26 start=682 CUs= 24 PL=eep-3a bitrate=32 DAB+
16 : Salisbury Radio (0xc2c1) Pri subch= 6 start=132 CUs= 84 PL=uep 3 bitrate=112
17 : BFBS Salisbury (0xc991) Pri subch= 1 start= 0 CUs= 36 PL=eep-3a bitrate=48 DAB+
18 : Grt Hits S'bury (0xc5f4) Pri subch= 7 start=216 CUs= 58 PL=uep 3 bitrate=80
19 : Radio Bath (0xcbec) Pri subch= 8 start=274 CUs= 24 PL=eep-3a bitrate=32 DAB+
20 : BBC Radio Wilts (0xcc32) Pri subch=27 start=706 CUs= 48 PL=eep-3a bitrate=64 DAB+
21 : Nation Radio (0xc485) Pri subch=12 start=358 CUs= 24 PL=eep-3a bitrate=32 DAB+
22 : BFBS BestBritish (0xc9c4) Pri subch=21 start=562 CUs= 24 PL=eep-3a bitrate=32 DAB+
23 : BFBS Beats (0xced6) Pri subch= 2 start= 36 CUs= 24 PL=eep-3a bitrate=32 DAB+
24 : Angel Vintage (0xcdc2) Pri subch= 5 start=108 CUs= 24 PL=eep-3a bitrate=32 DAB+
satelescu
Astra 3B / Astra 3C @ 23.5° E
Cele doua streamuri DAB+,BuMux 1 si BuMux 2,la 12167 V,27500,3/4,Dvb-S2 au fost reactivate(probabil pentru teste;ramine de vazut),cu aceasi parametrii de transmisie ca prima oara(mai sus, #13).
Procedura de a le receptiona si asculta este la fel ca cel descris mai sus.
Pentru streamurile DAB+ la 12168 V este nevoie de cardurile cu demod STV091X based(6983,6903,6908,6905 PCI-E,TBS 5927 USB2.0 si stid135 based,iar comenzile pe doua console/terminale sint astfel:
- tune-s2 12168 V 27500 -adapter 0 -system DVB-S2 -lnb UNIVERSAL,
- dvbsnoop -adapter 1 -s ts -tsraw -b | fedi2eti 4121 239.128.43.43 50043 | dablin_gtk,
- dvbsnoop -adapter 1 -s ts -tsraw -b | fedi2eti 4122 239.128.43.10 50010 | dablin_gtk.
DAB+ Deutchaland (mis 1 si 2),la 12641 V,1500,2/3,8PSK, este in continuare folosit si functioneaza concomintent cu cu cel de la 12168 V.
dvbsnoop -adapter 0 -s ts -tsraw -b | ./bbframe-tools/pts2bbf | bbfedi2eti -mis 2 | dablin_gtk
Acest stream poate fi ascultat numai cu cardurile cu demod stid135(6903x/6909x).
De asta data am folosit ca suport semnal app neumoDVB si player dablin pe un terminal.
satelescu
DAB+ Metropolitain si DAB+ RAI cu USB5927
Si tunerul USB5927 poate fi utilizat pentru a rula streamurile DAB+ Metropolitain(11461 H) si DAB+ RAI(12564 V) la 5.0W la fel ca placile dvb testate in postarea anterioara, insa nu decodeaza streamul DAB+ NRK la 1.0W, doar placile 6903x/6909x sint valabile pentru acest stream.
satelescu
