Black Hole 3.0.5 Quad PiP VU+ Uno4k SE Image
What is new ?
- Update and fix CrossEPG
- Fix Timer recording bug
- Fix USB recording
- Add Overlayfs for new kernel (Uno4KSE, Zero4K)
- Add Uno4KSE support
- Add Zero4K support (beta)
- Add VP9 Support (Ultimo4K, Uno4KSE, Uno4K, Zero4K)
- Add Dvb-S2X support (Zero4K)
- Add Multistream/PLS support (Zero4K)
- Add Blindscan support (Zero4K)
- Update Drivers (Ultimo4K, Uno4KSE, Uno4K, Solo4K, Zero4K, Duo2, SoloSE, Solo2, Zero)
BlackHole-3.0.5-vuuno4kse_usb_release_20171224_610e58d.zip
Vu+ UNO 4K SE User --- Manual english---
Black Hole 3.0.5.A Quad PiP VU+ Uno4k SE Image
What is new ?
Update drivers(4k models)
- Fix demux problem
[bluetoothsetup/util] update for solo4k.
[vuplus-blindscan-utils] update TT2L08/TT3L10
[Scan] Fix DVB-T2 Network Scan. (need update libdvbsi++ 0.3.8)
- Fix HDR/HLG problem
- Fix grab problem
- Fix demux problem
- Improve overall performance
- Update kernel config
- Adjust driver memory allocations
update kodiegl/chromium/directfb.
[libdvbsi++] update to 0.3.8
[dvbmediasink] update EXTRA_OECONF (solo4k, uno4k, ultimo4k, uno4kse).
update driver(zero4k)
- Fix DVB-CI problem
- Fix PLS
- Improve demux
This is available as an online update from 3.0.5 or as a full flash update.
Black Hole 3.0.5.E Quad PiP VU+ Uno4k SE Image
Black Hole 3.0.5.E
What is new ?
update drivers(uno4k, uno4kse, ultimo4k)
- Fix DiSEqC timing
- Support Dual DVB-S2X FBC tuner(needs E2 update)
update drivers(solo4k, uno4k, uno4kse)
- Fix media playback(24Fps)
Fix default recording path and usb recording.
[dvbapp] update.
[autofs] remove sync option for broken recording issue for ext4 filesystem.
[udev] fix automount.
New VTi - Vu+ Team Image - VTi 13.0.x
From VTi Team
VTi Panel (Blue Button)
Supported languages:
English, German, Dutch, Italian, Turkish, Danish, Polish,
Russian, Ukrainian, Czech, Arabic, French, Swedish,
Portuguese (Portugal), Greek, Bulgarian, Hungarian
With modular, flexible VTi skins
VTi Bootlogos and Radiomode Logo.
Short press on blue button opens VTi Panel, long press opens Pluginmenu
Support for FTDI chipset cardreader like smargo and easymouse2
Running Softcam shown in the Infobar
MovieList with extended functions
Support for full image backup and restore (not Vu+ Solo 4K / Uno 4K)
Supports VTi image flash online (not Vu+ Solo 4K / Uno 4K)
Restore Plugins, Bouquets, Settings, etc. during installation
Remove preinstalled packages during installation (VTi Zero)
Support delayed descrambling in standby (Solo 4K, Uno 4K, Uno4K SE, Ultimo 4K, Zero 4K)
Basic image information
Build tree: openvuplus-3.0
Kernel: 4.1.20 (Uno 4K SE, Zero 4K)
Kernel: 3.14.28 (Solo 4K, Uno 4K, Ultimo 4K)
Kernel: 3.13.5 (Solo², Duo², Solo SE, Zero)
Kernel: 3.9.6 (Duo, Solo, Uno, Ultimo)
Gstreamer: 1.6.4
HbbTV-Browser: Opera (Solo², Duo², Solo SE, Zero)
HbbTV-Browser: WebKit (Solo 4K, Uno 4K, Ultimo 4K, Uno 4K SE, Zero 4K)
CHANGELOG
- update Samba --> 3.6.X version including backports for important securtiy patches
- redesigned Openwebinterface (responsive design)
- ChromiumOS is not preinstalled anymore - please install YouTubeTV plugin to use it
- Update dvbapp2
introducing database for media files
search movies by title, description , tag or time intervall
auto tagging for movie files (based on database)
trashcan based on database including an auto delete function (ATTENTION: old movie trashcan will be removed by a future update)
movie search with voice input at BT RCU (EPG-button)
enhanced configuration for debug output
mark recordings which are being made by another receiver
enhanced virtual keyboard
text input open virtual keyboard (need modified skin for showing SMS style input)
improved displaying of long configuration lists
ZapHistory button presses work like default InfoBar (no need for closing Zaphistory anymore)
View top 20 downloads (Plugins / Skins) - VTi News, yellow button
Bugfix: freezing PiP at Solo 4K
Bugfix: support movie folders containing ":"
Bugfix: parental control for folders in movielist
Black Hole 3.0.6 VU+ Uno4k SE Image
Black Hole 3.0.6
What is new ?
Completely re-written the BH EPG system.
Added EPGImport support
Added FreeSat, Netmed, ViaSat and Virgin EPG
Updated Sky EPG
Added options to Load-Save-Delete epg.dat
Updated CrossEPG
Fixed DVB Subtitles issue on some channels
Swapped Buttons around in BH panels to match layout of other images
Various Skin updates from MX10
Please Note:
Due to limited resources some end of life models will no longer be supported from BH 3.0.6 onwards. If you want to use BH with these receivers please use version 3.0.5
The following is a list of the receivers that will not be supported in version 3.0.6 onwards:
Vu+ Zero
Vu+ Ultimo
Vu+ Uno
Vu+Duo
Vu+ Solo
This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
- Integrated OpenEpg
- CrossEPG supported
- EPG Import supported
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
Thanks to plnick for help obtaining missing Ultimo4K files.
Thanks to Pedro_Newbie for Backup script.
Thanks to Littlesat and Pli Team for the original autolanguage and subtitle options code
DISCLAIMER
LICENSE (TERM OF USE)
BlackHole-3.0.6-vuuno4kse_usb_release_20181003_578734e.zip
Code:
Satdreamgr-6.0- VU+ Uno4k SE Image
