Ferguson Ariva 4K and Ferguson Ariva 4K Combo
Ferguson Ariva 4K and Ferguson Ariva 4K Combo - Explore the power of Android on your set-top-box!
Main features:
4K UHD - Support for ultra-high resolutions
H.265/HEVC - Support for hardware decoding
DVB-S2 - H.264 Full HDTV 1080P
Support for pay TV card reader (CA)
Dualband Wi-Fi - 802.11 b/g/n 2.4Ghz/5Ghz
Ethernet modem (LAN) for interactive communication with local network and Internet
Bluetooth - Support for connecting the keyboard and mouse or other devices
SD Card Reader
Hard drive ready - Support for easy hard drive installation for TimeShift and programs recording
Android 5.1.1 Lollipop
Kodi Media Center - Advanced multimedia support
Netflix, HBO GO - Excellent cooperation with almost all Video On Demand (VOD) services
DLNA, Miracast i AirPlay - Support for media streaming to the device
Inputs/Outputs:
LNB IN
USB
AV
Ethernet
HDMI 2.0
OPTICAL
Power
USB
Recovery Switch
Micro SD Card Reader
Pay TV card reader (CA) (on the side)
Slot for HDD mounting (on the bottom)
Universal Remote:
Ariva 4K is supplied with an extremely convenient and intuitive RCU-660 remote. The pilot sits perfectly in the hand allowing you to conveniently operate all the functions of the receiver. Note: it is possible to service the receiver using any device based on Android or iOS through the free app: NesTV.
Technical Specifications:
Chipset: Amlogic S905-B, Quad core Cortex A53 @ 2.02 GHz
Flash Memory: EMMC 8GB
DDR III Memory: 1GB
DVBS Tuner Type: On board
DVBS Frequency Range: 950~2150MHz
DVBS Demodulator Mode: DVB-S (QPSK, ETS 300 421) and DVB-S2 (QPSK/8PSK, ETS 302 307)
Video Decode:
H.264/H.265 HEVC MP L5.0 up to 4K UHD 60fps
H.264/H.265 AVC MP L5.1 up to 4K UHD 60fps
H.264/H.265 MVC up to 4K UHD 60fps
MPEG-4 ASP L5 up to 1080P 60fps
AVS Jizhun Profile up to 1080P 60fps
MPEG-2 MP HL up to 1080P 60fps
MPEG-1 MP HL up to 1080P 60fps
RealVideo 8/9/10 up to 1080P 60fps
WebM up to VGA
Video File Format Support: MKV, WMV, MPG, MPEG, DAT, AVI, MOV, ISO, MP4, RM, JPG, BMP, GIF and others
HDMI Output: HDMI 2.0
Video Resolution: 4K 60Hz, 4K 50Hz, 1080p/i, 720p
Wi-Fi: Built-in 802.11 b/g/n, 2.4G/5G dual band
Ethernet: Bilt-in 100M Ethernet RJ-45 modem for communication with Internet network
Audio Decode: Dolby Digital/Digital Plus, MPEG, OGG, OGA, FLAC, ALAC, APE, M4A, RM, MPEG-1 layer1/2, MPEG-2 Layer II (DTS passthrough)
Sampling Frequency: 32KHz, 44.1KHz, 48KHz
PVR Record: Instant Record and Timer Record, EPG Timer Record
Time-Shift Support: Auto Time-Shift
File System Support: NTFS, FAT32
Operating Temperature: 0°C-40°C
Storage Temperature: -10°C-65°C
Humidity: <95%
Dimension (width x depth x height): 258mm x 158mm x 43mm
Input Voltage: 12V 2.0A
Power Consumption: Max 24W
Power Consumption in Standby Mode: <0,5W
Main features:
DVB-S2 - H.264 Full HD 1080P TV
DVB-T/T2 - also support for H.265/HEVC standard
DVB-C - Cable television
SD Card Reader
Inputs/Outputs:
ANT IN
LNB IN
USB
AV
Ethernet
HDMI 2.0
OPTICAL
Power
USB
Recovery Switch
Universal Remote:
DDR III Memory: 1GB
DVBT/T2/C Demodulator Mode: ETSI EN 302-755 V1.3.1 and EN 300-744 V1.6.1 compliant
DVBT/T2/C Frequency Range: 52.5MHz to 866MHz
Video Decode:
WebM up to VGA
Humidity: <95%
Ferguson Ariva 4K Combo----poze
