Stirea bomba vine de la Andrea
LE:
Acest Oscam nu are DVB-api compatibil 100% cu VITMODOS, in concecinta nu deschide!
Code:August 25th, 2016 at 22:01 | #137
Reply | Quote
I released also OSEmu for VITMOS. Same folder as oscam.
http://www.costan.org/K1Plus/OSEmu
This should allow for EMU fuctionality inside Oscam directly. Please read the manual on github for configuration:
https://github.com/oscam-emu/OSEmu
Also prepare a startup script similar to oscam one if you want to avoid to login after each reboot.
[Only registered and activated users can see links. Click Here To Register...]Code:Andrea
August 23rd, 2016 at 20:08 | #125
Reply | Quote
The URL to download:
http://www.costan.org/K1Plus/oscam
Just save the binary on the K1Plus running VITMOS (ssh access using root/root) under /usr/local/sbin and create all the config files under /usr/local/etc.
For autostart just go under /etc/init.d and create a script named S51oscam like the other startup file (I have one on the box, but I’m not at home at the moment).
If you’re just impatient, for quick tryout, launch
/usr/local/sbin/oscam -b
and it should have started.
You can also remove wicardd from the startup, it’s not needed anymore (and possibly may clash with DVBAPI interface socket).
Also note that wicardd is not working with DNS, since the libc is dynamically trying to call libnss that is not available on this platform, while this oscam has a statically linked nss in the statically linked libc and thus DNS is working again.
